As I see it, track cars want a slight bit of understeer.....a tail happy track car could scare the weewee out of a guy.....unless you're a dirt track specialist.
Clutch type LSD keep the rear tires spinning at the same rate up to the clutch-unlock rate.....equal means straight ahead....I know, I'm telling you stuff you already know. I avoided this with a TB diff, but "they" say TB diffs don't work well in high HP applications.
I just want to get it so I can get it loose with my right foot, but I certainly prefer high speed understeer and it is why I left the wing on (I was going to leave it off at one point but last minute put it on again).
The Mendy only had a clutch type diff available - I asked about a TB diff but they didn't have that option on the S4 trans.
Are you gonna get another shot at a track day before the winter hits CO?
doubt it - but who knows... there are days that it will be 70 deg in Jan for instance, it just has to miraculously coincide with an open track day.
I wasn't there, but I'll give it my best guess. I think I might go with your assessment of stiffer rear springs depending on how the rear of the car behaved. I'd be inclined to go slightly stiffer (and adjust shocks accordingly) if you need more control over the chassis in the rear. Otherwise, I might opt for a stiffer rear sway bar complimented with softening up the front just a little bit; perhaps a softer sway bar setting, and/or less dampening depending on the spring/shock. JP's right in that you don't want it tail happy, so you need to sneak up on it a bit at a time; but as I said, it's all a best guess. You know me, test and adjust and test and...
given how much motion I had at the rear and the fact I reduced the frequency value I calculated to based on the Penske tech recommendations, I am going to increase the rear spring rate based on what the car was doing. I obviously won't throw the existing springs away
so if I find it affects my ability to plant the throttle out of a turn I will swap back and swap sway bars and put the stiffer one in the rear. Car was pretty flat watching the vids so I think my sway bars are about correct for what I want to do.
I definitely sneak up and specifically set the rear bar soft and the front bar stiff just to hopefully guarantee a start with understeer - oversteer on these cars tends to mean spin - it has to be very slight - so I too try to start under and tune to neutral with on-throttle oversteer which is quite manageable. Just gotta get there
And the more I think about it, those guys standing by Ken timed me at 2:02 and you can see me having to pass traffic that lap... I don't think I ever had a clean lap once I was running my timer (different topic altogether but it double clicks so I have to add two times together and I have to worry about consistency of the second click across the track in the back straight)... it is totally possible the car is faster than that already! I hope so, it feels fast as hell, and they got the black Z at 2:08 and I was gaining on him pretty quickly each lap, probably quicker than 6 seconds difference (tho' who can say how clean his laps were, but that is cooking for a Z06 so he had a good lap there). And the caution was out nearly the whole session with that white Porsche cup car.
The car, on paper, should be good for 1:55s I would think and I suspect I can get there with tuning. Here are some results from groups that I follow for a good comparo since you guys have no way of knowing if 2:02 is fast, slow, or sorta Rocky Mountain Vintage Group - I look at the big bore group as that is all the vintage Trans Am cars and typically where the Porsches run as well. Porsches prepped by 3R can be pretty darn fast and I have yet to see one clear the 2:00 mark, but they get real close-like. Oh yeah, be careful, you have to watch what track config they run, the full track is 2.55 miles and they sometimes to the shorter 2.0 mile version
http://www.mylaps.com/results/showevents.jsp?org=140- Oct 3rd enduro, fastest lap of all cars = 2:02.872 I don't know what car model that is as I don't know that driver combo.
- Oct 2nd was qualifying on the short course, no comparo.
- May 16th Ken Petrie clicked off a best of the weekend of 2:00.891 in his big block 2nd gen Vette. That dude is seriously fast and a champion driver and holds most of the RMVR track records, has Formula 5000s, etc. I should be able to beat that Vette. Note there was a faster car at 1:53.305 - that was a Lola or similar if I understand correctly that was thrown in that group. If I could run with him I would be stoked! He ran a 1:57 in qual and got faster, so did Ken, so me thinks Sunday was best weather/conditions
SCCA stuff - again, watch the course length... July 3rd was 2.0 miles, the 4th was 2.55 miles
http://www.coloradoscca.org/results/201007...ainsRaceway.pdf- Note that a GT3 Cup guy ran a 1:55.911
- Pettiford ran a 2:00 in his Solstice T2 car.
- Mike also ran a 1:57.968 in his C6 Grand Sport in the Sept 4th national event and I was there that day... he failed to qualify, started dead last, worked thru the whole group, then went on to lap the whole group in the session! Awesome driver and took 3 nat'l championships AGAIN that weekend (twice he has done it and the only guy to win 3 classes in 3 cars, let alone twice, in SCCA - amazing driver
I need to be running at the 1:55s to make all this effort worthwhile
