QUOTE(jaminM3 @ Jun 19 2007, 04:19 PM)
How about an update Andy?
I saw your car in the pictures of the WCR, so we know it's done, or at least running and driveable...
update will come later this week. yes, it's running!
there's a few things that need to be sorted out. the off idle is rough and it doesn't want to drop the rpm right away when you let off the gas, there's a 1 second delay.
got some minor oil seepage on one line.
i also need to change the oil after the weekend as well as the two filters. flushing the system after the initial shakedown run.
re-torque all the bolts. mount the fuel pump permanently.
you know, little things like that.
by the end of the weekend, i felt pretty comfortable. the engine has GOBS of power once you hit the cams (which is pretty early).
i let quite a bit of smoke out of my 225 street tires ...
Andy
