Epic in many ways....the work, the move and change in life, the results so far, etc. Nice work.
aggiezig
Feb 6 2019, 02:13 AM
Thanks for the feedback, everyone. I would love to meet up with some of you SoCal folk one of these days soon. I'm going to try and make it to the show in El Segundo this March. I was hoping to meet some people at the PCA show in the valley this last Sunday but it was rained out (so did the VW show at Santa Monica Pier).
Man, time just keeps flying by. Small update this time, just pecking away at little projects when I get a few minutes here and there. Color sanding and buffing has taken way more time then I ever imagined. Once I knock out the paint correction, my goal is to finish up controls and all the other mechanicals.
I did manage to get the engine and transmission back out of the car so that I can install a new pressure plate, clutch and throw out bearing. I am not in love with the look of the transmission and contemplating painting it with some high-temp aluminum paint. Will see if I can muster the motivation. If it ain't broke…
I reassembled the headlight buckets (without bulbs yet, thinking LEDs) using powder coated and re-plated hardware. I had the chrome bezels coated satin black and the framework a gloss gray. The original plastic housings cleaned up really well with a coat of CQuartz Dlux ceramic. I think I will try to save as many original plastic pieces this way instead of using plastic paint.
Also rebuilt the door catch mechanisms with original re-plated parts and rebuild kits from 914rubber. Top is before, bottom is after.
Seat tracks and bases were rebuilt with re-plated and powder coated hardware. Seat bases were rebuilt with a kit from 914rubber, although I had to drill out a couple of holes to make their included roll pins work in my cast pieces. I think I have the release handles installed the wrong way here in this pic.
Installed knock off dynamat from Noico. I bought this stuff on amazon a few years ago for another project and it never got used so I decided to roll it out for the 914. Instead of covering every square inch, I'm trying to strategically place it in places with the most flex and / or resonance. The interior is pretty much complete and I plan to roll a strip under both trunk lids and also on the backside of the firewall.
But mostly, I've spent a lot of time color sanding and buffing the paint job. Everything is looking great for essentially a garage booth job. There are a few small imperfections that I know by heart but the average bystander would be hard pressed to point out without a detail light.
Unfortunately, I wasn't able to save the runs in the driver's side door and it will eventually need a re-spray. I sanded through the outermost layer of color trying to get the run to level out. I'm going to post another thread about it to see if I can get some advice from more experienced paint / body folks.
On an unrelated note, I came across a 914 at a dealership in Sherman Oaks the other day and had to stop and look at this '74 1.8L. I added it to the VIN database. Pretty clean car and gives me inspiration to finish mine out.
Lastly, some other car-related news. After relocating to the city, I was tired of bottoming out and scraping on these LA roads. So, I sold my extremely fun DD (2008 M3 6 speed) and joined another vehicle cult (Jeep Owners).
Sale Ad Pic:
The morning I said goodbye:
New (to me) ride:
That's all for now. I'm enjoying sunny SoCal and will try to keep you all posted more regularly!
Peashooter
Feb 6 2019, 08:38 AM
If you have enough, add a square of the sound deadener inside the doors on the outer skin. When you shut the doors, they will give a nice thunk.
bbrock
Feb 6 2019, 10:27 AM
Glad to see you've been plugging away at it Looking good.
You are right that you have the seat release lever on backwards. Also, I'm pretty sure the release handles go on the tunnel side of the seats.
I need to ask how you handled replating the tracks. I would really like to replate mine, but lost my nerve when it looked like rivets would need to be drilled out to take them apart.
Huge bummer about your color sanding. Hopefully you can get a good match on the resprayed panels.
aggiezig
Feb 6 2019, 08:30 PM
QUOTE(Peashooter @ Feb 6 2019, 09:38 AM)
This is a great idea but I have the "crash bars" inside my doors. I'll have to see if I can find some space for it, I have plenty of extra left over.
QUOTE(bbrock @ Feb 6 2019, 11:27 AM)
Thanks, Brent. I've been watching your thread whenever I need the inspiration to get out there and do some work.
On the tracks... I went ahead and drilled out the rivets. I replaced using pop-rivets and used roll pins for the pivots. Send me a PM if that's not clear and I'll shoot you some pics.
Yep, the color sanding issue really sucks. I'm putting it in the back of my mind for now and going to fix that dead last so that I can keep making progress. The hood is easy enough to bolt on and off and so is the door, thankfully.
aggiezig
Feb 24 2019, 11:57 PM
Well, I don't know about the rest of you, but it's been nasty and rainy here in SoCal for a few weeks. Folks around here keep telling me this kind of weather isn't normal and I do have to admit I miss the sunshine. At any rate, time for another small update! I'm chugging along with small stuff, trying to knock out paint correction so I can focus on other bits.
Window regulators were cleaned up, treated for rust and painted gloss black. You'll never see 'em but at least they'll be clean during reassembly. Does anyone know if you can buy replacement nylon rollers for these regulators?
Also decided to polish up the heat exchangers, only took about five minutes because they really weren't too bad. Used some fine steel wool then 2000 grit with WD40 to lube. Before on left, after right. Still need to paint the non-stainless pipes with some exhaust paint. I believe this is a 1.8L exhaust, not sure if I'll run with it or try and swap for a 2.0L.
