76-914
Jun 27 2016, 08:01 AM
Sweet. You gotta love eye candy when it improves your ride.
Mine too, became a daily driver once I did the conversion. It's been dry docked for a couple of weeks now and man I miss it. What's left on your "to do" list?
Mueller
Jun 27 2016, 08:40 AM
Pretty brake parts...I like your ECU mounting as well, great job!
A&P Mech
Jun 27 2016, 07:08 PM
QUOTE(76-914 @ Jun 27 2016, 08:01 AM)
The next big expense is SpeedHut gauges. I hope to have them before the RRC. The muffler that I had installed needs to be replaced. The car is to loud. The wife doesn't like riding in it. My front swaybar is painted and ready to be installed. I still need to design and build a center console, and I am slowly buying new rubber seals from 914Rubber to try and keep the rain out. I have my interior almost done. The dash has been replaced along with new seat upholstery and carpet. I am pretty sure I am funding Marks retirement right now. Lol. I would love to get it painted but I am pretty sure that is outside my budget. I have a friend that vinyl wraps cars. I am thinking about trying it? I wonder if they make Revenna green vinyl?
It has been a lot of work but the conversion was soooooo worth it!
914forme
Jun 27 2016, 07:36 PM
No quite what your looking for
A&P Mech
Jun 27 2016, 07:40 PM
No, but I do like it.
Kent, Why are you in "Dry Dock"?
A&P Mech
Jun 27 2016, 09:31 PM
One down, three to go. They are sure pretty.
Jun 28 2016, 04:35 PM
QUOTE(A&P Mech @ Jun 27 2016, 06:40 PM)
This happened!
http://www.914world.com/bbs2/index.php?showtopic=286795
A&P Mech
Jun 28 2016, 09:44 PM
QUOTE(76-914 @ Jun 28 2016, 04:35 PM)
This happened!
http://www.914world.com/bbs2/index.php?showtopic=286795Wow that's a bummer. The only reason I have a Subaru in my 914 was because the head gaskets were leaking in my impreza. I pulled the motor and replaced the head gaskets then installed it in my 914. I replaced the motor in my Subaru with a lower mileage scrap yard find.
I was able to get the driver side rotor and caliper replaced tonight. I just have the rear rotors, calipers and master cylinder to go. During the replacement tonight I found this.
Click to view attachment The boot is less than 2 years old! Maybe I shouldn't have bought the cheapest turbo tie rods I could find. Now I need to find some replacement boots.
rnellums
Jun 28 2016, 09:57 PM
I think shea stocks those!
A&P Mech
Jul 2 2016, 04:36 PM
I am working on replacing the Brake master cylinder as part of a complete brake job and decided it was a good time to get side tracked. Time for some new Pedal bushings.
A&P Mech
Jul 2 2016, 07:41 PM
The master cylinder is now installed. Wow the reservoir lines were a total PITA! It sure seem like that connection solution could have use a little more engineering.
JRust
Jul 2 2016, 09:14 PM
Yeah I absolutely hate doing the MC lines. On my v8 car the darn lines kept leaking. After replacing it multiple times. I finally figured out there was enough flex from my pedal use through the wall. That it would pop my lines out after a month or so. If you have someone in your car push your pedal's with you underneath. you'd be surprised how much flex there may be. McMark made me a brace. After that no more problems for me. Basically had something attach around the rack that had an arm that stuck out under the MC. Made it solid & no more issue. May not be necessary for you but something to look for.
I spent a good 4 hours in my car driving today. Gorgeous day today & was top down the whole drive. Loved every minute of it
A&P Mech
Jul 3 2016, 06:38 AM
I was getting a fair amount of flex as well so I fabricated this little bracket. I am getting zero flex or movement! The master cylinder is rock solid.
Chris H.
Jul 3 2016, 07:53 AM
Yeah that bracket should certainly do it
. Looking good my man! Were you swapping the exhaust out or was that someone else?
A&P Mech
Jul 3 2016, 08:22 AM
QUOTE(Chris H. @ Jul 3 2016, 07:53 AM)
Thanks! I was just reading through your thread. Man your car looks great! The manifold flip is looking awesome. How close to two firing it up are you?
