@MCShack
some other stuff i dug up from files on research last year.
for comparison.
production plate for a 1974 Karmann Ghia, built jan 74
nr = 0449113
production plate for my 74 914, built jan 74
nr = 0459543 (built the day after the kg above).
production plate for 74 super beetle cabriolet. built feb 74
nr = 0659323.
for the 5th number it looks like
1 = karmann ghia.
3 = beetles (or perhaps super beetle cabs).
5 = 914s.
the numbers are spaced with a gap between.
also i knew i had a build sheet found in a VW tucked away somewhere.
i think i found this on a jeans beetle website run by an enthusiast but can't remember exactly anymore. anyway, thanks to that enthusiast site with acknowledgement.
i think the story was this build sheet was found under the back seat (in common with stories you hear about some fords, gms and chryslers). highly prized if happen to be in a car but not all cars had them to find.
the terms the germans use are interesting.
it called a WORK INSTRUCTION.
and very clearly it has what we would call the karmann number - or more universally throughout VW = the production number.
its called the KENN NR. which translates directly as KNOW NR.
ie know what the car is that you are building? i dunno. no pun intended.
so its really an order number that is coming through the channels from the dealers, main distributors, sales department, to the factory?
of interest this build sheet also noted the time of the day. i'm guessing its the minute of the day given its written as 81 probably made sense at wolfsburg or similar sized plant where they would have been churning them out. i think the 0 in this work order kenn number means the wolfsburg factory.
you could well be on to something with your question about the use of 6 in 914s and other numbers later in 75.
i mean - an order could get cancelled? or revised? or reassigned?
so there are all sorts of possibilities there as well as just the idea of going past 100.
production figures i calculated about 74 MY i sent through to you in a PM.
this does suggest during nov dec 73 they were making more than 100 cars a day (all of which were 1.8s). but in jan 74 this figure virtually halved as a daily number (again all of which were 1.8s). they resumed making 2.0 L cars sometime in feb 74 and mixing 1.8s with 2.0s for the rest of the MY.
