trojanhorsepower
Oct 1 2015, 07:49 PM
QUOTE(r_towle @ Oct 1 2015, 09:44 PM)
Keep those doors in place now as you do the rest of the welding to know when and if you do something wrong with those rear fenders and sills
Thanks for the tip! I know I still have a long way to go, but it is fun to see it with a door on.
914forme
Oct 1 2015, 08:32 PM
Just read thru the entire post, that is some great work, and dedication. Makes some of my patches look like I did them in kindergarten.
Olympic 914
Oct 2 2015, 10:38 AM
QUOTE(trojanhorsepower @ Jul 12 2015, 03:34 PM)
Also got the little seat adjuster bracket that welds to the cross member. Slowly moving forward, very slowly.
I used the seat mount to locate the hinge parts that weld to the floor. After I broke one off trying to loosen it up.
Looks good. wish I could weld like that...
trojanhorsepower
Oct 2 2015, 11:22 AM
Thanks Guys,
It is a learning experence and I could not have gotten here with out Doug's help.
trojanhorsepower
Oct 4 2015, 09:19 AM
Worked on prepping the rear quarter to test fit with door.
trojanhorsepower
Oct 4 2015, 09:24 AM
Got it all ready and test fit.
Wah wah
This is not good. The measurements seem OK, so maybe some fiddling and I can make it work. If not I will be the first competitor out.
So far staring at it has not helped......
trojanhorsepower
Oct 4 2015, 06:27 PM
It's weird, but I put the old quarter on and it fit OK, not perfect, but the door will close. I wonder if this means that the new quarter can be made to fit?
JoeDees
Oct 5 2015, 07:50 AM
For some reason it is reminding me of the time I helped replace the doglegs on a VW bus. We absolutely couldn't get the door to fit right. Double check your prepwork where it sits and make sure the quarter is sitting flush. Is it warped from removal maybe?
I definitely don't think you're done. I'm betting and hoping it's something fairly simple.
trojanhorsepower
Oct 5 2015, 07:38 PM
Well, I figured I should press on while I think about this fender issue. I have been picking away at the small spots that remain. Got most of the spots on the front end worked fixed, but will have to add after pics tomorrow.
cary
Oct 6 2015, 06:43 AM
Subscribe
trojanhorsepower
Oct 6 2015, 07:05 PM
More pics of the weather stripping repairs.
Still some more work to do, but it was not as bad as I though it would be.
trojanhorsepower
Oct 10 2015, 07:27 PM
Got some more done today, but no pics. I will add some soon.
I have (I think) finished the patching on the front end.
I fiddled with the replacement fender and found that it was hanging a little on the fresh air vent in the door jam. I trimmed a little more and got it to fit, so I am going ahead with the build. I may end up shaving the door a little, but at this point I am confident that I can make one of the fenders work.
So, on to the back end. All I have done here is scour out the seam sealer from around the plug. I also found more rust!
Oh well it looks manageable.
trojanhorsepower
Oct 12 2015, 07:53 PM
Took some time this weekend to pull out some more seam sealer.
trojanhorsepower
Oct 12 2015, 07:55 PM
Started on the rear trunk pan.
trojanhorsepower
Oct 12 2015, 08:03 PM
So my patch panel does not have the threaded hole seen in the last picture at about 12:05. What is this for?
Chris H.
Oct 12 2015, 11:05 PM
Spare tire tie down? There is a threaded hole in the rear trunk that allows you to mount the spare tire.
trojanhorsepower
Oct 29 2015, 07:15 PM
How does this joint come apart?
914forme
Oct 30 2015, 12:28 PM
Click to view attachment Remove this screw (Blue Arrow)
Pull Cap off (Red Arrow)
Pull Swap bar out (Green Arrow) {Optional Step in Reality, I do it to check them}
Pull Arm (Pinkish Purplish arrow)
Hope that helps
trojanhorsepower
Oct 30 2015, 06:53 PM
Thanks Stephen,
I would not have guessed that was all that holds it together. What about the cap on the other end of the a arm? Does it just slide off as well?
cary
Oct 30 2015, 10:01 PM
Some where I read you finish those repairs with JB Weld. I used it on my white car.
Makes a nice smooth channel to install the new seal in.
914forme
Oct 31 2015, 07:42 AM
QUOTE(trojanhorsepower @ Oct 30 2015, 08:53 PM)
Thanks Stephen,
Never tried to take one off.
Now if you are talking bushing mount here the two bolts go in. Slides off with a twisting motion. Or mounting it in a vice, and
out of it, unit it gives while you expand you one syllable vocabulary
Some of us old school guys just lit them on fire, and they burn out. If you go that method do not burn them on your driveway. It leaves quit a mess, S.O. might not like said mess.
trojanhorsepower
Nov 18 2015, 08:37 PM
I have gotten a lot of the front suspension bits apart, but decided to switch tracks until I can locate some blast media. So November is paint removal month. I am stripping as much paint as possible to make it cheaper to blast.
Click to view attachment Click to view attachment Note the rust under good paint.
Click to view attachmentTop side all done.
trojanhorsepower
Nov 18 2015, 08:45 PM
trojanhorsepower
Nov 18 2015, 08:57 PM
So I finished stripping the doors:
Click to view attachment Click to view attachment The drivers door is toast, but Doug has a spare for me so I am going to use it to practice. Got a new toy:
Click to view attachment and I started playing with dents.
Click to view attachment I still have a lot to learn, but with this car I will get plenty of practice
wait wait
trojanhorsepower
Nov 18 2015, 09:08 PM
For a change of pace I started cleaning up the replacement light panel:
Click to view attachment And guess what??
Click to view attachment Click to view attachmentClick to view attachmentNo way! More Rust!!
