ThePaintedMan
Sep 20 2012, 10:13 PM
Of course when the exhaust came off, it brought about another set of problems. Most of the studs were loose or already pulled out, so I ended up installing time serts for the time being. Paul (URY) found a set of heads he had, which I'm looking into getting rebuilt at a local machine shop. Paul, when I found out what condition they're in, we can figure out a price?
In the meantime, I'm stuck with these heads. I'm pretty sure #3 has a burned ex valve. Below is a picture - is there anything obvious from it?
Click to view attachment Also, last oil change was pretty curious. At the bottom of the tuna can was a bunch of crusty stuff. I ran a magnet through the sludge, and nothing stuck to it except a few very small slivers. I wonder where all this crap came from then?
Valy
Sep 21 2012, 04:07 PM
QUOTE(ThePaintedMan @ Sep 20 2012, 09:13 PM)
Click to view attachment Seems to me that the plug hole was already fixed once but someone didn't take the time to cut a flat set for the plug.
It can be fixed but make sure it's cut it straight this time.
ThePaintedMan
Dec 12 2012, 07:58 PM
Been quite awhile, and in fact, only a little over a year after I purchased the car, I can't believe how far its come. Dropped a transmission, drove it, dropped the trans/engine, repaired the passenger long, floorboards, put the drivetrain back in and now almost ready for paint in a little over 12 months. So, after the Tropical Ramble, landing a full-time gig and sort of figuring out school and money for the time being, I got a chance to tackle what I consider my specialty (and my favorite hobby, believe it or not) - bodywork. I started with the front and rear trunks.
ThePaintedMan
Dec 12 2012, 08:09 PM
I guess I don't have a good picture of the front trunk or rear trunk painted. But here is the prep work on the rear. This was probably one of the most difficult tasks I've done on the car. The PO sprayed some kind of rubberized undercoating all over it. The "lie detector", as Scotty B calls it, didn't work very well, neither did a standard wire wheel. The heat gun made progress but it was slow and I was removing a lot of good paint, which I felt was unnecessary, since there wasn't rust in the majority of the trunk. Finally I tried brake cleaner, which is dirty, greasy work, but removes that rubberized stuff like a charm. I wonder if the same would be true for you guys removing the floor tar? The last pic is after filling in pin holes and reapplying seam sealer where necessary, then a coat of POR.
billh1963
Dec 12 2012, 08:11 PM
That's awesome progress compared to many cars on this board that have been on jack stands for years!!!
ThePaintedMan
Dec 12 2012, 08:17 PM
I've said from day one that this was to be a "rolling restoration." By that I mean, I wanted to get the car mechanically as sound as I could so I could enjoy it, even if it looks like a turd. The other part is that since I do not have the ability to own a compressor where I live, I have to drive to my previous company's shop (which they graciously allow me to use) in Tampa to do any kind of work that requires one. And, well, I'm tired of working outside. I also happen to work in Tampa, so when I get off at the end of the day I spend a couple hours doing a little bit of body work here and there with filler. Here is the last bit of welding that I had to do before I could start with the filler.
Madswede
Dec 12 2012, 08:22 PM
Lookin' good man!
ThePaintedMan
Dec 12 2012, 08:26 PM
Unfortunately I welded this up with flux-core prior to the Tropical Ramble, where John Faure (Fourblades) so graciously donated his great Hobart mig setup
. However, as John said, the proverbial and literal torch has been passed and I plan to put it to good use with the roll cage. Thank you once again John.
On a side note, if any of you are ever going to re-paint your cars or do any work around the door jamb area, make sure to check not only the little round vent for rust, but also the area I cut out. Poke and prod there and more than likely you will find plenty of weak metal. If you didn't have the sail panel trim, you might get lucky. This is a big blunder I think on Karmann's part - below you will see the white epoxy-like chunks I scraped out of this area, which trapped water, most of which came in through the holes in the sail panel.
ThePaintedMan
Dec 12 2012, 08:31 PM
Here is something interesting. I didn't know till recently looking at all the other cars at the TR that the fenders are not supposed to be flush with the cowl. The PO of my car had at some point filled all this in. So, I ground out the filler to see what was underneath. Sure enough, the fenders are welded to the cowl where there would normally be a seam. Luckily, they did a decent job and there was no rust under the filler, so I re-filled it.
