The 2056 engine is in the car and running.
This engine has plenty of grunt. I can now feel acceleration in all gears. Totally transforms the car. On local twisties where I used to accelerate all the way from one corner to the next with the 1.8L, I now find myself coasting most of the way since I'm quickly up to the max speed I'm comfortable with.
Had the carb linkage towards the rear of the engine but it hit the rear firewall. Also got the carbs working pretty well. A little stumble coming off of idle but runs real good with the throttle open.
I used the clutch which came with the engine. It was a bit worn but still serviceable. It chatters a lot in 1st gear but is ok to take off in 2nd. I'll need a new clutch, PP, TO bearing, and pivot bushing.
