xsboost90
Jan 8 2005, 09:35 AM
Yeah im still doing the two tone paint but i may be changing some things. IM thinking about something alittle brighter but without being like a f&f car. Ill prob. keep the black lower but make the top something besides silver, like candy tangerine or blue or something...dunno yet.
mirrors- i found them AFTER i bought them on
http://www.springfieldstreetrods.com/HTML_...nia_Mirrors.htm
Trekkor
Jan 8 2005, 09:45 AM
Good progress thread.
Looks like you are having fun.
KT
xsboost90
Jan 8 2005, 10:28 AM
what if the paint scheme looked more like this????would this be porsche-lly offensive? The orange would actually be like a copper or candy tangerine color. Or maybe silver with the flames...the black would be inside the flames and the lower flames would just be pinstripe..yeah i do that too.
Root_Werks
Jan 8 2005, 11:09 AM
QUOTE (xsboost90 @ Jan 8 2005, 07:34 AM) |
heres my mirrors- manually operated no cables or anything, but they are adjustable and have little caps to cover the screws after you install everything. |
I have these exact mirrors on my 914. They came on it when I bought it. They rock! One thing though, I had the 914 painted and never bothered to check the mirror placement/adjustement (never drove the 914 before I painted it) and trusted the PO's mounting. Big mistake, they are too far to the rear of the car. Make sure to mount them ahead of the quarter window post depending on how tall you are ect. So I have to look down to see through mine. Sucks, but dang, they look sweeeeeet!
The 944 flares, go for it. I saw one 914 like 10 years ago with 944 front and rear flares. Looked like they were made for the car! I was too young and dumb to take pic's though. But looked great.
xsboost90
Jan 8 2005, 08:34 PM
got my arms all painted up tonite, will be hopefully installing them this week!!
xsboost90
Jan 20 2005, 10:36 AM
well, finally got the arms and repainted struts on and put in my second set of bearings..still had some troubles with them but we'll see how they do.
xsboost90
Jan 20 2005, 10:38 AM
mo pics- oh i also stripped the tar stuff out of the floor, who could forget that!
xsboost90
Jan 26 2005, 09:50 PM
well did some more welding tonite, got the dead pedal and the hole behind my gas pedal welded up. Also did some POR15 treatment to the entire floor and in every hole i could find in the car.
xsboost90
Jan 26 2005, 09:51 PM
po fiteain beeatches!
xsboost90
Jan 26 2005, 09:52 PM
now to work on the front end and check for rust in front extremeties. Havent seen any but im check everywhere while its apart.
xsboost90
Jan 27 2005, 09:27 PM
picked up my 944 front hubs tonite. These will work well w/ my 911 slotted rotors when i mount them on the 911 spindles,struts im getting and im also picking up a 19mm master cylinder from the same guy. My bud also gave me a 944 jack and jack handle to put into the front above the spare.
Aaron Cox
Jan 27 2005, 09:29 PM
QUOTE (xsboost90 @ Jan 27 2005, 08:27 PM) |
picked up my 944 front hubs tonite. These will work well w/ my 911 slotted rotors when i mount them on the 911 spindles,struts im getting and im also picking up a 19mm master cylinder from the same guy. My bud also gave me a 944 jack and jack handle to put into the front above the spare. |
944 hubs fit on 911 spindles????
are you sure?
xsboost90
Jan 27 2005, 09:33 PM
according to a couple people ive talked to the inner hub part from an early 44 fits the spindle of like 78-83 911. The outer rotor fits perfectly.
xsboost90
Jan 27 2005, 09:39 PM
check this out...found it on paragon-products.com
Wheel Bearing - front, inner
Fits 356 64-65, 911 65-89, 912, 914/6 70-71, 924 77-82, 924S, 944 83-86 more info
List Price: $12.95
Our Price: $9.65
You Save $3.30! Qty Add
Wheel Bearing - front, outer
List Price: $13.85
Our Price: $7.93
You Save $5.92! Qty Add
ft.lbs.
