Yeah. A few years ago Hemming's Exotic Cars did a cover story on the 308GT4 as an economical way to get some Stallions. (edit:05/07/16)"A few years ago"19 actually. http://www.ebay.com/itm/November-1997-Euro...x8AAOxyVaBS1IHX Bertone did a great job of integrating 4 seats and mid design transversely.The marketing department not so good. Like the 914 the GT4 was shunned by the illuminati.Paul Frere did a R+T road test in Upper Michigan in '74 and loved the car. Click to view attachmentClick to view attachment
Now stuffing a 400i V12 longitudinally and a modern 6-7 spd tapshift would wake it up. The objective being to maintain the brand of the prancing horse.Add the turbos and water+nitromethane injection ..How fast?220MPH+ fer sure.
Couldn't find the thd,What sitename? Lower longer..starting to look like a Can-Am with a 914 house on top. Hey,it does have a Can-Am engine.+Turbos! The large vents under the trunk floor will allow the flow of the massive heat generated by the powerplant,feeding the low pressure area behind the car at speed.Turbulent air under the car is drawn out. The width here is about as extreme as it should get. Still possible to add GT flares of narrower dimension. The reverse light is in factory position,the lens is merely wider by the widening amount. Not the easy way this is.You would need a metal surgeon to hammer and dolly the added strips of sheetmetal.The shape of the trunkline rear of the targa defines the intersecting transverse curve.The beltline then is lower.Raising the trunkline would help a lot,giving a humpier,bulging curve to the rear top quarter,sorto like the latemodel Aston-Martins. The focal length of the camera used foreshortens the image making it tricky to accurately sketch.
So..to shape some foam you first must use adhesive to attach it to the fenders. Then use the above methods the achieve the shape you desire. Modern epoxies and clothes are more suitable for insulation type polystyrene. If you are making your own mudgards(flares) it's possible to design,fabricate a unique look for your 914. At some point in the work-up to the LeMan '70 someone cut a washtub in half at the factory and said "yeah,that'll work". Don't get me wrong.I like the look,they were the solution of the day for the fat wheeled Porsches,the 911 too. The colour is very close to my own selection.
As you observe various auto designs,are you able to perceive rust and dents from a distance of 100 yds? Sure,so it is entirely possible to detect the shape of the fenders of a 911RSR. Expedient measures to cover the tires range from this to the shapely splined flanks of the 914. The necessity drive the invention.
Click to view attachment nice crank.corvair aero app they are able to do -8's to similar specs 2K?+
Lol! Hey, that's my LE saved only days before the PO was going to have it crushed! It's stored in my garage until I can do a full on roto resto :-) Cool what you did, but it'll be bone stock concourse when completed (years from now, lol)
veekry9
Apr 20 2014, 01:53 PM
Another Save!RestorationDesign has the sheetmetal replacements you desire. A tall task on the horizon,requiring stamina and fortitude.Never give up,never surrender(Wittwickie).A polished gem at the end,close to perfection,reflecting.
Thanks bulitt. OK,so,you need a Wider Fender...Note to self,drive-ability makes good parts.
Click to view attachment A raised trunkline,taller from the trunk floor. Wider lens + taller too.Starting to look like 944/968/928 pieces,fitting really,that the parts would serve a similar purpose.
Click to view attachment How bout now?3" stretch behind the targa curve. Two tone anodized Fuchs 4-stud.A bronze/titanium,rim polished. Polished alloy or chromed outer rocker. LED aero turn indicator.(spoke?) If you measure your door thickness add 3-4" for this result. I can add the front fender vent and the engine oil cooler scoop as well as an intrusion barrier/cage bar with the extra width.Form follows funktion.
Click to view attachment The larger tail-lamps remove any semblance to 914 and move into the 924 family. An exercise in fitting the rads/intercoolers amidships,without adding lumps. 17" and low profile tires fit the enlarged w-wells in a modern way. A '66 Mustang is showing its influence,difference being the vents are functional. This will be a long time coming,a ton of work.
veekry9
Jun 4 2014, 10:56 PM
Click to view attachment into the realm of a full custom Click to view attachment Some details to be determined..without the 3"stretch.Navy Targa Vinyl. I recall one of the early "models in clay" sported headlamps of similar shape. Mid mounted coolers do two things,eliminate long lines and retain a centralized cg. Not really 914+944,or change for changes sake,more like what if? In '67 a pencil and plasticine was used.
While you are designing , why not spring for some cool 911 headlight treatments , maybe some of the MB headlight setups to the turn signal locations ??? Do away with the flip ups , relocate the turn signals to another location ??? I've always wanted to install 911 headlights in that spot , just have to do some creative fab work , but with thesee fender widening on these pics it would be very doable , but however it's your project not mine , good luck to ya !!!
Jack
veekry9
Jun 5 2014, 11:53 AM
Always thought this was interesting....
