Click to view attachment Less radical than the two above,a slight widening of the flanks.The work required to modify the original doors is apparent.
It has a lift up rear section that mimics the 904's,though a separate trunk panel is built in.The shape is reminiscent of the 904's,the windscreen the only common part.
The slope of the frunklid is extended several inches,the latemodel's 'crunchbox' replicated in lightweight grp/abs/vinyl,and carries twin LED lamps.
Some metalwork is done to remove the doggles that receive the new bumper,twin cooler scoops integrated that are similar to the chromed potmetal/plastic of the early's.
All of the work of other's prior '914+904' versions,suffered from the lack of the original windscreen,a significant feature,and great looking on the 914's later mod shape.
Note the length of the roofline behind the sideglass,and how the green gasburner above is much longer,a more attractive iteration.
The cab-forward position of the glass is what makes the slope of the trailing roofline meet the trunk's top in a pleasing way.
Smoother through the air,less turbulence induced and a giant fan,pulling a low pressure beneath the car,an upflow,like the Hall CanAms.
With a wing above and behind the roof,spats and a scraper up front,a 20mph advantage for the hp available.
Stable at speed,the air controlled,the pressures managed to push the shape down,trying to be slick.
Inspired by the Unobtanium 914+904,an evolution of a shape,with a purpose.
With the wheelbase stretch,a longer engine/tx package can be installed without holing the firewall,a matter of 100-150mm.
A flat six would of course need little,if any extra space,a V8 of course could use the room,depending on the dimensions of the engine used.
The huge pillow of air trying to get under the nose is given a low drag place to go,into the tunnel located outside the inner door panel.
Separated from the flow under the belly,and given a good signal at the rear low pressure area.
The cross sectional area from the front to rear is a growing dimension,allowing great flow of cooling and aerodynamic smoothing air.
The room afforded,allows a robust cage,intrusion panels and rollup windows,very convenient.Tubular.
QUOTE(7TPorsh @ Feb 5 2016, 01:02 PM)
I love this! Needs Fuchs!
Here are your Five-Fuchs.
You spelled your name wrong!