Sprayed the stain black under the engine grilles with some SEM Trim Black. I think the finish is pretty spot on.
Spent some time wire wheeling the paint off of the transmission. The PO had sprayed it a dull gray and blue. Would like to just do a bright aluminum look.
Next up was the targa top. I decided to clean up the donor top I stole from a 72 a while back because it was in better shape than the original top from my car. Here is its state before refinishing.
First, I sanded everything down with 220 grit. I smoothed out all of the knicks and scratches along the edges by re-shaping the profiles. There was only one spot I decided to fill with a bit of putty. Here is after sanding:
After that, I sprayed 2-3 coats of raptor liner in black thinned about 15% with urethane reducer. I used one complete bottle with a tiny bit leftover. You can buy a single back on Amazon for about $40 and I think it's well worth it.
Bottom side sprayed first, did not completely spray where headliner glues
Close up of texture:
Lastly, here are some pictures of the paint correction. Everything is being color sanded down smooth to remove orange peel. Then correcting with Menzerna 400 heavy cut on a dual action (15mm throw) with a heavy cutting pad. The DA can take out the sanding scratches almost completely. If anything is left over, I can hit it with my rotary and wool pad. After cut is a polish with Menzerna Super Finish 3800. Then a pass with Meguairs #7 show car glaze. Then Menzerna power lock sealant and lastly some Collinite 845 insulator wax.
Here are the results:
Pretty happy with how it's turning out. Not perfect and truthfully the paint is probably an 8/10 but for a garage warrior and first-time painter it's not too bad.
Side note - stopped by Cars & Coffee this morning by Griffith Park. Lots of sweet rides, below are a few of my favorites.
Believe this is a member's ride, the car is in the VIN database
Alright, that's all for now! Hope you enjoyed reading
bbrock
Feb 26 2019, 12:17 AM
That roof came out really nice! I have to be honest, when I read you used Raptor, I wasn't expecting that good of a result. Nicely done.
Now as for your weather... you are welcome to come up here and enjoy -15F with a stiff east wind kicking snow in your face all day.
aggiezig
Apr 20 2020, 02:32 PM
Hello 914World!
Wow, it's been more than a year since my last update. I did not mean to leave you guys hanging. Life has certainly gotten in the way of my 914 restoration. Some quick, personal news - my wife and I tied the knot last July and my 914 made a big debut… well, sort of.
It was the next best thing to actually having the car at our wedding! The cake shop did a really great job.
Ok, now back to the real Porsche. I told myself that 2020 would be the year she is back on the road - and so far, it's looking good! While this COVID business has affected a lot of people, I will admit that I am loving the extra time I have to work on the car. Combining that along with a new wrenching buddy (my neighbor, who also has a p-car project) and I think my 2020 goal might just be attainable! Here are some updates since I last posted…
GENERAL UPDATES
I had a few more parts and pieces plated in yellow zinc:
Spent way too much money at 914Rubber:
Installed the pedal assembly and (loosely) steering column:
For anyone wondering, here's what my "shop" looks like. It's a 2 bay garage under our house. It was built in 1922 or so, meaning the size is pretty small and there's a line of support columns running down the middle. The ceiling has been "modified" with several botched plumbing repairs in the past and is about 7' tall (good thing I'm pretty short). But, for LA, this is a prized possession. I added some LED lights to the ceiling to see better. I sure do miss TX sized workspaces.
WIRING
I purchased a complete wiring harness kit for a 1972 & up deluxe VW beetle from Rebel Wire. As many of you know, the beetle and 914 of this era share many of the same electrical components. My intentions are to re-wire the car with this kit, modifying as necessary to incorporate factory and aftermarket pieces. I chose this kit because it uses "GM Style" wiring with separate fuses for each circuit. Additionally, it will have all new wire and they are labeled every 6". I'll document this process as I go for anyone else out there looking to do the same. For reference, the kit was around $300 and I'll have another $1-200 in supplies when I'm done. A lot less than a replacement harness and a lot safer with less mess.
TRANSMISSION
I painted the transmission silver and completed it with nice, refreshed goodies:
FUEL TANK
I finished the fuel tank with a new sender, refreshed wiring, fresh paint on the plastic and new seals:
I also added new metal lines and nuts for the bottom. I'm not using the return line with my carbs but didn't want to epoxy it shut or completely block it off in case of future need. There are a ton of rubber caps online but none seemed to be for certain fuel rated. So, this is my cheap fix. It works fine for me and allows future flexibility.
BRAKES
A new 914Rubber master cylinder was installed with re-plated/polished line fittings:
A rebuilt proportioning valve (PMB Performance) was installed and a rubber guard/grommet was added to the line after this picture:
I wasn't thrilled with the condition of my re-plated calipers as compared to the rest of the car. So, I broke down and splurged on rebuilt units from PMB Performance. They sure are pretty:
Rears installed:
Fronts installed: (I believe I have the clips in the right position, but correct me if I'm wrong)
ENGINE COMPARTMENT
I've spent a fair amount of time crawling in and out of the engine compartment over the last few months. Turns out, the space is just big enough to fit my rolling shop stool (ask me how I know). I wanted to button up as much as possible in here before putting the drivetrain back in place.
