QUOTE(altitude411 @ Nov 22 2020, 05:30 PM)
Hey Mark, did you use the Hess drivers side long? If so did you have to modify it and what are you thoughts on this piece?
It's a good piece. Much better than the passenger side repro piece, but I think mine is better. The only real 'issue' I noticed is the bottom bend radius is the same as the top, so it'll take a bit of massaging where the old and new come together. And the floor pan relief isn't quite right. But as far as repro pieces go, it's good.
QUOTE(914werke @ Nov 22 2020, 06:34 PM)
Thats quite a jig!
Yeah, I've built a lot of that for this project. The Celette fixtures only ensure the suspension points are in the right place, it doesn't guarantee the doors will line up or the windshield, etc. That's been the hardest part of this project. The metal work is not any harder than normal, but you only get one shot to get this all right -- if I make a mistake or rush or don't check something in the right order, at the right time, then I could stack a whole bunch of other metal on top of something that's wrong. Most of the time hasn't been actually working, just a lot of thinking and planning, measuring and building jigs.
QUOTE(Cairo94507 @ Nov 23 2020, 10:18 AM)
Amazing. It has got to get a lot easier from that point forward, right? That looks great and it is wonderful to see that chassis moving forward so it can get back on the road.
Getting these longitudinals in will somewhat 'lock' the front half to the back half. It took me a
LONG time to get comfortable with my measurements, not just the numbers, but
where I'm measuring from and to. To get here I only locked the strut tops into place with fixtures. Those are my 'grounding points', each time I add in another connection things get a little more solid. This builds confidence, but also absolutely must be done in the right order. If you lock something in too early, you could screw yourself later if it needs to move. I wouldn't quite say anything will be any easier until the doors are looking good and the front a-arm mounts are solid. At that point, as long as things are still lining up right, everything will get easier. Right now there's still a lot of.... risk?
Not sure that's the right word, but there's still a lot of work before I feel like this has been successful.
