EDIT #1: Added picture and filter part number
EDIT #2: This location works great for a four cylinder car. However, putting even the biggest cooler (12" x 11" Setrab for example) under the trunk will work for around town when running a 3.0 six, but not so much at the track.
I've used the Derale Atomic Cool on 2 different application mounted next to the transmission with excellent results. There was at least a 20 deg drop in oil temperature if not more. What's nice is that the kit comes with a temperature switch.
I use the relay to enable the fan off of the + side of the coil. Main power for the fan comes direct from the battery with a waterproof fuse holder.
The sandwich adapter has a simple bimetallic spring that allows oil to flow once it reaches 180F. I also modified the oil filter mount to eliminate the spring loaded ball (so oil doesn't bypass through it due to the increased pressure drop of the oil cooler) and use a Baldwin B228 filter with an internal relief. It is the same length as stock, but a smaller diameter to clear the engine bar. (Save your breath, yes the filter has less area than the factory filter. It is more than sufficient for regular oil changes
Here's the parts list from my Summit order:
QTY 2 - Fitting, Hose End, AQP Socketless, Straight, -8 AN Hose Barb to Male 3/8 in. NPT, Brass, Natural, Each
Part Number: AER-FBM1206
QTY 1 - Fitting, Hose End, AQP Socketless, 90 Degree, -8 AN Hose Barb to Female -8 AN, Aluminum, Red/Blue, Each
Part Number: AER-FBM1533
QTY 1 - Fitting, Hose End, AQP Socketless, 120 Degree, -8 AN Hose Barb to Female -8 AN, Aluminum, Red/Blue, Each
Part Number: AER-FBM1543
QTY 1 - Hose, AQP Socketless, Rubber, Blue, -8 AN, 10 ft. Length, Each
Part Number: AER-FCV0810
QTY 1 - Temperature Controlled Sandwich Adapter, Oil Filter, Sandwich, Aluminum, Natural, 3/4-16 in. Thread, 3/8 in. NPT Inlet/Outlet, Each
Part Number: DER-15702
QTY 1 - Derale Cooling Products Atomic-Cool Remote Fan Mounted Fluid Cooler, Tube-Fin Type, Aluminum, 9.375 in. x 12.75 in. x 4.313 in., -8 AN Inlet, Outlet
Part Number: DER-15950
QTY 1 - Relay, Starter/General Use, 30 Amp, Single Pole, Each
Part Number: VIA-80237
