Did a few things that I wanted to document here.
1. Resealed the back window. No more rattles! Some DAPO had shoved every bit of paper and foam imaginable back there to try and stop the rattle.
2. Pulled the water injection setup. I didn't feel any difference and in the mean time was able to tune out the pinging. The water injection may have been too small, but I realized that keeping a container of water in the car was not something that I wanted. Now the pump is repurposed as a water pump for my water-cooled TIG torch.
3. Got new tires to replace the 10+ year old tires that were on there. I recently went to an autocross, so I had performance stuck in my head. So I got all excited when I saw Falken made their ZE-912 tire in a 205-
40-16. Got these ordered and installed and then immediately remembered that I don't like how a 914 looks with small circumference tires.
And then I drove it and remembered that I don't like how small tires change the cruising RPM.
So these will come off ASAP (probably after winter) and I'll get something back in the 205-50-16 which is really close to the stock tire size.
4. I had been using an old Odyssey compact battery that I had left over from a project
(Hi Rob!), but as winter started setting in the cold morning pretty much killed the battery. I remembered why we pulled it out in the first place. Cold cranking was pretty much nonexistent and I didn't realize how weak it was overall since it was able to start the car when warm. But I got a new Optima and
now the motor
cranks!
5. Finally, while the tires were being replaced I was poking around under there and realized I had forgotten this car has a BIG front sway bar and some sort of firmer rear springs. I thought it handled better than stock, but now I know why.
Yup, Neat idea reducing the weight but in the real world where my car lives, I need it to start all the time.
