Mblizzard
Nov 1 2014, 08:41 PM
QUOTE(PanelBilly @ May 23 2014, 07:04 PM)
I picked up two of the metal targa hinge covers and replaced the plastic ones that I had on the car. The plastic was OK, but they were both a little warped. I painted the covers with some undercoat spray and they came out looking very much like the leather on the pad. I'm sure glad I had used stainless steel square head screws on the pad. Made removal and installation much easier.
Click to view attachmentClick to view attachmentWhere did you find the metal covers?
PanelBilly
Nov 2 2014, 11:32 AM
Mr Stone
JRust
Nov 2 2014, 11:40 AM
Looking great Billy! I vote for painting the ribs black on your engine lid. While the blue looks nice. I think it looks better with the Ribs black. The ribs themselves really aren't that appealing(to me). So I like them being the same black as the grill. Having said that your car is gorgeous & will look great however you do it.
Great news on your motor
. Good to hear things coming together for you. It's been a long haul but will be totally worth it. I see many awards coming your way
PanelBilly
Nov 3 2014, 06:07 PM
Got a call from the shop today and the engine is nearly done. They just need to do a few more things. Somehow I misplaced the oil sump cover (or its in their shop somewhere), so it looks like I need to get another one.
PanelBilly
Nov 7 2014, 04:17 PM
The engine work is nearly complete and I'll be bringing this baby home to get it ready for INSTALLATION. I need to figure out why the 2 bolts hanging out of the
timing chain covers are so long and if they should be replaced with shorter ones. There's also some long bolts for the engine mount that i suspect should be
PanelBilly
Nov 7 2014, 08:02 PM
EdwardBlume
Nov 8 2014, 07:48 AM
PanelBilly
Nov 11 2014, 10:39 PM
The engine is in my garage now!
PanelBilly
Nov 15 2014, 01:27 PM
So the engine goes together. First the alternator wires need to be pulled through the shroud and the rubber grommet needs to be set.
Click to view attachmentClick to view attachmentThen the wires slip through the inner cover that directs air evenly over the cylinders.
Click to view attachmentThen bolted to alternator.
Click to view attachmentGround wire to alternator case is a challenge to do.
PanelBilly
Nov 15 2014, 01:33 PM
Fan housing strap was more fun.
Click to view attachmentClick to view attachmentAnd now I'm trying to decide what hardware to use to secure the shroud.
Just used some bolts that were in the scrap pile.
Tom
Nov 15 2014, 02:15 PM
Looking nice Billy. Sent you a PM about the wiring harness mods.
Tom
PanelBilly
Nov 15 2014, 06:44 PM
When I checked the size of the holes in the shroud with the insulators, I could see that I needed to trim the holes a little larger. I've read that this is normal, so I was prepared.
Click to view attachmentIt wasn't too hard to grind the holes, I just had to make sure that none of the dust ended up in the engine.
Click to view attachmentI figured I'd mock up the carbs and see if there was going to be any more problems, but it all fit great.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
PanelBilly
Nov 15 2014, 06:51 PM
But I'm missing one of the fastener clips to finish the fiberglass block off trim that mounts to the front of the shroud. I have 3 of the 4. Anybody have an idea where to find them? I check 2 stores today, but no luck. I'm going to Ace tomorrow. They seem to have a large selection.
Click to view attachmentClick to view attachmentClick to view attachmentAnd I see that there are 3 holes in the shroud. Anybody know why they are there?
Click to view attachmentAnd do I need these 3 bolts sticking up from the block?
Tbrown4x4
Nov 15 2014, 07:54 PM
Looks great Billy! Something so perfect about triple throat Webers on a flat six.
puffinator
Nov 15 2014, 08:05 PM
Those 3 bolts are for an accelerator bracket for the CIS injection. You don't need them with carbs.
puffinator
Nov 15 2014, 08:25 PM
In regard to the 3 holes. The one on the right, in your picture (passenger side) gets a plastic plug, the one on the left is for a bolt holding a "heat source" funnel to push air down to the heat exchanger (see my picture). The one on top is for a plug that holds spark plug wires on CIS engines.
PanelBilly
Nov 22 2014, 07:35 PM
More work done today. First I have the braided ground cable attached
Click to view attachmentAnd the block off plates for the front of the shroud
PanelBilly
Nov 22 2014, 07:37 PM
PanelBilly
Nov 22 2014, 07:39 PM
And since I had a box of plastic plugs, I capped all the holes in the shroud
PanelBilly
Nov 22 2014, 07:42 PM
So this is where it stands. Now I need to figure out what sending units will be mounted to the engine and order up some new ones. Tomorrow I'm going to start the headers and fan belt. Then the tin
Nov 22 2014, 08:06 PM
Too pretty to put in a car.
JRust
Nov 22 2014, 09:05 PM
QUOTE(mepstein @ Nov 22 2014, 06:06 PM)
That is one sweet looking motor Billy. Way to pretty though
. It really needs to go in a dirtier car otherwise it will just be over the top. I suppose I could throw it in my old v8 car to help you out
PanelBilly
Nov 22 2014, 10:03 PM
QUOTE(JRust @ Nov 22 2014, 07:05 PM)
I thought you were into the hybrid thing. This car is all Porsche
KELTY360
Nov 22 2014, 10:07 PM
QUOTE(PanelBilly @ Nov 22 2014, 06:42 PM)
Am I the only one to notice the dust on the hats? I think you're going to have to repaint them Billy.