For whatever reason, this shift rod guide bushing was a total b*tch to get installed:
I followed @simonjb 's build as a guide for my fuel pump and filter:
I wired my fuel pump in with a relay that grounds through a crash circuit interrupter. I'm not sure that the placement is optimal, but the idea is that in the extremely unfortunate event of a crash, the fuel pump will be cut off. Also, I'm using a Miata sized AGM battery - need to fab up some sort of hold down still.
I purchased a new firewall pad from 914Rubber and it is installed in the pic below but not currently in the car. I'm having difficulty using any sort of velcro to attach it - nothing wants to stick to the backside of the pad. Does anyone have a suggestion for some very strong adhering tape? Additionally, the pad (in my case at least) needs to be trimmed for proper fitment as it is too tall and won't allow the decklid to properly close. Kind of bummed that such an expensive replacement requires modification to install but I understand this is an aftermarket replacement.
I finally got around to painting the piece that holds the decklid catch mechanism to the rear trunk firewall. For whatever reason, the PO had removed this on my car and I didn't realize it was missing until after paint. So, I sourced a replacement, painted it to match and used aluminum rivets to hold it in place. It's very strong and not going anywhere. Yes, you see the rivets in the trunk, but it's a pretty clean look overall for not being factory. I still have to fabricate a sleeve of some sort to hold the release cable in place because that, too, was missing from my car. I am thinking about using a nylon sleeve like the front trunk guide and using some clamps to hold it in place.
While I had the paint gun out, I also repaired the rear valence that had been chafed by the tie down straps I used when we trailered the car here two years ago. It's not perfect, but it's completely hidden by the bumper and I bet you can't tell where it was repaired in this picture:
We also sprayed my buddy's 944 front valence since we had some extra paint… This is his track car and will be repainted anyways, but it looks pretty cool! I love Mexico Blue!
Last, but not least, here is the engine decklid finally re-installed. I'm noticing now that I have some blue paint to cover up with black under the smaller, side grilles. The decklid has been reinstalled with the factory spring bars and rain tray.
DRIVETRAIN
Ok, onto the main event. After more than a year of sitting on a dolly on the floor - it was time to marry the engine and transmission back up to the car. If you recall, I had pulled it out to install a new pressure plate and clutch. Well, in the process I learned that the PO had shaved the flywheel down so far that the new pressure plate would not bolt up properly. So, I purchased a new flywheel from AA Performance and had it machine balanced (it was actually pretty close already).
I also learned in the process that the engine builder had used a rear main seal that wasn't the full 12mm deep and I was already getting a slow oil leak from the back. This was replaced with the proper size RMS and endplay was reset with the new flywheel. Then the new pressure plate and clutch were mated to the engine with new socket-heat bolts.
Finally, I was able to re-install the transmission along with the starter and new ground strap:
Here is everything ready to go back up into the car (note my TX flag that I waive proudly here in CA). I use the two jacks method of raising and lowering the car without wheels on to attach the engine and trans in place.
After the engine was reinstalled and I was riding the high of accomplishment, I set out to run some wires and get her running again. I purchased new 1 gauge welding wire and made my own battery and ground cables. After hooking everything up, I wanted to test the starter and roll the engine over. Of course, no good deed goes unpunished…
The starter was cranking very, very slow. So, I went through the troubleshoot list. I checked grounds, battery voltage, even swapped starters to no avail. After a few times of trying to start, I realized it wasn't just cranking slow - but I was also hearing what sounded like a grinding noise. Sh!t.
With much reluctance, I decided to pull the tranny and investigate further. Of course, all sorts of dangerous thoughts are running through my head at this point and I have no idea what's causing the issue. We jacked up the engine and removed just the tranny. I do have to say this was very easy - clutch jobs must be pretty quick on these cars.
After a quick glance, we found the grinding right away. The trans was showing metal shavings and the pressure plate clearly had witness marks. See the ring around the edge in the picture below:
With a little further investigation, it turns out the clutch fork arm was rubbing against the pressure plate. The PO had shimmed the pivot ball with (3) washers and as a result, the fork was sticking way too far out.
This was an easy fix, and it could have been a lot worse. I removed two of the washers and reinstalled the pivot ball with just one washer. After another hour or so, the transmission was back up in place and the grinding was gone.
I could have stopped there for the day, but being so close was just too tempting. So, we ran to get some fresh gas and installed and filled the gas tank for the first time. After some fiddling with wiring, it was time for a test fire. As a reminder, the engine was rebuilt in May 2018 and broken in at that time. It has sat (sadly) un-used on my garage floor since then. This was going to be the first fire in about two years. I was pretty certain that I would have carb issues from letting the old gas sit and evaporate out of them. But, after a few cranks…
Obviously, I'm over the moon to hear her run again. Yes, I need to adjust timing and tune - but she sounds great (especially without a muffler) and it's great to have a throbbing heartbeat in the car for the first time since the mid-90's. I couldn't have gotten this far without watching all of your builds for motivation and support and I've definitely leaned on my new wrenching buddy (neighbor) a ton throughout.
