Well I had a Blau 80 mm cap, but I decided I would sell it, it was not going through the hood, but my hood will have a door, so I need something to grab ahold of.
So I knocked this out.
Click to view attachmentInstalled on the tank, temporarily.
Click to view attachmentThen I started working on the oil thermostat, got a new one in. Never found my old one.
Click to view attachmentAnd I ran out of the proper length bolts to make my studs.
Then I started working on my new engine stand to get the mockup unit under the car while the car is still on the rotisserie.
So Like most things I over thought it. Started cutting metal to make a motor rotisserie. Then I figured out for what I needed todo in the near future, a drivetrain rotisserie is just over kill. Latter, it will make sense maybe, but I doubt it. So I put all the metal back in the bin, and built it out of wood.
So you can see it was a success!! The engine is in, to allow me to start working on the new engine mount.
Click to view attachmentClearance to the front firewall
Click to view attachmentClearance on the drivers side
Click to view attachmentClearance on the passenger side, -4 motor mount is still in there. need to get the
and get that out of there.
Click to view attachmentHere was the reason I needed to modify that cart. The leg on the rotisserie gets in the way. Engine is support the tranny makes it tip backward, so I have a ratchet strap on the front to keep things where they belong.
Click to view attachmentDown and dirty engine cart a few 2x4s a scrap 2x12 and a few screws.
Click to view attachmentToday I ordered a few parts from the land down under, them Aussies have all the
stuff.
And I calculated my fuel pump requirements, I need at minimum 190lph for E85. and looking at the 914 tank, I realized you knuckle head, it has a baffle in it. As long as I can get the fuel pump pickup in that part of the tank, I will be golden. So I will keep the fuel filter before the injectors, I just won't be running the complicated setup, I have drawn out several times.
Worse case I drop a Holly Hydrant in the 914 sump just to make sure I am good.
Any one know where I can get some 1-3/8" green stripe or equivalent, in a larger roll, not sure how much I need? Wonder if I can get 1-1/4" to slip over the 1-3/8" inlet, some serious lube and muscles maybe.
I am open to suggestions
