Very impressed have been following progress....POS to really nice car is my thoughts,well done.
Thanks for the kind words, they help to keep me motivated
I didn't see if anybody answered your question about removing pushrods to build oil pressure. Never heard of such a thing.
Adjust your valves. Remove your sparkplugs and disable the ignition. Crank until you get oil pressure, then install spark plugs, connect ignition, and fire it up. Maintain 2000 RPM for 20 minutes to beak in the cam. (Or whatever the cam MFG recommends.)
That's exactly what I was planning to do. Good to hear some confirmation from someone else that my break-in plan was sufficient without pulling the pushrods.
The probable reason your tin was hacked up is that the coil mounted in that location often creates cracks due to heavy coil mounted on flimsy sheet metal. Mine was cracked badly in these locations as well.
You should mount the coil on the fan housing where it's much stronger as sone years were done.
Good catch & good advice. I will see if I can find a better place to mount the coil
