QUOTE(The Cabinetmaker @ May 19 2016, 09:26 AM)
QUOTE(nathansnathan @ May 19 2016, 09:41 AM)
It's always seemed to me that people buying a Raby motor would be setting themselves up for some disappointment. To think you'd get all this performance and reliability from just a long block.
To get the potential from it involves not just the motor but also fuel delivery, the exhaust, and the tuning. The engine may be built with the best components, made to last, balanced internally, but if you're running like baby webers and a 009 I don't think it's going to be a screamer. There's so much to be gained from tuning, and it's so rare to see peoples 914's and buses really purr... Just properly synching carbs, not running too rich, running enough advance, there is a lot of performance to be gleaned from a stock long block.
These are my thoughts when I see people running a single progressive carb saying they'd never pay that much for a motor. ...well yeah, would be pointless with that stuff bolted to it.
I think Jake's engines come complete.
It used to be better documented what you got with the motor, along with a pic and it looked like a long block. I don't recall it ever seeing the carbs listed.. I see on the site it says it comes with everything but exhaust. I would like to know, not that I'm gonna sign up, but that would help justify the cost to have intake manifolds (csp?), linkage, air filter setup. I do think he has the tin blasted and powder coated with that price which is a significant service.
Let me make a rough list of things. Some maybe high, assuming that the good stuff is being used I could spend this much, or like a padded price to rflect expertise in performing whatever/ being a one stop shop. Other things maybe I'm way off on, just speculating here.
1500 new heads
700 rework heads
300 p&c, maybe rings separate
1000 Align bore case, bearings, rebush conn rods, weld thrust etc
200 type 1 oil pump and cover, modified, peened, blueprinted(?)
350 cam and lifters
1200 carb setup with intake manifolds, air filters and linkage
1000 tin blast and powder coat
500 replace stuff that's missing/broken/worn out (thermostat, messed up tin, various hard-to-find seals brackets etc)
500 fuel pump, regulator, hose, gaskets
500 setup valve geometry, custom length pushrods
500 dyno tune
500 edit clutch package I forgot
I come up with 8750. I can see how that could be like padded to 10k. 20k, I don't know.
