Harpo
Feb 25 2017, 01:02 PM
I know that welding causes heat but I failed to consider the consequences of welding on my 914-6 clone column. I can't install the lower bearing.
I have tried heating up the column and installing the bearing and was successful but ended having to remove because the bearing was binding.
So I have decided that machining is the way to go. Lathe may be the easiest if I could chuck it up, not. So that leaves a milling machine.
Harpo
Feb 25 2017, 02:23 PM
Could the machining experts please help here?
Could a small diameter hone work? The price is right
https://www.amazon.com/CTA-Tools-1120-Small...words=bore+hone
zambezi
Feb 25 2017, 03:12 PM
I would think a small break hone would work for this.
live free & drive
Feb 25 2017, 03:44 PM
Hi,
Take it to a repair oriented machine shop ( or friend with a lathe). The way to do it is to clamp the part to the compound or cross-slide (as if it was going to be line bored) shim up the shaft/tube to the lathes centerline and clamp in place. Then put an adjustable boring bar in a collet in the spindle (like a Criterion or DeVleig) and then tease off the out of round or off-size heat deformation. It won't take much. The machining will take a few minutes the set-up 1/2 hour plus.
McMark
Feb 26 2017, 07:25 AM
I don't think that bearing needs perfect machining to sit in all the way around. It's not carrying a load. I'd try the hone, which may expose some high points that can be taken down with some light touches from a carbide cutter.
I think you can get it sorted out in your garage. Or throw it in a box my way and I'll sort it in my free time and document my process.
Harpo
Feb 26 2017, 07:45 AM
Thanks Mark I will try the hone (it was cheap) and let you know
David
Harpo
Mar 14 2017, 03:21 PM
Is there a member with a six that that is willing to send their reinforcement "washer" to McMark so he can have these laser cut
peteyd
Mar 15 2017, 10:06 AM
QUOTE(Harpo @ Mar 14 2017, 01:21 PM)
Click to view attachmentI have this piece and also a laser.
I can work on this and sell it with the other stamped piece.
Pete
McMark
Mar 15 2017, 12:54 PM
Awesome Pete. I was gonna run with it, but you're way more set up to deal with it.
jim_hoyland
Mar 15 2017, 03:15 PM
Installed the Jeff Hines left-side ignition kit.
Mark Henry
Mar 15 2017, 03:22 PM
QUOTE(peteyd @ Mar 15 2017, 12:06 PM)
Pete
I want one of each, set them aside for me for when we bring you your seat.
SixerJ
Mar 15 2017, 04:35 PM
That's my support ring in the photo and bought it last year via Mittlemotor at the time it was still available
Pete, for any reason if you can't find yours / NLA I would be happy to post over
Mar 15 2017, 04:42 PM
QUOTE(Mark Henry @ Mar 15 2017, 05:22 PM)
Pete
Pete - I'll take 2 spacers. Thanks, mark
Harpo
Mar 16 2017, 07:11 AM
That is awesome Pete I will take one also. Please let me know when they are ready
Yes I borrowed sixerj photo to help emphasize my point
peteyd
Mar 16 2017, 11:57 AM
Here is the preliminary drawing. In the next couple days I will cut one out on the laser and see how it matches up to the OEM piece.
Pete
jim_hoyland
Mar 16 2017, 01:16 PM
QUOTE(peteyd @ Mar 16 2017, 10:57 AM)
Pete
Click to view attachmentPlease add me to the list; I will order 1
eric914
Mar 16 2017, 08:51 PM
Me too:)
type47fan
Mar 16 2017, 09:12 PM
Nothing really constructive to add here . . . just found these pictures of a set up I had, at one time, from a '71/6.
Click to view attachmentClick to view attachmentClick to view attachment
peteyd
Mar 17 2017, 03:00 PM
I cut out the shim today.
It fits on the ignition nicely and matches up the original piece nice as well.
Next week I will cut them out of the proper gauge steel.
Pete
Harpo
Mar 17 2017, 03:16 PM
Good afternoon Pete,
Is there any chance you would consider making the "washer" a little thicker?
Thanks
David
QUOTE(peteyd @ Mar 16 2017, 09:57 AM)
Pete
peteyd
Mar 17 2017, 06:07 PM
Originally the thickness is .035"
What do people want? I have material that is .045" and .032" It will be cut out of galvaneel steel, which wont rust so there is no need to paint it. It also polishes up pretty nice with some scotch brite
I can cut either thickness, but I don't want to cut both.
Pete
SixerJ
Mar 17 2017, 07:04 PM
QUOTE(peteyd @ Mar 18 2017, 12:07 AM)
Pete
Pete, I would be really tempted to do it out of the thicker material. My new one I recall is very thin and yours looks like it has pulled up in where it has bolted up. I can't see that it's going to make a difference in mounting up, clearance with the plastic escutcheon etc
Thanks for doing this BTW and demonstrates exactly why this site and members are great
tweet
Mar 18 2017, 08:29 AM
For those that have requested a thicker gauge metal, this may have been deliberate by Porsche. I've had a few of these and some customers' as well. When they distort they are very easily flattened back with a standard hammer and a flat surface and are good to go.
Don't forget that this is a malleable fixing plate to install the heavy unbalanced 911 style ignition. The weight and design of this ignition, and the way these older cars go down the road make the ignition move a lot even when properly installed. I think the thinner gauge and softness of the metal are supposed to behave more like a crush washer so the plate takes the impact and vibration from daily driving, instead of the soft threads of the mounting holes in the zinc casting of the steering lock housing.
This is just my opinion and reasoning. Then again maybe Porsche just cheapened out, but I would rather save the threads and have the plate give out, not the $950 ignition assembly.
Harpo
Mar 18 2017, 09:38 AM
Because you have the .045 in stock that would be my vote.
