Well long time no update. Lets see, a whole bunch of life got in the way.
Trip to Portland ended in a ride to the ER, but I caused our plane to get emergency clearance, and we arrived 30 minutes earlier than we should, way to turn up the wick.
Spent the next month trying to get clearance to drive again, that was no fun.
I am back to driving, all my doctor visits have found nothing, I am in prime condition except all the crap I all ready knew was an issue.
Thanksgiving, Christmas, Chanukah, Winter Solstice, etc.... Any excuse to not work on the car....
But the 914 got some progress despite all my efforts to keep me out of the work shop.
No outside services used yet, lots of parts and ideas being tossed around in my head. And yes I am still screwing around with the back bumper, rear trunk area.
But first things first some of the parts my 914 picked up.
These will replace my Cobie Z beams, and Cobie driving lights.
Yep Truck Lite 7" LEDs
Click to view attachmentNice Light pattern
Click to view attachmentThen I also had an idea, so I ordered up one of these:
Click to view attachmentHarley LED passing light, also by Truck Light
Light pattern not as nice but still adds some to fill in the dark spots, I hope.
Click to view attachmentAnd here is my idea, stock location.
Stock fog light for comparison.
Click to view attachmentAnd now the Truck Lite unit
Click to view attachmentNow to figure out how to mount this things, nothing screams hey you can mount from here, and the instructions, are well nonexistent.
Click to view attachmentYou would think them little white plugs would work as a mount, but they don't seem to wanna come out.
Need to do some research on the Harley forums
I also ordered a second one, so you all can go out and order to yours, as I have the stock I need for the build.
Fellow member asked about my 914-RS lights, and if I was going to use them in my build, and I said, I'm not sure. With adding backup lights, it is a road car, the extra weight might make it not worth the efforts.
So I decided to weigh them against stock.
Stock is 1 pound 14.4 ounces
Click to view attachmentRS alone is 1 pound 0.4 ounces for a savings of 14 ounces. Or a total savings of 1 pound 12 ounces for the pair.
With backup lights I pickup an extra 2 ounces or 4 ounces total. Meaning I save 1 pound 4 ounces on the pair.
Yes every little bit helps so lets look at light output.
Running light
Click to view attachmentTurn signal
Click to view attachmentBrake Light
Click to view attachmentLong to the short, I have sold the RS lights, contacted Spoke about the Group Buy, waiting on the next round, and I ordered a set of euro rear lenses from AA.
George out of stock
I should have know, I am on the hunt for euro lenses now.
Done plying with lights, of crap I am not. Rear Fog, well now rear DLR / Fog. It forced me to make a decision, I will not be running the rear valance, I had been thinking about it, but now I won't have not run it since I owned the car. So where to put this, it needs to be low and on the drivers rear side. And I don't like the factory box.
So out cones this. Two modes DLR / and Fog/Brake A zener diode will allow both to function with out flashing the front fog lights when I hit the brakes. Or the other way around, in reality it will take two zeners.
Click to view attachmentThis is the bracket made to hold it.
Click to view attachmentAnd this is it being fitted up
Click to view attachmentDLR mode
Click to view attachmentFog / Brake Mode
Click to view attachmentWow camera does not show a difference in light output.
And after 2 days for
it looks like this. We need a grinder emoji
Click to view attachmentI will most likely have another few days worth of work cleaning up that bumper. Need to strip all the old filler,
the dents out, and then epoxy prime, fill whats needs filled, epoxy prime/ seal, then primer, sand,primer, sand, on and on.
I am no Metal Surgeon thats for sure, but I am learning a lot, in the process.
What is next for the bumper
A plug for the trailer wiring, waiting on a step bit that goes to 1-3/8 of an inch.
Bumper tops, waiting on 914Rubber to get the kinks worked out on the fiberglass bumper tops, been waiting a long time for these.
And then into the trunk, and finish welding the trailer hitch, plug up all the holes I no longer need. Finish the shock mounts, waiting on my counter sink bit to show up for that. And building a mount for the trailer light conversion box. So back to the shop today, to makes some more progress, hope to get 3 more days out there this week.