I think Kent is reworking his exhaust? It is funny that you should ask. I think you might have psychic powers. I pulled mine last night. I have decided the muffler that I chose is just too loud. My wife hates riding in the car because of the exhaust noise. I spent some time reading reviews and I found a dynomax max muffler that is supposed to be pretty quiet. The best part is it cost $38 shipped to my door. I am not the greatest welder but I am going to give it a shot.
A&P Mech
Jul 23 2016, 06:01 PM
I completed the muffler swap and what a huge improvement! I do believe it was the best $38 bucks that I have spent on the car so far. The exhaust note went from loud and tinny to deep and pretty quiet. .
A&P Mech
Jul 23 2016, 06:10 PM
Today I started the fabrication of a center console. I am kind of enjoying melting metal so I decided to fab it out of angle iron. Digging around in my old parts pile I found an arm rest extension that I purchased for a WRX several years ago. It appears to be a good fit for the 914 so it will be the basis of the center console.
Click to view attachment Click to view attachment
Chris H.
Jul 23 2016, 06:30 PM
How did I miss that reply? Anyway yes the muffler makes a HUGE difference doesn't it? Need a decent sized one with Subarus to quiet things down. I need to make a console myself. Think I will just boost up the stock center bin. Looking good!
A&P Mech
Jul 30 2016, 05:23 PM
I use my phone to stream music to my stereo and as a GPS speedometer. This kills the battery in my phone pretty quick. So until I can get the war department to authorize the purchase of SpeedHut gauges, I had to find another solution. I decided to install a USB outlet in the dash. I don't smoke and don't plan on starting, so I removed the cigarette lighter and installed the USB outlet in the same location.
It works pretty good.
Click to view attachmentClick to view attachment
Andyrew
Jul 30 2016, 06:06 PM
Very nice! I like the stubby USB cord as well.
914forme
Jul 31 2016, 09:28 AM
looks great.
BTW, what car is that console box part out of? I know where to get steel tubing from,
A&P Mech
Jul 31 2016, 02:29 PM
Thanks. I really like the arm rest. It is at the perfect height and it adds some storage. The wife even commented that it was a huge improvement. Once I get the center console completed, it should look good also.
It is out of a 06-07 Subaru WRX. I found an example on eBay .
http://www.ebay.com/itm/like/141824995088?...p;ul_noapp=true
JRust
Jul 31 2016, 04:22 PM
Center console is looking good. In seeing yours I forgot I never updated my thread when I was building mine. I included a pic here. Mine isn't quite done yet. Going to add a forward piece that connect to the underside of the dash. Adding a nice solid cup holder, Cell phone holder & my Fuel Pressure guage . I made my center console have a total of 3 storage sections. The rear one is the deepest as the cables are the lowest. The middle one is about 2 " deep. Then around my shifter I have about a 1" lip. Give's more place to keep random stuff. Still don't like my shift boot but haven't looked for a better one as of yet.
Hoping to see your setup in Person at Red Rocks. Still not a lock to come but I am trying
A&P Mech
Jul 31 2016, 06:38 PM
Your center console looks great! I am planning to add a cup holder to the front of mine as well. I sure hope to see you at the RRC. Ross is planning on it as well as Scotty and myself. Ross has a roommate and we have him convinced to buy a 914.
We are going to try and do a Subaru six conversion on it starting next week and have it ready to drive to the RRC.
There maybe 4 water cooled outlaws coming from our Hood. Lol
A&P Mech
Aug 4 2016, 09:33 PM
Well it has been about a week since I have drilled any new holes in my car. I was starting to have withdrawals so out to the garage I went. I pulled the fuel tank and got to work installing a swaybar. I was able to get all the holes located and drilled this evening. I did spend a few minutes making a tool that would allow me to accurately locate and center punch the center clearance hole.
Click to view attachment Click to view attachment Click to view attachment I hope to finish it up tomorrow night. I still need to fabricate and weld one drop link U bracket. The drivers side has one but the passenger side doesn't?