Simply fabulous...I'm sure it will sound as good as it looks.
PanelBilly
Nov 22 2014, 10:39 PM
Not paint, they are powder coated. Wipes clean
rhodyguy
Nov 23 2014, 11:32 AM
Mcclendons has a pretty extensive metric selection. Try the Renton store.
JRust
Nov 23 2014, 11:49 AM
QUOTE(PanelBilly @ Nov 22 2014, 08:03 PM)
Hey to help out a friend I can go all Porsche. I'm giving that way
billh1963
Nov 23 2014, 04:06 PM
Beautiful engine! I'll be curious to see how you like the PMO's.
aircooledtechguy
Nov 24 2014, 09:39 AM
WOW!!
Good things really do come to those who wait. . . I'm lovin' watching this car come together!!
type2man
Nov 24 2014, 08:39 PM
That oughta run good!!!!
PanelBilly
Dec 6 2014, 06:08 PM
Headers were installed today, but i quickly learned that you can't Install both of them and turn the engine back over. So the second one goes on while you sit on the floor and try to hold the gaskets in place
PanelBilly
Dec 6 2014, 06:10 PM
PanelBilly
Dec 6 2014, 06:28 PM
And then the exhaust
Click to view attachmentBut I assembled it without the gasket. I thought I had one. I'm going to look a little more before I order a set
Click to view attachmentThe engine is looking closer to ready
bigkensteele
Dec 6 2014, 06:31 PM
Looks fantastic! Can't wait to see it in the car.
Just wondering if it might not be easier to put the headers on after the motor is in the car? You will definitely want them loose at the heads when you go to mount the muffler and bracket to the back of the transmission. I learned that the hard way on my 4.
Keep it up - I have been watching this thread for a loooonnnngggg time!
Cairo94507
Dec 7 2014, 09:02 AM
Seriously - get that baby in the car already!
EdwardBlume
Dec 7 2014, 09:06 AM
QUOTE(Cairo94507 @ Dec 7 2014, 07:02 AM)
Like you don't have a car on jackstands....
PanelBilly
Dec 10 2014, 09:36 PM
Today the oil pressure sender arrived and I have the throw out bearing finished
PanelBilly
Dec 15 2014, 12:11 PM
Broke one of the exhaust studs yesterday while I was torking them up. I should have just replaced all the studs before I started!
aircooledtechguy
Dec 16 2014, 10:43 AM
PanelBilly
Dec 27 2014, 10:25 PM
Today I got the timing marks scratched in the flywheel and color coded them.
Click to view attachmentHere's the clutch mounted up
Click to view attachmentAnd the transmission mounted up without much fuss. Rebuilt starter needs one more bolt. I'll need to pick one up next week.
Click to view attachmentNow I need to find the gaskets for the muffler and get that mounted up.
Cairo94507
Dec 27 2014, 10:35 PM
Very nice
PanelBilly
Dec 30 2014, 08:44 PM
I needed the car high enough so I could slide the engine in, so by combining the new lift with some wood blocks, I got. I just didn't trust the lift, even though it has a built in cross bar to lock it. I stacked up some wood 4x6 blocks and stuck the jack stands on top. Just another level of safety. Not too much work to be done and I'll be dropping it back down to bolt in the engine.
Mblizzard
Dec 30 2014, 08:55 PM
While the 6 x6 blocks rarely fail, I always use something to tie them together like a crank strap or pipe strap with a wood screw into each block.
Evil Older Brother
Dec 30 2014, 09:16 PM
QUOTE(PanelBilly @ Dec 30 2014, 06:44 PM)
Click to view attachmentClick to view attachmentRemember your evil older BROTHER in your will.
At least be careful as we really like Julie.
PanelBilly
Jan 4 2015, 01:15 PM
Working on details before the engine is in the way. I have the 14 pin connector back together and secured the brakelines so they didn't rub on the firewall.
Click to view attachmentI also ran the fuel lines up to the regulator and fastened them so they were out of the way. I drilled out the original holes for the lines so some larger grommets would fit. I need to find a clean way to block off the intake for the heater ducting that runs in the longs.
rhodyguy
Jan 4 2015, 01:27 PM
Billy, go to mcclendons and pick up a set of rubber pipe caps and ss screw clamps for the tubes. Next time run the center pieces of 6x at 90*. Less apt too tip over. What purpose does the piece of tubing, between the headers and case in post #182, serve?
Mr.242
Jan 5 2015, 09:40 AM
QUOTE(rhodyguy @ Jan 4 2015, 11:27 AM)
Oil line that connects to the side tank.
rhodyguy
Jan 5 2015, 10:59 AM
supply or return?
PanelBilly
Jan 11 2015, 04:56 PM
I did find some rubber caps at McLendons and they worked perfect.
I need to clean off some of the dust!
Click to view attachmentI got the last of the engine tin mounted up and the throttle cable is done. I need to get the wiring organized and figure out where to mount the regulator.
I posted over at the bird site for suggestions on how to organize the harness. Figured lots of folks over there have done this. Any suggestions?
PanelBilly
Feb 15 2015, 01:51 PM
Mounted the MSD with nutserts or rivnuts (whatever you want to call them), so it could be removed and reinstalled easier. Pain in the ass making the single rubber
mount where the firewall angled back.
Click to view attachmentWhile I was mounting nutserts, I redid the fuel pressure regulator replacing the metal screws with bolts
Should have cleaned off the dust before I shot the photo