76-914
Nov 19 2015, 08:50 AM
trojanhorsepower
Nov 29 2015, 02:11 PM
Did some more paint removal..bondo removal.
Click to view attachment Click to view attachmentClick to view attachment. This panel has lots of damage but I guess I will try to save it, but it is probably beyond my extremely limited skill.
trojanhorsepower
Nov 29 2015, 02:14 PM
trojanhorsepower
Nov 29 2015, 02:19 PM
OK. I know this seams random, but given the way these panels interact they have to go on at the same time. While I was working on the quarter panel had to cut out a wad of rust that was a bolt. Here:
Click to view attachment Does anyone know what this nut should be? BTW that is a picture of the pass quarter upside down, where the sail panel moves into the rear truck seal channel.
trojanhorsepower
Jan 24 2016, 09:12 PM
I hate to say it, but not been making any progress lately. Weather, holidays... Just doing paint removal when I can do anything.
trojanhorsepower
Feb 21 2016, 06:11 PM
At last an actual update. We had some warmer weather this weekend and I was able to open up the shop and work some metal. I started on Saturday by removing the old bashed up taillight panel.
Click to view attachment Then I started cleaning up the area that goes under the brace inside the trunk.
trojanhorsepower
Feb 21 2016, 06:21 PM
OK there should only be one copy of the first photo, not sure what I did there.
Anyway.... I also started fixing up the replacement panel (salvaged from DLeehr). It is a little rough, but better than the one I had. I was able to salvage some of the parts off mine to patch this one.
Click to view attachmentClick to view attachment Click to view attachmentClick to view attachment Click to view attachmentI have several other small spots to work on, but that was the worst of it.
trojanhorsepower
Feb 21 2016, 06:30 PM
I also had to redo the drivers side rear corner where there was Rust! I know you are all shocked. But this was not just rust, this was rust and a accident repair, with brazing!
Click to view attachment Click to view attachment Click to view attachment The inside trunk corner was the worst. But after lots of little patches it came out OK.
trojanhorsepower
Feb 21 2016, 06:33 PM
So next on the list is to finish repairing the repair panel and install it. Then I need to finish the drivers side corner. Then maybe I can get my trunk floor panel installed.
trojanhorsepower
Mar 20 2016, 05:53 PM
Finished the rear trunk. I still have to add the muffler shield, but won't do that for a while.
trojanhorsepower
Mar 20 2016, 05:54 PM
Taillight panel Mostly welded in.
trojanhorsepower
Mar 20 2016, 06:00 PM
Now for a major problem. My original quarter is pretty rough, and thinking I would replace it I was not gentle when I took it apart.
Click to view attachmentI got a replacement from Doug, but it seems to fit worse than my original.
Click to view attachment Click to view attachment Both quarters are tight at the bottom, but the replacement panel is worse. The biggest problem with the replacement is the fact that the bottoms don't line up.
Please give me your suggestions and tips. I can weld the best of the two quarters together, but it may not be better than using one or the other.
trojanhorsepower
May 12 2016, 05:45 PM
Suggestion... Ideas???
dlee6204
May 12 2016, 06:17 PM
Curious, do you have a gap at the top? From the last picture you posted it doesn't look like the door is all the way closed?
Garland
May 12 2016, 06:34 PM
QUOTE(trojanhorsepower @ Nov 29 2015, 02:19 PM)
OK. I know this seams random, but given the way these panels interact.
I think your rusty bolt was the tab with stud, that mounts the bottom of the vertical sail trim, to the sail. Here's a shot of the interaction your speaking of.
And one of the hole for the tab. And tab.
Click to view attachmentClick to view attachmentClick to view attachmentYour build is looking good.
Garland
May 12 2016, 06:41 PM
After review, I think I'm way off on the location of that rusty bolt. In that last post.
trojanhorsepower
May 12 2016, 07:19 PM
Thanks guys!
The gap at the top is not terrible, but bigger than I think it should be. Not that that means anything. The door will not close without forcing it. That said it is not so bad that you cant easily force it to close. It hits in lower corner as pictured and at the latch striker.
trojanhorsepower
May 30 2016, 07:01 PM
Well Doug L. came over and saved the day!
We got the fender realigned. I then had to take it off and beat out some dings and weld up some holes. Any way, onto final fitament. I am screwing the quarter into place. Now I will add the rear deck lid and align it to weld in the hing points. Then I plan to start the welds on the quarter.
trojanhorsepower
May 30 2016, 07:02 PM
Oh yeah, I got the jack point welded on to.
trojanhorsepower
Jul 19 2016, 04:20 PM
Well whiles't I dither, I decided to work on the brakes. I found a few issues:
Click to view attachmentClick to view attachmentClick to view attachmentBoth of my adjuster studs have this thread broken off. I guess that is where the lock nut sits.
trojanhorsepower
Jul 19 2016, 04:21 PM
I am ashamed to say I did this one myself:
Click to view attachment Is it still usable?
trojanhorsepower
Jul 19 2016, 04:26 PM
The master cylinder dose not look too good.
Click to view attachment I was thinking about rebuilding, but I bet it is pitted. Is there a reason not to open it up? I would like to have it for a core if necessary, so if taking it apart means PMB won't want it, I will leave it alone.
trojanhorsepower
Jul 19 2016, 04:27 PM
One more for today. Does anyone know what these are for? I found them in with my brake bits:
trojanhorsepower
Jul 19 2016, 05:58 PM
Deleted
Andyrew
Jul 19 2016, 06:28 PM
QUOTE(trojanhorsepower @ Jul 19 2016, 03:27 PM)
Click to view attachmentLooks like brake pad retainer pins.