WHAT'S NEXT?
My ambitious goal is to take her out on a "test drive" before the end of April… we'll see if that happens or not. I need to bleed brakes, hook up the emergency brake, tighten down the steering u-joints, torque all suspension bolts to spec, adjust the clutch cable, connect the shift rod, connect the accelerator cable (and fab a bracket), and install the latches / catches for the trunk lids. So, that gives me ten days to start wrenching… Here goes nothing!
Stay tuned, I promise it won't take 14 months for my next update!
bbrock
Apr 21 2020, 07:41 AM
Woo freakin' hoo!!!! I think about your build often and wonder how you are getting on. Congrats on you wedding and all the progress on the car. Very, very exciting!
Cairo94507
Apr 21 2020, 08:20 AM
You have done beautiful work and your car looks terrific. I like the documentation and start-up video. Great work. I look forward to the driving video.
siverson
Apr 21 2020, 10:00 AM
Wow looks great!!!
-Steve
mbseto
Apr 21 2020, 02:19 PM
That's a gorgeous car, congrats on the first start up! I've been thinking about what to do about my own harness and your kit idea is very intriguing... If you do document that process, I will be paying attention.
aggiezig
Apr 22 2020, 11:15 AM
Thanks, everyone, for all of the kind words. It's hard to describe just how great it felt to hear her start up again. I've been tinkering away most nights this week, so hoping to have another exciting update here soon.
@mbseto - I will definitely keep track of what I am doing with the harness for you. I'm not a master electrician but I've used this kit in the past on a VW project and was pleased with the results. I may start a separate thread altogether with that information.
aggiezig
Apr 30 2020, 10:27 PM
Well, today is officially the last day of April and while I haven't taken her out for the maiden voyage, I am very close! Here are a few updates since my last post…
Before I get started, just a quick shot of my second home lately. Man, I've probably spent a totally of 8-10 hours underneath this rear end over the last couple of weeks. Don't worry there are jack stands behind the jacks. Man, I envy you guys with lifts!
Here are a few shots of the rear end after installing and adjusting clutch cable, throttle cable (more on that later), emergency brake cables, shift rod, CV axles, etc.
Man, those CV axles were a HUGE pain in the butt to get installed because of how deep they sit in the trailing arm. The CV joints are the ones that came with the car, but completely taken apart, inspected and re-greased with new boots and C-clips.
I replaced what would have originally been clevis pins and clips for the emergency brake levers with a shoulder bolt from McMaster-Carr. I was having a hard time tracking down the right hardware and these will be easier to remove in the future and technically safer.
No pics to share, but I used a motive power bleeder to bleed the brakes with DOT4 fluid. This being my first 914, I had no idea about adjusting rear disc vent clearance first - so, imagine my frustration with a soft pedal and no idea why. After adjusting that down to .004" and bleeding several more times, I have a pretty firm pedal. I'll bleed again after a bit of driving as I suspect there's still some air trapped in the pressure regulator. I have a slight leak from one of my rear bleeder screws and they are brand new, so I'll also be watching that to see if I can get it seated properly.
One word of advice, be sure to pressurize your system and do a leak down test first. I found quite a few loose fittings that I swore were tight when doing so.
I've also been working my way around the car and torqueing down all of the suspension fasteners. I found a PDF of a technical service manual and have converted all of the torque values to ft lbs in a google sheet. I'll share this in a separate thread for anyone who needs the values. I'm also marking bolts as I go with a paint pen, very racecar-esque (and it looks cool).
A small side project and not related to being road worthy, but I followed @bbrock 's lead and "fixed" the 914Rubber door stop arms. For those that aren't aware, 914Rubber makes a new set of arms and pins and they are very good quality, but drilled for 1/4" holes and not 6MM like the factory. This is an issue if your holes aren't super worn out because drilling the pin holes in the door jamb would be near impossible.
So, here's the "fix" - it's pretty simple. I purchased a set of 5/16" x 7/32" aluminum spacers from McMaster-Carr. This size has a slightly bigger O.D. than the new arms. So, drill the new arms out and then use some JB Weld to hold the new bushings in place.
After it has cured, then use a 6MM drill bit to drill out the spacer to fit the stock pins. Lastly, file down the surface so it is flat.
Now, @bbrock uses spring roll pins instead of the OE clevis pins. I think that's a really slick install and I ordered a set of 6mm stainless roll pins, but I could not get them to squeeze tight enough to fit my doors, so I will have to order a new size and try again.
I also got around to "fixing" the lack of a sleeve for my decklid pull cable. I ordered some 6MM O.D. nylon tubing and cut this to length, held in place with adel clamps. After some adjustment and lubing, it all works as intended. Just need to adjust my gaps now because the rear trunk cannot open with the decklid shut.
Looks great with the decklid on!
We spent some time this afternoon doing a string alignment to get the toe set before taking her out on the road (and it's a good thing, because the toe-in was nearly 1"). I've never done an alignment before, nonetheless with the string method, but this is pretty neat to setup and see in action.
We ended up with just about 1/8" (or 3mm) of overall toe-in on the front and just between neutral and 1mm toe-in on the rear.