Jan 28 2005, 11:14 AM
I mounted '85 944 hubs and rotors on '69 912 spindles.
monkei
Jan 28 2005, 11:25 PM
QUOTE |
Andrew has been eyeballing my spare set of 944 rear quarter pannels sitting in the backyard. We did some measurements a few times and it is a possibility. Maybe have to put them on backwards due to the length of the pannels. |
QUOTE |
The 944 flares, go for it. I saw one 914 like 10 years ago with 944 front and rear flares. Looked like they were made for the car! I was too young and dumb to take pic's though. But looked great. |
i would love to see it! ive considered the same thing before. ive always been a fan of the 944 s2 front clip. that'd be cool to use it (sectioned??) in conjunction with the 944 fenders.
xsboost90
Jan 29 2005, 10:12 AM
picking up my 911 parts tonite at the pca chili party..yippy!
xsboost90
Jan 30 2005, 10:17 PM
picked up my 911 spindles, rotors, calipers and master cylinder tonite. It looks like the mc wont work though. I mounted everything up to make sure it would fit and everything is great but the offset of my wheels is going to require me to space the front almost two inches! I used my early 944 hubs to mount the rotors and they fit fine. Now on to find another master and disassemble the front end, paint/detail, new bearings and check out the floor in the front before i can put it all back together again!
xsboost90
Feb 13 2005, 10:39 AM
got my turbo tie rods, installed the rack again after i finished welding and undercoating the front end. Waiting for my german liscense plate to come in air mail! Started installing the front suspension again tonite and hopefully have it back on wheels again tomorrow or monday so i can start body work. Im finished w/ rust!!!! Finally time to get back to the stuff i like, paint!
xsboost90
Feb 19 2005, 06:46 PM
welded, sealed, undercoated and starting to install stuff, once again. I am having trouble w/the calipers fitting correctly though.
xsboost90
Feb 19 2005, 06:48 PM
she is puuurrdy under der.
CptTripps
Feb 19 2005, 09:28 PM
Did you scrape everything out of the wheel wells before spraying more undercoating on?
What undercoating did you use? I've got to get a lot of it, as I've got shiney new floors right now.
Keep up the great work. Maybe I can drive mine down there and I'll have you paint it too! (I'm dreading that part)
xsboost90
Feb 19 2005, 10:38 PM
i tried a bunch, best out there is 3m, the big can. That stuff rocks. I did the entire front under w/ one can, and the rear w/ one can.
CptTripps
Feb 20 2005, 09:32 AM
I've got a can of the NAPA stuff, the DynaMat stuff, and another off-brand. (Not that those aren't.) I'll give them all a shot on some scrap and see what looks like it'll work the best.
Is thicker better, or endurance? Did you prime first?
xsboost90
Feb 20 2005, 09:36 AM
i wire brushed the old stuff off and roughed up the surface a bit w/ some scuff pads.
the 3m seems to spray out alot nicer and cover much better. It also seems to stick better than the cheaper stuff.
CptTripps
Feb 20 2005, 10:01 AM
Looking back at your older posts...
Are the holes in the center tunnel something I should do? that seems like a place that rust could START rather than prohibiting it.
Aaron Cox
Feb 20 2005, 12:39 PM
throw A sway abr on there while you are doing front end work
xsboost90
Feb 20 2005, 02:20 PM
oh yes, a sway will be in there before the tank goes in, im still saving my pennies and trying to decide on a 19 or 22mm sway bar. Im thinking just get the 22....
xsboost90
Feb 22 2005, 09:46 PM
well, it took some small spacing but the calipers fit like a glove. Finally got the rack hooked back up and the parts prepped, painted and installed. Yet to get brake lines or mc yet. Now its time to prep under the tank area, get ready for a sway bar, and do some body work! Also got my euro german plate in to stick up front. Progress..i can see it coming together finally!
CptTripps
Feb 22 2005, 10:16 PM
::: golf claps :::
Nice work...that's about where I'm going to be this weekend...back on the ground, ready to start body-work.
Stay pumped, and it'll be done in no time!
