i worked out where the confusion came from between 2000 and 2010 on threads here and on pelican parts over vacuum hose set ups etc.
folks had cars that were already 30+ years old. throttle bodies had been replaced. some of the set ups being argued over were not in original configuration. some throttle bodies had come from other 1.8s in the VW family of cars.
this is the basic 74 914 EC-B throttle body.
Click to view attachmentClick to view attachment All 74 914s had manifold vacuum connected to distributor retard vacuum. all ran retard at idle for emissions. only EC-B ran vacuum advance off upstream port on TB.
here are examples of various VW throttle bodies for the 1.8 L-Jet engine.
would have been a lot of these floating around?
to make matters worse some seem to have the same part # stamped on as the 914 TB. i don't know how VW would have distinguished these parts from each other?
Click to view attachment Click to view attachment Click to view attachmentClick to view attachmentClick to view attachment both EC-A examples posted here by members
@nihil44 and
@L-Jet914 have had their vac advance activated and an alternative source of manifold vacuum taken off the intake plenum. in other words converted to EC-B configuration.
got my head around the california emission kookery. CARB were making VW and porsche run the car retarded from ideal at all part load as well as throttle closed positions?
so much for the distributor as a fine tuning, reactive, load sensing adjustment device for engine efficiency?
california cars would have gone into slightly retarded timing of mech advance at cruise?
to do a version of trick as idle retard? forcing lower emission at the cost of fuel economy/efficiency of combustion.
@Van B will fill that in if i have it wrong.
anyone in cali with any sense would have found a way to reconnect advance?
in 75 they swapped it all around.
the EC-B throttle body went on to the californian cars.
the upstream port on the TB connected to the EGR and activated it at cruise and part throttle.
the EC-A throttle body went on to the 49 state cars.
these had only the manifold vacuum port connected to the retard vacuum on distributor (no EGR or cat and no vac advance.).
i found two published versions of both cars in very good original condition showing this.
you can find plenty of 1.8s for sale, the images that go with the dealer ads show that over the years owners have found some pretty novel ways to find manifold vacuum off hoses directly to the plenum to activate the vacuum retard if they had a TB without the port.
suspect there were lots of the vw TBs but correct 914 TB was a bit harder to find.
i will deposit the documents we have found in the originality section of the website as a resource for 1,8 owners.
as
@Van B says, so folks know what the baseline factory set up was - then its easy to think your way into work-arounds if you have to.
jeff bowlsby asked if we could do a correct vacuum hose layout for the 1.8.
but we don't have to.
there is one that is on the pelican parts site that is 100% correct and was done early on.
what did not get worked out 10 years ago was that the disconnection of the advance hose on the distributor was due to CARB. Not a chronological difference, early and late as noted in discussions 10 years ago. both versions were manufactured at the same time. production of L-Jet very likely starts in November 1973.