The priority for the test drive is just to get toe "set" as camber and caster would require an flat and level surface (which my garage is not) and preferably some additional equipment. However, we did do a quick adjustment and measurement with digital angle finders and the front camber is about neutral, caster is neutral in the slots, and rear has a very slight negative camber. This is good enough for me to test drive.
With the car up on jack stands, I've tested the clutch, all gears, brakes and speedometer. The throttle cable isn't perfect and I'm going to have to re-engineer how to use the stock cable with the CSP bell crank linkage. I'm having an issue with the car returning down to idle after any throttle input, but I think the issue is actually with the CSP linkage and not with the throttle cable. I've adjusted about a dozen times but it's still not working quite right.
Also, threw the dash in-place temporarily for the upcoming test drive. Starting to look like a real car!
Yes, I've spent a few minutes sitting behind the wheel playing speed racer in my head. If you can't tell, I am ready to drive this thing already! Stay tuned because the first drive is just around the corner…
76-914
May 1 2020, 08:38 AM
Beautiful work!
bbrock
May 1 2020, 10:32 AM
The suspense is killing me!
FWIW, I had a helluva time getting my roll pins in my hinges too. I had to squeeze them in a vice as tight as they would go. After releasing them, they sprang back to just enough smaller diameter that I could tap them in place.
Root_Werks
May 1 2020, 11:13 AM
Everything is so clean! My 914 is dirty, used and abused.
aggiezig
May 2 2020, 05:42 PM
Alright, gents, ask and you shall receive. For the first time in 25+ years, she is officially back on the road under her own power!!!
So not only was this my first time driving this car, but it's also my first time ever driving a 914. Pretty cool little car, I am over the moon. (ignore the crappy video quality, I'll shoot a better video one day soon when I have a muffler and windshield)
Before the test drive, I gave her a good wash for the first time in a long time. She cleans up nicely! Paint definitely needs another polish, will probably ceramic coat this time.
Also took the chance to install the sill plates and rocker covers. I may change these rivets to black later, but for now, I like the contrast.
My original tail light housings were not powering up (too corroded) so, yes, these are tail lights from my other project (Jeep CJ7) zip-tied in place.
Here she is, ready to roll:
The test drive was a hoot and total success. We got her up to about 45 mph and blasted through first and second on a couple of pulls. The steering is fantastic and the suspension feels great. Brakes still pretty soft, so that will need some attention. Accelerator linkage is FUBAR... not sure what's going on but I'm going to take off the CSP and make sure everything is actuating properly. Also, the clutch is releasing pretty darn high so I think that I must have the cable too tight.
These are all easy fixes and I'm just glad to have hit this milestone. It's all downhill from here, right? I'm going to enjoy the moment for a bit then start attacking the few small issues before moving on to finishing up the wiring. Who needs lights anyways? Also going to order a Triad West exhaust and get the engine buttoned up.
But, hey, it sure is great to not have to push the car into the garage anymore!
[quote name='aggiezig' date='Feb 7 2019, 02:30 PM' post='2686928'] [quote name='Peashooter' post='2686726' date='Feb 6 2019, 09:38 AM'] If you have enough, add a square of the sound deadener inside the doors on the outer skin. When you shut the doors, they will give a nice thunk. [/quote]
[quote]
I noticed the same issue with my car ,I found it easier to cut 75mm strips ,I put 4 top to bottom ,huge difference even without the door panel on,no more tinny noise,even better with the panel on ,still have RH side to do but I now know it works . Nice to see your progressing well,nice car .
bbrock
May 4 2020, 04:08 PM
QUOTE(porschetub @ May 4 2020, 03:10 PM)
QUOTE(aggiezig @ Feb 7 2019, 02:30 PM)
I just did two pieces per door, one above and one below the bar. Huge difference. Has that nice German *thunk* when it closes.
aggiezig
Jul 22 2020, 07:45 PM
Quick update... progress continues on the 914. I've been working quite a bit on wiring and have taillights, blinkers, hazards, horn and instruments all figured out. Next up will be headlights and accessories like the wipers, blower motor, etc. I've driven the car up and down the block a few times, it's a total hoot. I'm going to try to get the glass in soon though so I don't have to take the windshield out before I cruise each time.
However, I did a thing today and I thought I'd share...
I think I have a disease.. never seem to learn my lesson. It's a '73 with a 2.0L in her. She's not perfect but a ton of fun and a complete car. I think she'll be a short term project - I'll do some minor fixes and actually enjoy driving a 914 while the Mexico Blue car is being restored.
In the meantime, my driveway screams UCLA Bruins with the yellow & blue. I'll post a vid of the new car soon.
76-914
Jul 22 2020, 07:53 PM
Another repeat offender.
bbrock
Jul 22 2020, 09:17 PM
No WAY! That's so cool and love the color combo. Quite the attention grabber.
jaredmcginness
Jul 23 2020, 12:41 PM
I dont know how I have missed this thread. Totally awesome work! Really inspiring. Love the color.