ThePaintedMan
Dec 12 2012, 08:42 PM
Almost forgot about this. The front of this car was tagged pretty good at some point, obviously.
Click to view attachmentThe headlight bucket was pretty buckled. If I were in a different spot financially or this car had been in better shape to begin with, I would have just sourced a replacement piece.
Click to view attachmentBut, as I wanted to learn more about metal and collision work during this process, I thought this would be a good chance.
Started by drilling out spot welds (anyone else who has tackled any metal work will know this is usually the first step).
ThePaintedMan
Dec 12 2012, 08:50 PM
Then I "relieved" the metal by cutting it along the creases.
Click to view attachmentThen cut the three welds holding the bucket support bracket to the fender. I then let the redneck in me out and hooked up a ratchet strap to the bucket. Next, rolled the car backwards in neutral a few times, and checked the distance from the bucket to the bulkhead using the passenger side measurements as a reference.
Click to view attachmentFinally, once I was satisfied, that was all welded back up. Fast forward to last week, and this is what it looks like with a little filler.
ThePaintedMan
Dec 12 2012, 09:08 PM
More filler. Trust me, it looks like a lot more than it really is. I pulled and dollied out as much as I could before starting. Also, if no rust was present, I chose to scuff the surface lightly prior to adding filler. I personally don't believe in stripping it down to bare metal before filling, as the paint is one more barrier to prevent rust. If you were doing a concours car, obviously it would be a different story and you probably wouldn't consider filler in the first place. For me, no big deal
Click to view attachmentNow here is the frustrating part. See all those black swirlies? It appears as though someone at some point let a five year old loose on this car with a dremel or something along those lines. They were ALL over the car. None that I observed went through the sealer or first coat, but most were through the second paint job layer. I only discovered this when I started to DA/block the car. From what I understand, this would usually mean taking the whole car down to at least the first coat. Since I don't have the time, resources or a dedicated shop, I can't strip the whole thing down. So instead, I decided to block it as best I could so that the primer coats I would lay wouldn't have so many steep "valleys" to fill. Perhaps Scotty B or Rick can chime in here, but I'm keeping my fingers crossed that once I block the primer I won't see these valleys in the final coat.
Click to view attachmentAnd that brings me to last weekend, where I shot a coat of urethane primer/sealer. I will block this coat and then possibly shoot another before color. Traditionally a great paint job gets at at least 3 of these before color, from what I understand. But for a Chumpcar/daily driver, I think I've probably already done far more than was really necessary. The best part was that my fiance said, "Okay, so I just want to say, you did a great job. A year ago, I never thought you'd get this far. I'm proud of you." .... I guess I can keep her
Wait till it gets color - she might even ride in it then!
FourBlades
Dec 12 2012, 09:18 PM
Nice work George!
It is looking good.
John
jdlmodelt
Dec 12 2012, 09:42 PM
QUOTE(ThePaintedMan @ Jan 11 2012, 11:07 AM)
Thanks for the kind words fellas. Been raining all day so I couldn't get any work done on the car before classes this afternoon. However, I went out and took a few photos. This one is the passenger floorboard we made. Still needs some welding and a few more bends to be complete, but I think it'll do fine in the car. It was a full days worth of work to make, but for me, cost is everything. If you look at the welds, you can see how it was done. We cut a few slots lengthwise using a cutting wheel as well as one down the side for the seat channel. Then, bent those downward using channel steel and a ball peen hammer. Then, hammered this "V" shaped valley against bar steel to achieve more of a "U" shape. This left about an 1/8th to 1/4 in gap, which had to be welded closed. The only real problem was the warping, because I failed to mention to mark that he needed to put in all of his spot welds first. However, fitment wasn't bad, and since this car was destined for a scrap yard anyway, I think anything we do to it is an improvement. Once I'm out of college I'll find a nicer model to do everything the "right" way
nice work! have you decided to build this up right? i thought you were going to take it to a smashem up derby and about cried. kinda like "The Crying Game".
carr914
Dec 12 2012, 10:11 PM
You really don't want to repeat your Award from the TR
no1uno
Dec 12 2012, 10:29 PM
It's looking better and better. way to go!
Gint
Dec 12 2012, 10:35 PM
Dec 12 2012, 10:43 PM
URY914
Dec 13 2012, 05:54 AM
Good job Painted Man. Your name fits.
bcheney
Dec 13 2012, 06:30 AM
It's great to see all your progress with the car! Your doing a great job and with her support the sky is the limit
ThePaintedMan
Dec 13 2012, 11:42 AM
Thanks guys!