Dave-O
Feb 22 2005, 11:17 PM
Isn't it a great feeling to get her back on her feet. Keep working, it will be driving season in no time
David
xsboost90
Feb 26 2005, 07:41 PM
time to get her all stripped for some primer/ paint. Ive been busy the last couple days w/ the chem stipper and the d/a sander getting it all stripped down. I wouldve gotten farther but the parts house w/ the sandpaper closed at 5
. Heres the progress as of today.
xsboost90
Feb 26 2005, 07:43 PM
got the quarter stipped and sanded completely, still working on the door jam though, it was brazed in a couple spots and the filler above that cracked, so now im trying to weld, grind, fill it so it wont come back.
xsboost90
Feb 26 2005, 07:46 PM
drivers quarter is perfect but the ps has some damage, not too bad, just need to grind it all out and redo it just to make sure.
xsboost90
Feb 26 2005, 08:23 PM
heres the doors while stripping them. ONce again the ds is pretty good, just one small crease under the paint/bodywork. The ps is slightly worse but still workable. I had to weld a couple of small pinholes
xsboost90
Feb 26 2005, 08:30 PM
oh, and another toy i got today, actually its a belated birthday present, just came in...
CptTripps
Feb 26 2005, 08:58 PM
Keep up the great work man...
You are 3 steps ahead of me, so it's nice to see what I'll be spending my weekends doing the rest of the month!
What chemical did you use to strip? Would you suggest that, or a 3M pad or something?
xsboost90
Feb 26 2005, 09:25 PM
in most cases, when im painting a car, ill just sand it down. This thing has been redone once before, and painted w/ enamel, so i wanted to make sure it was not an issue. I used Aircraft Stripper, cant remember the name brand but it comes in a gallon. Heavy duty stuff, i had to run the exhaust fan and open a door to keep from being overcome by fumes. Now i just need to sand everything down, fix the crap underneath and primer/ block primer, paint! I keep saying im not going to strip the front fenders because i dont want to know what is under there, but ill prob end up stripping those too.
Steve Thacker
Feb 27 2005, 05:34 AM
Keep up the good work Dan, you are making fantastic progress. We have a caravan to catch and from the looks of it, you will make it with no problem. Hang in there
xsboost90
Mar 4 2005, 09:54 PM
sprayed alittle primer tonite, its just for blocking out body work, but its progress. Ds quarter looks good, two little dingers. Ps is getting close.Hopefully she'll be ready for paint before next month.
xsboost90
Mar 4 2005, 09:56 PM
more primer.
Steve Thacker
Mar 5 2005, 07:54 AM
Keep it up Dan,...just keep focusing on the end product.
Motivation, Motivation, Motivation....Nothing.........is more important.
The MWC is calling your name like a siren of the sea.
Ya...Ya I know...
OK...just cut the philosophical shit and stay with it. You are doing good.
CptTripps
Mar 6 2005, 09:23 PM
What did you use for primer? Just rattle-can stuff, or is there something particular?
I'm going to start tearing the paint off tomorrow. We'll see how far I get, but I want to cover it with SOMETHING so it won't start 'turning brown' on me early.
Keep up the great work...
xsboost90
Mar 31 2005, 09:49 PM
i use evercoat euro-primer, its high fill and sands very well. Not great for keeping things from rusting in wet weather, you need some sealer primer for that or self etching. More pics of progress and stuff i bought.
xsboost90
Mar 31 2005, 09:50 PM
nice weltmeister sway bar showed up today at work, nice!
xsboost90
my cabinet o' goodies
CptTripps
Mar 31 2005, 09:55 PM
Sweet...
I HOPE I'm in primer by the weekend. At least the first coat. I got the PPG 36.
xsboost90
Mar 31 2005, 09:58 PM
mine would be mostly in primer by now but this quarter is really messing w/ me, should be able to spray some tomorrow. Got it all vac'd out and taped up tonite.
kafermeister
Apr 1 2005, 09:28 AM
Dan, I've got a right rear quarter I'd sell cheap if you decide to go that route. It was cut off at the targa bar but the rest is there.
Rick
xsboost90
Apr 3 2005, 09:50 PM
naw, i think i got the quarter whipped, got most of the car in primer today, front fenders, rear quarters, both trunk lids, ds door. Still need to finish the ps door and the engine cover, do some small ding repair on the fenders, etc but almost there.