76-914
Aug 4 2016, 09:58 PM
Looks good. You'll love the front sway bar. Are you welding that flange? Pulling the gas tank is painless now, huh? I can pull or re-install mine in 10 mins. I know Ross bought another 6 but are you going to a 6 as well or is your friend? .
EDIT:
A&P Mech
Aug 5 2016, 06:30 AM
Thank you for the birthday wishes!
I am really looking forward to the swaybar. From what I've read it really makes a big difference in handling.
I was able to purchase some 1" wide 0.125" steel strap from the local hardware store. It is about 0.025" thicker than the OEM U bracket but should work fine. I am planning to weld it on to the A arm, is that a bad idea? I am open to other solutions.
The fuel tank was definitely easier to remove then before. My electric fuel pump is pretty easy to get to now. I just pulled a fuel line and powered up the pump. It emptied the tank in about 2mins. My garage still smells like a petroleum refinery. The pump got 99% of fuel out but there always seems to be a little in the lines. It's a good thing that the war department is out of town this week! She might have declared war on me because of the smell. Haha.
I want to put a six in mine but not sure if I can get the funds reallocated right now. I'm still trying to get the purchase of new gauges approved.
914forme
Aug 5 2016, 07:57 AM
Kent was referring to the sway bar mount. to the body, not the U tabs. It is pretty thin metal there, and it is know to rip out with larger sway bars installed. In reality it should not matter, it is the sway bar binding in the bushings that causes this issue. Simple way is to make sure the business do not bind. I did this via free axial bearings, my sway bar has no binding what so ever.
For your suspension tabs, yes you can make them. I just ordered another set from Paragon the last time I got some stuff from then, a little more $$. I did not have to spend time bending a packet an aligning the holes.
A&P Mech
Aug 26 2016, 11:26 AM
Lookie what the nice guy in the brown truck delivered to the house yesterday!
Click to view attachment Click to view attachmentClick to view attachment
Chris H.
Aug 26 2016, 11:33 AM
You added your reflection to the glass???? WOW!
Just kidding. Looks awesome. You will love those. PM me with questions. What color night lighting did you go with?
A&P Mech
Aug 26 2016, 11:44 AM
It was so you could see my smiling face!
HAHA I went with the standard white lighting. I almost ordered the neon green dial faces. The wife talked me out of it.
I am sure I will have a few questions. I know that I will have to figure out the oil pressure thing. My ECU doesn't use it so I am wondering if I can just install the speed hut sender in place of the OEM unit? I think the threads maybe different.
Chris H.
Aug 26 2016, 12:01 PM
QUOTE(A&P Mech @ Aug 26 2016, 12:44 PM)
Oh I hear ya. You don't even want to install them they're so pretty.
Yes so I
assume the Subaru senders are pretty universal. You'll find an idiot low pressure light somewhere. I think those are 1/8 BSPT threads into the engine block. The Speedhut is 1/8 NPT. You need something like this to bridge the gap.
AdapterJust find one that clears everything. I THINK since you are running an aftermarket ECU you don't have to have the idiot list sender connected. Might want to verify that. If you want to keep both connected PM me and I will get you the part number for mine. I am running the stock ECU so I have both connected still.
EDIT: ABSOLUTELY DO NOT FORCE 1/8 NPT MALE THREADS INTO A 1/8 BSPT HOLE. I think you know this but for the benefit of all.
A&P Mech
Aug 26 2016, 12:08 PM
Chris you are amazing! I really appreciate all the help! I wish you and Kent could make the RRC. It would be a ton of fun to meet you guys!
I found this on amazon.
https://www.amazon.com/gp/product/B00NWZ3TU...=A3Q5L29ROA0I31If the speedhut gauge doesn't need the OEM sender, I will just remove it. Thoughts?
Chris H.
Aug 26 2016, 12:20 PM
No problem. Plenty of people have helped me!
Yeah that looks right! It's the ECU that you need to verify does/does not require an oil pressure connection. I can tell you the Speedhut gauge doesn't need both. If you want a low pressure warning light you set that up yourself just by saying "when pressure gets to X turn the little orange light on". The question is, is the current sender hooked up to the wiring harness now and is the Stinger reading it? Does it care if you take it out? Doubt it since all it will tell you is whether the pressure is VERY low or not.