ValcoOscar
Jul 23 2020, 12:54 PM
QUOTE(aggiezig @ Jul 22 2020, 06:45 PM)
_________________________________ I have the same disease. Dr says I can be treated but never cured. I'm okay with that.
Oscar
Jett
Jul 23 2020, 05:08 PM
QUOTE(ValcoOscar @ Jul 23 2020, 11:54 AM)
Oscar
Lol, 1 leads to 2, which leads to 4... we are building another garage
The sickness is real!
aggiezig
Jul 23 2020, 05:16 PM
QUOTE(Jett @ Jul 23 2020, 06:08 PM)
My sickness runs deep... In addition to these two 914s, I'm also working on a 1980 CJ7, a 1958 Chevy Apache, a 1967 Ford F100, a 1970 356 Speedster Kit Car, a 1987 944S Track Car, and a 1994 325i Track Car. My neighbor and I started buying up cheap Craiglist projects when the pandemic hit and we're working on a shop one of these days soon... My wife thinks I've lost it.
Jett
Jul 24 2020, 07:27 AM
QUOTE(aggiezig @ Jul 23 2020, 04:16 PM)
That’s great...
930cabman
Nov 26 2020, 09:23 AM
QUOTE(aggiezig @ Jul 23 2020, 06:16 PM)
Curious, have you fallen off your medication for the sickness? we haven't seen/heard any recent progress. Please provide an update, your thread has been very informative. Thank you so much for sharing, I am just getting on the road now with a '74 rustoration.
Enjoy the holiday
aggiezig
Dec 8 2020, 11:09 AM
Ask and you shall receive!
Crazy how time has flown during this COVID era. I have been tinkering here and there on my 914 and will share some updates. Some of the other projects have gotten most of my attention in the last few months and the CJ7 has turned into a full frame-off restoration.
I did spend way too much money on 9/14 day at 914Rubber stocking up on new parts. I should be pretty much covered as far as parts go to get this car back together. I still need to track down some bumpers that I can paint, and figure out what I’m going to do with my trim - but those can happen later.
After my last big update and now that the car is officially road-going, I’ve made a few trips up and down the hills around my neighborhood. It’s been a blast to enjoy this thing even if I’m just going slow and staying close (and driving without a windshield). I did pull one bonehead move on a quick drive and left the e-brake just ever so slightly engaged… Yep, you guessed it - I caught my freshly powder coated backing plate on fire. Luckily there was no other damage that I can see or tell so this will be a minor fix and a reminder to finally get that e-brake handle return spring in place.
I’ve had a tough time finding the right way to make my horn work and retain canceling turn signals with an aftermarket Momo steering wheel. After trying literally four or five different hub adapters, I finally found the “right” one for my car which is Momo 8002. Below is a pic of one of the wrong adapters and the eventual right adapter that illustrate the issue I was having - too much clearance between the hub and the column.
Wrong:
Right:
You may notice in that last pic I have a “temporary” dash set up. I’ve roughly mounted things in place so I can work on wiring and also feel comfortable going for a spin and at least having a few gauges.
I’ve got the horn working but still having a tough time with the canceling signals. I can feel and hear the canceling ring interacting with the column but it’s not enough to cancel. Going to have to keep playing with it and perhaps build up the tab on the cancelling ring. I went ahead and added a pair of Hella Sharptone horns and although they will never be seen, I really dig the yellow color. If you haven’t yet noticed, I have a few tasteful accents of yellow in the car to offset against the blue.
I went back and forth quite a bit on how I was going to handle my tail lights. I have two sets of housings and both were pretty worn out. Unfortunately, these things don’t grow on trees and so I decided to try and restore them to an acceptable level. Despite cleaning the terminals, one of the lights would not send current through the original wiring. I did try adding new wires back to the original terminals but the soldering iron heated the plastic too much and it was doing more harm than good. So, I improvised and rewired the housing, drilling a small hole for the wires, sealing with hot glue and using a Deutsche connector.
The other taillight did not require re-wiring, but I went ahead and made a pigtail with a Deutsche connector so that both sides would look the same and could be disconnected easily.
I think it looks fine and frankly the Deutsche connector is easier to use than five individual plugs. Luckily the connectors are on the bottom side of the housing so they’re not visible anyways. I also repainted the inner reflector a metallic silver as it had lost some of its mirror shine. Lastly, I scuffed and sprayed the housing a satin black. This helped hide a lot of the ugliness. I used new 914Rubber taillight seals but to be honest they left some to be desired.
I originally tried out a set of Euro look lenses from Sierra Madre but was completely displeased with the gap between the lens and the body. I went through two sets with them before throwing in the towel and getting a set of US-spec red lenses that fit much better. One thing I noticed when working on these was just how ugly and un-stylish the taillights are compared to the rest of the car. WTF was Porsche thinking with these big blocky trailer lights
Look at that gap!
Where I landed:
You might notice my new muffler from Dave at Triad West. I really cannot say enough great things about the quality of his work and how easy and friendly Dave is to work with. The muffler is handmade and is an absolute steal for the money. It retains the factory look with one tailpipe exiting the driver’s side valence while still being a dual exhaust with the second pipe turning down. It sounds great!
For the longest time, I’ve dreaded re-installing the pop-up headlights. I think partially because I didn’t remember how I took them apart and partially because they seemed pretty intricate. But, I was tired of people calling my car “blind” - she deserved better.
