got some more stuff done, just for the giggles, here's the current "todo" list ...
Engine Swap Related Work *Electrical *Add fuel pump wiring. *Test fit engine wiring harness. *Mount ECU. *Oil *Fabricate oil cooler exit ducting. *
Weld in oil cooler inlet floor. *Mount oil thermostat. *Fuel *Hook up fuel lines. *Fabricate fuel filter mount. *Fuel pump mount mods. *Engine *Test fit engine tin, and modify as necessary. *Install breather plugs. *Install 3.2 intake elbow. *Install cam covers. *Install throttle cable. *Install new valve cover gaskets. *Change engine oil and replace on engine filter. *Install Headers/Exhaust/Muffler *machine 914 flywheel ringear to fit 993 flywheel *clean *Transmission *clean *fix leaking speedo angle drive *change oil (swepco) *add JWest shifter set *fabricate shiftrod *notch for flywheel sensor *Other Work *Weld cage. Reweld cut joints (sleeves?) *
reweld Cage to targa bar attachment plates. *Seam-Weld front suspension mounts. *Alignment *Check torque on all suspension, brake, etc bolts and nuts. *Corner Balance *Install front strut inserts. *Fabricate tray for fire extinguisher *
Fix broken front trunk release cable *Add JWest fuse block *
Add H4 100W headlights *
Add JWest Flasher upgrade *
Add Camp Euro Turnsignal kit *
Add Camp Pilot light kit *
Install 5-point harness *
Mount and reseal new rear window *Install missing grommet for fuelline at the firewall *Get tank repaired, boiled, cleaned and powedercoated *Check inner CV joints bolt thread-depth *Seam sealer for drivers side rear fender to trunk *
weld in hood shock mounts *
weld cracked door brace on drivers side *
weld in door strap support on pass. side *
install 9/11 GT flares *
Install Front Windshield *Clean mounting flange *redo gauge wiring *weld stamped floorpan holes shut *
remove air hoses behind rockers *
weld up holes for air hoses (routed behind the rockers) *
weld in antenna cable hole *
Weld in front suspension support bar. *
Weld in antenna hole cover *
Clean up weld spots on firewall *
Weld in headlight bucket supports *
straighten floorpan *
weld in brackets for the new ECU harness *Shopping List *Hose Mount Brackets *Oil Inlet O-Ring * PN: 999.707.316.40 *Six Cylinder Tach *Distributor Belt * PN: 930.602.134.00 *Distributor Vent * PN: 993.602.121.00 *Black rubber windshield frame kit - ordered 04.03 *electrical plug connectors for gauges *set of front roller bearings *
Get additional rubber grommet for main harness @ engine shelf - EASY? *
felt tank pads *
Buthyl (sp?) kit for mounting the new rear window *
Spark Plug End *
JWest Shifter - ordered 04.02 *
Fuel Filter Fittings - do we need a second filter? *
Throttle Cable End *
Muffler(s) - shipped 04/04 *
Fuel Pump Fittings *
get new windshield - ordered 04.03 *
AN Fittings - ordered 04.18 *
Race Approved Roll Bar Padding *