So whichever one you end up with, the critical thing is, screw that adapter in to the block VERY easily and slowly. That is brass and you are screwing it into aluminum. That way you know it fits and that it's perfectly straight.
Yeah I'm gonna get to more events someday. It would be great to meet more of you guys.
Chris H.
Aug 26 2016, 12:27 PM
Wait...if you end up needing to keep the stock sender you can just find one like the one on e-bay. It has both 1/8 BSPT and 1/8 NPT female threads. I missed that. BTW the fuel gauge works with the stock sender but you have to program it manually. You have to run the tank DRY to get a perfect empty reading and then fill it full before it will read right. Other than that it's all pretty easy.
A&P Mech
Aug 26 2016, 12:30 PM
I was going to ask you about that. I was thinking about pulling the fuel tank sender out to program it. I am assuming you could just move the float by hand?
A&P Mech
Aug 26 2016, 12:32 PM
Also, did you remove a bunch of wiring for the stock gauge lights?
Chris H.
Aug 26 2016, 12:39 PM
QUOTE(A&P Mech @ Aug 26 2016, 01:30 PM)
Well yeah if you want to do it the EASY WAY
. Didn't even think of that.
And yes you only need a few connections for the lights, not...what is it...15? like the stock gauges. You can tape off or (gasp) cut the end of the harness wherever so it can be easily reattached if you want to revert back (which you won't). Also you can put the dimmer for the light faces where the stock speedo reset knob under the dash used to be
. Perfect fit. You'll see what I mean.
914forme
Aug 26 2016, 12:42 PM
The sender is inside a tube,but all you have to do if it is working properly is turn it upside down. It is not hard to get into the sender though to clean it up and do a little R&R. Of course I did not learn mine was stuck until I ran out of fuel.
A&P Mech
Sweet! Love the dimmer idea! Well it may make the 914 purist cringe but I have been cutting on this car from the start no stopping now.
So if you have a weak stomach for that sort of thing you might want to tune out for the the next update.
A&P Mech
Aug 26 2016, 12:48 PM
QUOTE(914forme @ Aug 26 2016, 12:42 PM)
Great idea. I guess that whole gravity thing was eluding me. Noted!!! for some reason my car runs out of gas when the current reserve light comes on and the gauge is reading a 1/4 tank. I will do some investigating when I have the sender out.
76-914
Aug 26 2016, 05:08 PM
[quote name='Chris H.' date='Aug 26 2016, 11:01 AM' post='2390471']
Wait a minute. There's an idiot list? Will you check to see if me or Elyut is on that?
Chris H.
Aug 26 2016, 07:17 PM
LOL I meant light. I'm near the top of the former list
A&P Mech
Sep 5 2016, 05:45 PM
I spent the entire weekend working on the car.
I was able to knock some big items of the "to do" list. The heated seat and the SpeedHut gauges are installed and working. I also completed the center console. My hazard lights were blowing the fuse everytime the switch was pulled to the on position. It turns out the contacts for the light bulb were shorted inside the knob. It is now sorted out and functional.
A&P Mech
Sep 5 2016, 05:46 PM
A&P Mech
Sep 5 2016, 05:48 PM
A&P Mech
Sep 5 2016, 06:02 PM
The SpeedHut gauges I ordered were 4" for the quad, speedometer and a 4.5" tach. They were smaller than the OEM gauges and I didn't like the way they fit in the stock panel. So, I decided to do a little cutting
to achieve a better fit. I cut the back off the OEM panel to allow for a piece of aluminum to be placed behind it. After a little time on the mill "Presto" a better fit.
Click to view attachmentClick to view attachment Click to view attachment Click to view attachment
Sep 5 2016, 06:11 PM
Nice job!
A&P Mech
Sep 5 2016, 07:11 PM
Thanks!
matthepcat
Sep 5 2016, 07:18 PM
Love your center console and shifter set up. Looks great.
I had a set of those gauges on my last two cars. Love them.
