QUOTE(Van B @ Dec 1 2021, 05:53 PM)
Ok, so I’m following everything but the fact that my car simply would not start with the vacuum retard attached. INSTANTLY floods! I’ve tried it twice and the second time I really made sure timing and idle speed were on the money.
attached or not attached?
the photos you posted show all the vac lines attached van.
retard and advance. thats how the car came to you right?
way i see it with vac retard attached its going to start easier from cold.
but once its warm its going to idle hotter (esp out in traffic). it stays retarded.
a car without vac retard attached is going to be a little harder to start from cold.
but once its warm will idle at 7.5 BTDC.
EDIT - and idle cooler too out in traffic.
i've never thought too hard about this before.
i never had to do anything to the car back 30 years ago.
it ran sweet-as for 15 years.
and its kind of running sweet-as again (except for the cold start being not up to what it used to be).
the thing about having no vac retard line, which i'm speculating for a 49 state car,
(and those throttle bodies are out there, with the right part # on them) is maybe the enrichment mix is tweaked on the ECU. its another area i have to go in and teach myself about. i've never had to touch the car in those areas, nor do i necessarily want to,
but i have to read the factory manual and get my head around how you can tweak the ECU. or even the AFM. other members here who have been fooling around actively with their 1.8s would really know this stuff.
i guess what i am saying is, cold the ECU definitely does adjust the fuel enrichment.
and that would be tuned or in synch with the vac retard scenario.
if you don't have vac retard (as maybe a true 49 state car is), maybe they tweaked an adjustment on the ECU from the factory. but i don't know. thats my next bit of reading.
