QUOTE(Kargeek @ Nov 25 2009, 12:55 PM)
Outstanding Job, I can appreciate the effort you are going through and I hope you are enjoying every minute of it.
What size tires are you running on the 16x7's"
Dave
Dave-
I have seen your six many times, it is one of the very best. If i'm not mistaken, you're running a 3.2 or 3.6?? Thank you for your kind compliment.
Yes, I'm enjoying every minute.
The tire size is: 195-55-R-16. They tires are Michelin Pilot-Primacy. The contact patch is smaller than the 205's. The 205's would not fit with the 7" rims and stock bodywork.
I really wanted to run on 16X7's because I like the look, but didn't want to modify the quarter panels, the body of this car was accident and rust free (except eng. shelf) so I just couldn't do it. I did have to roll the rear wheel-well openings on the top, then did a test-fit before i dissasembled the car and everthing worked without touching the inner or outer body work.
My vision of this car is to look like it did in 1970 with the exception of the rims.
I will report on the traction / handling once the car is on the road. I expect it to be easy to brake loose with 200HP and stock 901 w/ stock diff...
Eddie