A class 8.8 M6 bolt requires a minimum 9.6mm of threads of engagement. There are 18mm of available threads in the lock. Therefore with a 20mm long bolt the risk of damaging the threads in the lock are minimal. I under stand tweet's post it is a very expensive part.
I have found a suitable black pan head screw and I have extras if anyone want some for their clone or real left side ignition. If interested please send me a PM
David
Click to view attachmentQUOTE(peteyd @ Mar 17 2017, 04:07 PM)
Pete
Harpo
Mar 19 2017, 09:40 AM
If the u joints are the same between the 914 & 914-6 then why wont my 911 steering shaft slide on to my U joint? I can't find any burrs or damage and it will slide on to my 914 steering shaft?
peteyd
Mar 20 2017, 12:02 PM
We finished cutting out the shims today.
They are cut from .045" thick material.
They will be sold with the dash depression piece I already make. If you want to buy one separately they will be $8. they are not on the website yet, so if you're dying to get one fast, then call and ask for Pete
Mark Henry
Mar 20 2017, 12:37 PM
Cool!
mb911
Mar 20 2017, 01:30 PM
Awesome I want one for sure.
Harpo
Mar 20 2017, 03:11 PM
Me too
jkb944t
Mar 21 2017, 05:40 AM
That is great news since I'll need one too. I just wish it would have happened a couple of weeks ago when I ordered my dash depression piece.
Jeff B
peteyd
Mar 21 2017, 06:04 AM
I will bring a handful to Hershey if that helps anybody.
Pete
Larmo63
Mar 21 2017, 04:14 PM
I think I'm missing the outer bearing. That seems to be easily sourced(?) Will the '73 /4 steering column shaft fit into this? It would allow me to use the later wheel which seems to be more available. Also, the lower circlip, any body have/source those? The one that holds the inner bearing in?
This is all that came in the box....
Here's where I'm at so far, and I'm just going to use that early ignition switch because I don't care so much about originality and which key it uses. Will the /6 plastic bezel screw onto my early switch? Anybody?
jkb944t
Mar 22 2017, 05:52 AM
The electrical connections for the ignition switch and the wiper/turn signal stalks are obviously very different when converting to the 911 column.
Does anyone have a chart with the pinout locations?
Jeff B
Mar 22 2017, 05:55 AM
QUOTE(peteyd @ Mar 21 2017, 08:04 AM)
Pete
Yes. I'll pick up a couple from you then. Thanks
jim_hoyland
Mar 22 2017, 06:06 AM
I want one too; anyone in So Cal ordering one ? I'd like to combine an order...
sb914
Mar 22 2017, 06:11 AM
Wondering? what are the benefits of this mod? Converting to let side
McMark
Mar 22 2017, 06:50 AM
QUOTE(sb914 @ Mar 22 2017, 08:11 AM)
Cool factor goes through the roof.
jim_hoyland
Mar 22 2017, 07:28 AM
QUOTE(jkb944t @ Mar 22 2017, 04:52 AM)
Jeff B
I did a pin-out ID for the Ignition Switch; will take a pic and post later
Steve
Mar 22 2017, 07:29 AM
QUOTE(jim_hoyland @ Mar 22 2017, 05:06 AM)
I will take one if you are ordering one. We can split the shipping cost.
Harpo
Mar 22 2017, 08:25 AM
This is all that I have been able to find so far
Harpo
Mar 22 2017, 08:29 AM
QUOTE(Larmo63 @ Mar 21 2017, 02:14 PM)
I think I'm missing the outer bearing. That seems to be easily sourced(?) Will the '73 /4 steering column shaft fit into this? It would allow me to use the later wheel which seems to be more available. Also, the lower circle, any body have/source those? The one that holds the inner bearing in?
Here's where I'm at so far, and I'm just going to use that early switch because I don't care so much about originality and which key it uses. Will the /6 plastic bezel screw onto my early switch? Anybody?
Click to view attachmentThe lower bearing is held in place with "C" clips. The upper bearing that you have already installed has a slight interference fit. I believe that the steering wheel fits in there and removed all of the play. I believe the lower bearing is the same between 914/914/6 and 911.
Mark Henry
Mar 22 2017, 09:40 AM
QUOTE(McMark @ Mar 22 2017, 08:50 AM)
If you're doing a /6 conversion it makes it a little more authentic, true to what Porsche did. You don't have to do it, really it's just cosmetic.
But like Mark said...cool.
jim_hoyland
Mar 22 2017, 09:52 AM
QUOTE(Steve @ Mar 22 2017, 06:29 AM)
Great, lets see whether Larmo, Forrest, or ? want to order too....
Larmo63
Mar 22 2017, 10:34 AM
QUOTE(sb914 @ Mar 22 2017, 05:11 AM)
Faster starts at Le Mans.....?
Harpo
Mar 22 2017, 10:41 AM
jkb944t
Mar 22 2017, 10:59 AM
Cool factor for sure plus faster Le Mans starts!
Larmo63
Mar 22 2017, 11:19 AM
Now, back to business, will a stock /4 steering shaft work inside of this column if I'm not going to use the lock mechanism?
mb911
Mar 22 2017, 11:56 AM
QUOTE(Larmo63 @ Mar 22 2017, 09:19 AM)
Oh that would be perfect.
Harpo
Mar 22 2017, 12:42 PM
QUOTE(mb911 @ Mar 22 2017, 09:56 AM)
SixerJ
Mar 22 2017, 05:18 PM
Lawrence, circlips are availiable from OPC, stoddard etc
I don't get the 35x1.5 dim, could swear the tube is bigger than that, should be cheap as chips if you can find a non Porsche source
Positive the late -4 column uses the same clip
http://www.stoddard.com/90004200800.htmlClick to view attachment
