I think I'm missing the outer bearing. That seems to be easily sourced(?) Will the '73 /4 steering column shaft fit into this? It would allow me to use the later wheel which seems to be more available. Also, the lower circle, any body have/source those? The one that holds the inner bearing in?
This is all that came in the box....
Here's where I'm at so far, and I'm just going to use that early switch because I don't care so much about originality and which key it uses. Will the /6 plastic bezel screw onto my early switch? Anybody?
The lower bearing is held in place with "C" clips. The upper bearing that you have already installed has a slight interference fit. I believe that the steering wheel fits in there and removed all of the play. I believe the lower bearing is the same between 914/914/6 and 911.
-4 column parts, same bearing