No, I don't plan to take it to a 'smash em up,' but I won't be terribly upset when it gets tagged in a race... if and when that day ever comes. But for the time being it will be nice to have a decent paint job so I don't have to repeat my award , as TC reminded me, at next year's Tropical Ramble. Just to piss you off though T.C., I will be keeping the rear reflector. After working on the rear, it would have been more work than is necessary to fill the holes and straighten all of the dents. I promise the next teener that I get won't have the goofy reflector.
carr914
Dec 13 2012, 01:46 PM
I don't mind you keeping the reflector, it only makes me angry when someone butchers a car to put one on
ThePaintedMan
Dec 17 2012, 03:40 PM
Crappy pic, and not quite the paint job I had hoped for, but it'll do for now. Need to color sand and possibly repaint the hood after it dries over the next month. I was wearing gloves and didn't know my hands were sweating inside. Needless to say there is a spot where sweat dripped onto the paint where I had just gone over. Oh well, looks better than it did.
billh1963
Dec 17 2012, 03:42 PM
Great work!
mr914
Dec 17 2012, 03:53 PM
wingnut86
Dec 17 2012, 05:03 PM
Damn George - Awesome work!
carr914
Dec 17 2012, 05:09 PM
Looks like you're going for Most Improved Award at the next Tropical Ramble
URY914
Dec 17 2012, 05:43 PM
Nice work!
euro911
Jan 24 2013, 02:31 AM
First time seeing your build thread, George. Nothing short of awesome!
Anything else transpired in the past month?
ThePaintedMan
Jan 24 2013, 06:57 AM
QUOTE(euro911 @ Jan 24 2013, 03:31 AM)
Thanks Mark
Yeah, I've been piecing things back on it for the past few weeks and removing others to repaint or replace. I mocked up the cage so I could get measurements and soon I'll start wiring it for a cutoff switch, etc. Still have a small hesitation under heavy throttle transition, but I think that can be solved with bigger idle jets. John (FourBlades), my new teammate
has agreed to loan me some so I can troubleshoot. Here is the most recent picture. Would never have gotten this far without everyone else's help and inspiration. Thanks again!
JawjaPorsche
Jan 24 2013, 07:04 AM
I like the chrome-less look! Nice job!
billh1963
Jan 24 2013, 07:05 AM
Quite a transformation! You have every reason to be proud!
KENNY
Jan 24 2013, 07:15 AM
Awesome work!
bulitt
Jan 24 2013, 07:17 AM
Holy Crap George, It's awesome!!!
scotty b
Jan 24 2013, 07:19 AM
Looking good. Sorry I never saw your post about those gouges in the primer coats. di that turn out o.k. once you got the color on ?
Cracker
Jan 24 2013, 07:27 AM
I'm not inspired...I'm exhausted! I'm too old for this stuff but am glad to see some of you out there have a vision and tenacity to save cars like this! Your car looks great and you should be very proud!
Cracker
stuttgart46
Jan 24 2013, 07:41 AM
Good looking car you got there. Well done.
ThePaintedMan
Jan 24 2013, 08:36 AM
As always, thanks for the support fellas. The paint on the car didn't turn out quite like I had hoped, even though it looks decent in crappy pictures. Up close, there are a couple dimples I missed here and there and I should have spent more time with the 600 grit since I can detect some sanding lines in some areas. However, given the gouges that Scotty pointed out and the amount of crappy work done previously, I'm fairly happy with it. It was my first time spraying single stage, and I learned a few things. Either way, eventually it will hit the track and look better than 99% of the Chumpcars out there (well until the first corner at least.) For now I'm just having fun
and receiving thumbs ups!
Next to do:
Finish the bolt in cage
Wire up cutoff switch
Install remaining gauges (this will be a cool project - going to rework the dash in fiberglass)
Hopefully test it out at a DE soon
rhodyguy
Jan 24 2013, 09:35 AM
nice work george.
Millerwelds
Jan 24 2013, 10:48 AM
Looks great! I would paint the mirror(s) black so the body line flows better. I also like the all blacked out trim and black mirror(s) would add to that. Congratulations - great work!
jdlmodelt
Jan 28 2013, 09:11 AM
QUOTE(ThePaintedMan @ Jan 23 2012, 10:22 PM)
I'm pretty sure I'm not going to get any flack from anyone else for this....