Very Neat,I haven't seen that treatment before now. At the time,the 'new"designers were transitioning away from the "headlamp sponson"look that had prevailed for the previous 20 yrs. Hence the truncated headlamp turnsignal of the 914. We enjoy the look today,but in '69, it was like,so different. The simplicity of the slab-sided spline curves provide a surface on which to sculpt some detail,to make room for coolers and larger rubber.
veekry9
Jun 5 2014, 12:16 PM
While you are designing , why not spring for some cool 911 headlight treatments...
Yeah,the amount of time to make the changes to the shapes of the curves has been reduced electronically.To bang metal requires the traditional amount. I've considered a number of headlamp designs,and really like the clearlense 914 HID look a member here has done.(edit:05/03/15 neo914-6) As I go further,I am becoming more inclined toward a Boxster trioval shape.I agree the flip-ups now look more redundant. A work in progress,although the raised trunk-line does it for me,transforming the 914's simple splinecurves into an aggressive look that appeals with the massive airscoops. The GIMP software allows fast work in concept visualization. http://en.wikipedia.org/wiki/GIMP http://www.gimp.org/downloads/ /
worn
Jun 5 2014, 12:45 PM
QUOTE(sixnotfour @ Oct 21 2013, 05:43 PM)
Why on earth would you bother with a push rod engine ??
I believe that is a quote from Ferrari to Henry Ford. Before the race.
veekry9
Jun 5 2014, 01:11 PM
QUOTE(worn @ Jun 5 2014, 02:45 PM)
Yeah,the pushrod has been touted as primitive,do they still make them? Yup.
veekry9
Aug 20 2014, 06:40 PM
Found today.. I've not seen this here. Click to view attachment It even has side inlets, the wheelarches look unique enough. All that's missing is a proper targa bar. 2008 model showcar. Does this appeal to any 914 owners?
Thnks MovQuik I guess it is the gulf colours that suit the front fender treatment. The top chop is well done,the cage is closely fitted. yup,does it for me,very nice rendition.
Get 2 engines,cut and rejoin to build a bigger better engine of your dreams. What could you do with a 9L 90* Ford V-12? What could you do with a 4-5L 32 valve flat-8?
Q However, Tatra came up with some very special concepts and innovations under the hood as well. Which technical details were most significant? Ivan Margolius: The lightweight air-cooled rear engines V8 and flat 4, swiveling headlights, swing axles, forced fan-assisted cooling and flat undersides. Q
Haven't looked into the aftermarket for these engines,if it exists.
Click to view attachment Incredibly,snuggled into the behind. So yeah,with some careful measurement and mods,one could slip right in to your 914,smoothly.
Huge history! I remember seeing Dubcek and Svoboda cruising around Praha and Bratislava in 603! And then in the 70's them orders 613 model. Only the party big wigs got to be driven in those cars. Ahhh, great memories of the utopian socialism of CSSR and CCCP! And the pivo! Don't forget the pivo!
Come to think of it,those highpressure dies quite likely still exist. The entire GM Corvair production diesets were scrapped in the 70's. But things are done differently there,as the dies are of great value,even now.
Do you see anything you like?An alloy aircooled v8 of aircraft design philosophy. Lightweight,compact,easily manufactured,similar in design to the vw and corvair. hemi design canted valve in pushrod and dohc configuration,sophisticated.
By raising the camshaft far above the crank in the valley,the rocker geometry for the exhaust valve is improved,perhaps making possible the use of common rockers throughout. Note the hemi-like chamber and wide angle canted valves.Like the VW/Porsche and Corvair,the bore diameter is restricted by the cylinder head studs. A considerable amount of weight savings would be realized by adopting LN cylinders. I believe the crank is a conventional cross plane and at a small 72mm stroke,there may be plenty of room for a much larger stroker.
Anyone onboard able to translate his spoken words? Looks like an interesting project,a diesel conversion. / Tatra 613 unfinished project - Diesel. Unique project of rebuilding the engine T613 (aggregate) on diesel variant. At the end of the 70th century originated minuléto years so far unique project for rebuilding the engine on the T613 diesel engine with direct fuel injection into the cylinder. As a base engine was used T613 (model E) production year 1977, which had traveled 20 thousand. km. The creation of new pistons with a semicircular shape of the bottom of the piston has been redesigned combustion chamber cylinder heads were modified cabinets cam engine was devised to drive fuel injectors, all this was preceded by a complex formulation of models later casts, followed by manufacture themselves cast as pistons and various components, from which the formed parts for driving the injection pumps, produced with a special injector, it was necessary to devise and make special threaded shaft for installation into enclosures injectors cams and cylinder heads. further information only serious and technically savvy candidates. This project is a testament to immense creativity and skill of the Moravian-wise and because the owner of this concept does not want to make this engine ended up in scrap, looking for this very technical and design an efficient, technologically savvy real enthusiasts Tatrovaks heart for engines Tatra, which this project dotáhnul to successful end. The owner of both the engine and the entire project, originator of the idea itself is ready to provide serious, but it really only serious candidates all technical and knowledge support to complete this project successfully. The owner, however, asks dealers and speculators, who, on this project, they just want to earn without it without touching anything, so this video in any way responded.
P.S. The video is mistakenly stated that the year of manufacture of the engine is 1997 correctly's 1,977th /