Looking at a gaping hole in the body, I wasn’t even sure where to begin. After fiddling around for a couple of hours, I finally discovered the right order to install all of the pieces and then how to align the lids with the body. I’m using new nylon bushings and pushrods from 914Rubber which are ok - a little loose where they fit the rods.
The headlight motors were another chore. Thankfully mine cleaned up fairly nicely with a Scotch-Brite pad. I could get one side to work but the other would only rotate one way… After some research, it appeared I had a broken diode. So I ordered a new set of 1N4001 diodes from Amazon and re-wired the side with the break. The 5 pin relays are new from 914Rubber.
I’m also learning that my front trunk lid appears to be too proud on the passenger front corner. I’m going to have to try to adjust the hinge but I have a feeling it’s in the hood. It’s going to be re-painted anyway since I screwed up when color sanding and went too far, but it still sucks. Here’s a couple of pics to illustrate the gap difference (notice the passenger side gap around the headlight).
Normalish gaps:
Massive gaps, hood not sitting low enough:
The alignment isn’t perfect. The front brow pieces that are just held in with rubber grommets leave much to be desired in terms of adjustability and staying where you put them. Are there any tricks to getting these suckers to stay put? Maybe some silicone around where the tabs meet the body?
Sometimes it’s the small details that make all the difference. So, I added a set of new black badges from 914Rubber to the rear valence. These are quality pieces. The finish is matte and I might change this to semi-gloss at some point, but I really like how they attach to the car with small thumb nuts.
I also added a set of Porsche letters to the decklid. I bought some cheapo eBay push nuts to hold the emblems and unfortunately, they were total crap and disintegrated upon install. I will have to find a good quality set to replace these with. At least the letters look good.
I went ahead and put the back window glass in place using butyl tape from 914Rubber. I learned the hard way that the butyl they provide is really too thick for the job. It is what it is now because it would be a huge mess to redo, but it doesn’t look as good as it should (too much butyl showing). I’ll have to try and go back with some sort of solvent to clean up the line around the window.
When I work on my cars, I tend to blow up a million things at once for no rhyme or reason. So in appropriate fashion, I decided now was a great time to test out my new seat covers from 914Rubber (I told you I went crazy on 9/14 day…). I started by assessing the old seat first. The foam had definitely lost some shape and the bottom fiberboard was cracking in half. I started by building a new bottom board. I decided in the process that I am not going to retain the original seat sensors for the fasten seatbelts light. This may not sit right with everyone, but keep in mind I am building my own wiring harness. It would just be one more added complication for a pretty pointless warning system. I will probably leave the spot blank on my dash when I recover.
I tried to first steam the seat cushion to return some of its shape. That helped a little but still left a lot to be desired. So, I added a layer of 1/2” high-density foam to the top and bottom of the original cushion.
I decided for my car to order a set of tartan inserts with blue and yellow accents. I think these are going to look really great in the car. The color isn’t an exact match for Mexico Blue but they still look very sharp.
Originally, the seat bottoms are sewn through with some thicker thread to hold the cover down to the foam and add a “kick” up for thigh support. I debated on whether or not to replicate this and eventually decided to do just a couple of holes to help pull the seat cover down into the foam and create the crease you see in the pic below. I am happy with this.
Just for grins, here is the new cushion in the old seat. It definitely is a lot nicer to sit in with the extra foam - I think just the right amount for my car. I will start working on the rest of the seats, soon.
I’ll end with a pic of my “shop” with both projects inside. Man, I cleaned and organized for an entire Saturday to make room for both of these projects and things are busting at the seams. I need to get a real workshop one of these days.
That's all for now. We're driving back to TX to be with family for the holidays (don't tell the Governor...) so probably won't get around to doing too many things before then. I think I am going to push to finish up the wiring so that I can start installing the interior without worrying about covering up anything. One thing I am dreading but will need to do soon is to install my front windshield with the proper 5/16" butyl tape... from what I read, that will be an exercise!
Cairo94507
Dec 8 2020, 11:26 AM
Great progress and I love the new seat cover material on your car. For the windshield, don't forget to order the new blocks/spacers and the new clips for the trim.
jaredmcginness
Dec 8 2020, 01:56 PM
There he is! He's back! Love the seat. Shocked by how bad the Sierra lenses are. Keep it up.
Also, a tip I learned from the guys on here - roll that dynamat out reaaal nice until it is smooth/flush. That is when it really bonds to the metal and does it's job.
bbrock
Dec 8 2020, 09:01 PM
Love the progress!!!
I love 914Rubber but those tail light gaskets are junk and really not up to their standards. I've been told the AA gasket material is a better reproduction of the original so I have a set on order. Will let you know. I'm also not sure why they are still selling that 3/8" butyl either. Lots of threads on it being the wrong size - plus the factory manual that clearly states the correct size.
Now to the important stuff. You are making a big mistake not replacing the seat belt sensor. You know that special thrill you get every time you make the headlights pop up? Fess up. You can stop doing it, can you? You get similar thrill bouncing up and down on the seat watching the fasten seatbelt light go blinky, blinky.
aggiezig
Dec 11 2020, 12:49 PM
Thanks for the encouragement, guys. Much appreciated and helps keep me motivated on this project.
