Big injectors come fairly easy, I all ready have a set, forgot what car they came from. Nissan I think, well documented modification.
Bigger MAP is also an easy mod. Again a Nissan product.
Exhaust is the pain, and I contend it will only do you little good, because the cams are the limiting factor on this engine. You can spend the money for cams it will really bring this N/A engine up to mark. And yes the EG is built like a tank, 7 full Mains.
I read the write ups on the Green Car above. Not of Forrest's car. For me drivability is key. Low boast does put a bandaid on the cam issue. And as Scott says you got the room do something cool with it. A turbo also cuts down exhaust issues. Yes I have to build a custom header, that was already in the plans. That little spinning impeller helps knock out a lot of noise, which means I might be able to reduce muffler sizes and gain that all to critical item of space in the back of the 914. With the Subaru transmission space back their is still at a premium. And you loose the capability to use a larger Muffler like a 911 banana, or even sport style. at least on my car, even wit the engine being pushed forward as far as I could go.
Here is the key for me, I will do this in baby steps anyway. Stock EG3.3 with flipped manifold will go into the car. I will have all the lines ran for things like interceding, Larger Fuel, lines, and the like. Planning ahead. The basis for all the additions will be their, I can take my mockup engine and build it. Maybe as an N/A engine with Cams and all the tricks. 300HP N/A running on pump gas, or more on E85 would be a very nice 914 to drive around in, and especially on the auto-x. Do not want to get out of balance.
But you all know the power bug gets to people.
And once you have 225HP, you get used to it. So 300Hp seems like a good step, you get used to that. Pretty soon, your thinking this car needs 350, 400, 500, 650, 800, 1000.
It is a slippery slope I have been down many times.
I drive TDIs as my daily driver cars. The one before this one was an insane built car. Still got 45 mpg as the day was long. But in the end I had a tune so wild, my wife was scared to drive it. I could light them up in the first 3 gears. If I got stuck in stupid traffic, the thing was a bitch to drive stop and go. As it would load up. So you would have to build enough space to let it rev a little. Which meant I was laying 11s every time traffic started to flow. Not to mention, the huge puff I would leave behind. Made me look like I was a total ass of a driver with road rage issues. I was not, just trying to keep the car running correctly. That last iteration of Jetta TDI ran a custom Malone Tune, huge hybrid turbo,DC auto front intercooler, only one they built for a 6-speed TDI. European PD 150 intake parts, cams, and injectors etc. And a full 3" exhaust that was a straight pipe. Dinky on the build was only 245HP, with a TDI its all about torque, I was at almost 550 FtP with boast pooping up, at 35PSI. We cranked the boast up to 45 for a while. Car was dysfunctional! Don't even know the kind of power I was making at that point. EG temps where alarming though, so took it back down to 35.
I had all the stuff to do it correctly, full GLI suspension and brakes, Large tires, hurt my fuel milage, and a Perloguin LSD. A very stiff South Bend Clutch, that gave my left leg a work out. Great car, the drivability and the fact that a highly tuned car takes a lot of maintenance for a daily drive caused me to sell it. It was fun to take people for rides in, it really need to be AWD, and if VW group would bring an AWD TDI over in a Golf or Jeta, or even A3, I would be buying the first used one I could find.
See it every now and again, usual passing me. And think man I wish I had that car again. So my current one, love the car, wish I had GLI suspension and brakes, and Seats, but I will keep it at a sane level of tune. Once factory warranty is out the door, I'll add a Molone tune to it. And drive it with the little extra that gives me and be happy.
Yeah right
Tonight back to the mundane part of the build, making templates and cutting metal to fix the hell hole area. Maybe I'll get into so more fun, as I have to make a few mods to tunnel exist in the engine bay. Mine is solid, but I need to close up a few exists and add a few more entrances.
The lines running front to back are getting crazy.
Fuel x2
Water x2
A/C x2
Clutch
Brake
Battery
Electrical Harness
Engine Harness
Throttle Cable
Heater?
Intercooler x2
Cable Shifter
Missing anything?
