QUOTE(stugray @ Dec 14 2013, 01:50 PM)
I have a batch of adapter plates for the cooler location sitting in a box here.
Chris - any chance you have a block off plate for where the oil filter bracket goes?
So I could route to a remote oil filter bracket?
I wanted to use the sandwich adapter that I already have, but my plumbing to the front oil coolers is 12AN. The sandwich plate that I have does not have enough space between the fittings for 2X 12AN.
So I either need to come off the adapter plate with the 3/8" fittings to a remote adapter, or I need to replace the filter bracket with a plate that has 1/2" NPT fittings (3/8" NPT would work if they were far enough apart to use the 3/8"X1/2" reducer fittings).
I could go the "ful flow" pump route (probably drop the engine) or the cooler block off, but I actually wanted to keep the stock oil cooler so If I add a thermostat to the plumbing to the front coolers, I still have some cooling until the thermostat kicks in.
That way racing in cold(er) weather will not engage the front coolers until the whole system is warmed up.
I kinda like that idea too ..... as of now, I am still
slightly attached to the stock oil cooler
............ however I believe this oil circuit diagram for the type 4 ....... may help make a decision on where the 'additional' or 'replacement' oil cooler should be placed in the circuit .....
P.S. I got this diagram from another site (link below, it was a changing GIF), so someone please confirm that this circuit reflects our type 4 engine case.
http://www.ratwell.com/technical/FAQ.html