QUOTE(bbrock @ Dec 8 2020, 10:01 PM)
Brent, you're right. I've been tossing and turning every night since my decision to forego the seat belt sensor. Hah! In reality, I took one look at this part of the wiring diagram and said f*** no.
For those who've never had the pleasure of reading the current flow diagram before, "J34" is what Porsche calls the "Seat Belt Warning System Relay with Integrated Buzzer".
aggiezig
Dec 11 2020, 01:19 PM
Another small update, this time it's about the junk in my trunk.
A few years back (wow, time flies) I bought a trunk shock kit from Craig @ Camp914 for both the rear and front trunks. Well, I sat on it and lost the paperwork sent with the kit. Luckily, when I started getting tired of holding up the lids every time I worked in the trunks, Craig was kind enough to send me a new set of PDF instructions. So, here is documentation of my install and some tips.
First up is marking your holes. You know the old, "measure twice, cut once" saying? Yeah, I was measuring ten times before drilling into my fresh paint. Craig advised me on the phone that variations in these cars over the years they've been on the road may mean that his measurements aren't exact for my car, and to check a few times before drilling. Of course, that's easier said than done with something like these gas struts. Fortunately for me, his measurements worked perfectly for my car.
I broke out the tape measure, triangle square, and combination sliding square to help. Start by measuring for your bottom holes in the trunk rain gutter. You need to measure 19.25" back from the edge of the black engine decklid grate. So, shove the tape measure up against the engine grill in the rain gutter and measure back. Then mark your first, forward hole. Use the bracket to measure the distance for the second, aft hole. I used the combo square to find the distance from the edge of the bracket to the center of the holes and translated that as best as I could into the rain gutter.
The top trunk lid holes are a different approach. Using a flat ruler, measure 1.5" straight up from the inner, aft corner of the trunk hinge bracket (if trunk were closed). In the picture below, that would be the top-right edge of the bracket. This is the distance for your first hole. I then used a triangle square aganst the trunk hinge bracket to draw a line straight up. This line is essentially a continuation of the inner edge of the trunk hinge bracket. Use the same technique to mark the second hole using the bracket as a template.
Now, take a walk around the block. Come back and triple check your measurements. Then, go take a shot of whiskey or something else to calm your nerves. When you're feeling manly enough, break out the drill and drill your holes.
I deviated slightly from the instructions and used a larger drill bit than Craig recommends. The screws provided with the kit are stainless and will, unfortunately, strip themselves pretty easily in the mild steel of the decklid. I ended up driling a 4.5mm hole. YMMV, hold up your screws under your drill bits and find the right size that leaves just enough "tooth" for the sheet metal screw to bite. Another alternative here might be to use a rivnut and I may look into that at a future date.
I used a liberal amount of clear silicone in the holes and under the plates before attaching the car. Craig includes some rubber o-rings to go around the lower bolts through the rain gutter but I had a tough time with mine. Because they are o-rings and not rubber washers, they tend to "walk off" when tightening up the bolts. I will find some rubber washers at a later date to add under the bolt head, but for now I used silicone to seal.
After that, it's just a matter of popping on the struts. I applied a little bit of lube inside the socket end of the struts and then popped them on.
And, voila! We have a self-supporting trunk lid (finally). Also pictured is a rear trunk carpet from 914Rubber. I'm debating on adding some velcro to keep it in place and conform to the shape of the trunk.
After doing the trunk struts, I got an itch to "finish" up the trunk. So, I searched through the parts bin and found my OG trunk lock mechanism along with new plated retaining cup and the brass nut. I used a new seal from 914Rubber.
It's so satisfying to have a trunk lid that latches! No more painters tape to hold it down on test drives. One piece I haven't fully finished yet is the trunk lid catch pin mechanism. I had the assembly re-plated and have a new nylon bushing from 914Rubber, but I've apparently lost my original spring and have no idea where to find a replacement. Does anyone have a source?
Oh, and one other thing. I wasn't too thrilled with my previous application of butyl primer on the windshield. So I took it all off with solvent, masked a very straight and pretty line, and re-applied. The trick is to apply a small section and pull the tape up immediately because this stuff dries fast.
I've also already installed new windshield trim clips from 914Rubber (had to order a few extra after some showed up broken from my last order and some disintegrated on install). I have spacing blocks as well, but not really sure that they are thick enough. From what I've read, the best way to install is to first "center" the glass in the opening and use tape and markers to make some alignment marks that can be used when sticking the actual windshield using butyl.
One other thing, it's hard to see on camera but my original windshield has a scratch from a wiper blade on the driver's side. I am hoping that I can polish it out and bought some cerium oxide. That being said, I don't really want to put any pressure on the glass until it is properly installed and solid. So, I'll be crossing my fingers and taking the risk that it will polish out after install.
Stay tuned
djway
Dec 11 2020, 11:16 PM
I had really deep scratches on my original glass in my LowLight Ghia. While out I set up a table then built support to fit the glass curve. I hooked up a hose on a slow dribble to keep the glass moist then went at it. The water also kept the glass cool. I had to use wet dry papers then finished with the cerium oxide. Good luck.