Are you unemployed or just living off of your parents? You must be to find time to go around telling people how they should live their lives.
FYI - I'm at the end of my coursework in my Masters Thesis, holding a 3.76 GPA while teaching several labs and busting my ass at my day job out in the sun. I'll be happy to provide a copy of my transcript as well as letters of reference if it pleases you. Otherwise,
QUOTE(windforfun @ Jan 24 2012, 12:05 AM)
Are you getting A's in school? If not, why the hell are you waisting your time with a beat up old car? It's an old piece of shit. Face it, you'd be better off studying & preparing for your future.
WOW! I can't believe someone would rip into you like that?! I am inspired and impressed with what you are working on and what you are accomplishing.
Keep up the amazing work!
James
Dr Evil
Jan 28 2013, 09:28 AM
QUOTE(jdlmodelt @ Jan 28 2013, 10:11 AM)
James
Wow, the lack of civility is palpable. What is the point in posting such harsh words and criticizing?
I guess I have a dog in this fight:
BA Psychology with a 3.9 while working on my 914 and others transmissions.
MD - while working on my 914 and other transmissions.
MPH - third verse same as the first.
Oh, and I have many other projects as well. I put myself through school. I managed to fund my hobbies by providing services to members here like transmission clinics, DVDs, parts, interiors, CV bolts, special rear view mirrors.
How someone managed to maintain their hobby is none of your business unless they decide to share it. The distraction this hobby offers from school work is priceless.
bulitt
Jan 28 2013, 10:41 AM
QUOTE(Dr Evil @ Jan 28 2013, 10:28 AM)
James
George is like the Board's adopted, little brother, most everyone tries to help him!
Some people forget their manners... "If you don't have something nice to say, than don't say anything!"
bembry
Jan 28 2013, 11:11 AM
Man--great job with the car! Mine sat for 14 years before I got it going again. This was fast!
mittelmotor
Jan 28 2013, 12:19 PM
Ignore the haters, George, and keep inspiring us with your work!
billh1963
Jan 28 2013, 12:46 PM
3.9 in psychology?... Why not a 4.0?
My GPA was 3.925/4.0 for my BSEE...now that was a lot of work.
Only got a 3.75 for my MSEE. Of course, I had two small kids and was flying back and forth to England for a year. I guess I got lazy...
ThePaintedMan
Jan 28 2013, 01:22 PM
Thanks again fellas. That guy posted a long time ago, and have not heard from him since. Either way, my coursework is done and now I'm just finishing up my thesis.
I always thought of myself as the red-headed stepchild of the forum, but I'll take younger brother any day.
Full disclaimer though, I never intended this car to turn out as nice as it has, which is still a long way from most of your restorations. If quality isn't a main concern, it definitely speeds up the process. I envy those of you who are doing it "right." Hopefully I'll have some cool stuff to show in the next two months as the rest of the stuff gets done. Right now its wiring the kill switch ignition switch and starter button, which confuses the hell out of me. I'll need all the help I can get!
Kirmizi
Jan 28 2013, 01:29 PM
Keep up the good work at school and on the teener, both will be well earned accomplishments when you're finished.
Mike
Dr Evil
Jan 28 2013, 02:07 PM
My comment was not aimed at George, it was kind of hard to tell
ThePaintedMan
Jan 28 2013, 02:38 PM
QUOTE(Dr Evil @ Jan 28 2013, 03:07 PM)
No offense taken Dr. Mike. Question for you though - as we all sat around imbibing watching the Rolex 24, I was asking some of the guys about my transmission. I noted that I usually can produce a grind in every gear but fifth if I don't give plenty of time between throws, and of course the 1st synchros are definitely shot. I haven't really ever driven a teener with a new transmission quickly, so I'm not sure - with a freshly rebuilt gear stack, is it possible to shift any quicker than a... one Mississippi, two Mississipi without them grinding? I'm assuming this transmission its the original box and never been serviced, though it does have brand new fluid in it which helps.
On a similar note, there is a guy about 50 miles away selling a recently rebuilt side shifter for $300, which I've considered. While I'd like to send this one off to you to work your magic on, I think this is a decent deal to swap out to get me around in the meantime. Your thoughts?
