Click to view attachment Yes.
250LM=914-8,a comparison I never considered,because it's ludicrous,as demonstrated above.
Pretty extreme concept,huh?This one is the Stratos glass,the roofline of the 914,lowered to meet the top of it.~50mm.
The A pillar is closely matched to the Stratos glass's trailing edge,changed to meet the taper to the top.
After all,many a 914 windshield is damaged,as is the chassis.A derelict rusted varmint nest,in a field,free.
Some consider the 914's bare bones as a starting point,a basic map on which to draw a path to a nirvana of one's preference.
The chassis,when lowered from the standard ride height,makes for altered suspension geometry,nasty at the edge.
Chopping,channeling,lengthening,bigblock,turbo,lpg,nitromethane,lakes,and more.
This is the pix,leave your preconceptions and dogmas behind when you enter here.Open your mind,start the Reactor.
Kick an idea or two,one of your own,that you made yourself,or not.
Original 250s
You know if you belong. If you don't,we'll tell you.
17M
