QUOTE(rdauenhauer @ Dec 14 2010, 04:18 PM)
I recently started down this same path and the first place I went to research was the
"Lapuwali Classic Thread Forum" Specifically I was hoping to find a description/diagrams and pro/cos for the various solutions: Sandwich to nose, to trunk floor, Full flow (?), other setup ..ect.
But there is
no OIL LINE/COOLER INSTALLATION thread there presently
Sooo.... I nominate this one!
It would be nice to merge other Oil related upgrade threads into this one , example:
I recall another thread that detail tapping the case below the OE cooler and required clearancing of motor mount brkt ? What about filter relocation ?
Deep sump, tuna can & dry sump perhaps can go into a separate thread?
What do you think
filter location can be an issue with the sandwhich adaptor used in tradisrads installation. thermostat equiped sandwhich adaptors are kind of tall, and that lowers the oil filter. the stock sized OEM filter is now out of production, but there is a shorter version that is now sold , that will give more clearance with the sandwhich adaptor in place.
for me I will be likely going full flow off the oil filter mounting bracket point on the case. will have two hoses there in and out, then run a remote High Pressure filter and follow that with a plate type cooler simular if not the same as tradisrads. along with an electric fan.
to answer the other question, Yes even stock cars can benifit from an oil cooler, these cars even when new could run hot.
hot climate steep hills can cause oil to get beyond my confmort range (180F is nice, 200 F is hot, and above 220 F it is a probelm as oil pressure wil start to drop (viscosity lowers) beyond this point.
you can see these temps on a hot day.
new oxygenated fuels cause our cars to run hotter (lean burn) since are ecu can not adjust for it (cars with an O2 sensor can adjust and with carbs, you can re-jet)
add that many engiens may have been rebuilt with less than optimal compression, and other engines have dirty cooling fins, and you can get even more high temps.
so yes a stock motor can usually benifit from an external oil cooler. if you see high temps above 220F, then you shoudl consider it (make sure rest of cooling system is in good shape first!)
