Glad to hear of the positive results from you guys!
To think I was instrumental in saving a car is just fantastic.
With so many weekend mechanics among us, I figured our cars could use a little help.
Here is a list of the fuse blocks and associated parts. You may be able to pick some of the things up locally and in smaller numbers.
fuse block 4 way - 73801
fuse block 6 way - 73803
wire, red, 12 ga GXL cross-link 100 ft. 4114101. You can get this in 25FT rolls also, but different number- see delcity site.
ATC fuse 15 amp 78155
ATC fuse 20 amp 78205
ATC fuse 25 amp 78255
ATC fuse 30 amp 78305
Black single wall heat shrink
3/16" 98030505
1/4" 98032505
1/2" 98033505
Female push on terminal 12-10 ga. (100 min) 193005
Ring terminal 1/4" stud 12-10 ga. (100 min) 453145
Please check the part numbers to make sure they haven't changed. All of these parts came from Delcity.com.
I didn't list all of the nylon ties and sticky pads as it seems a lot of folks don't use them.
If you decide to make up one of these for yourself, please use proper crimpers and secure the ends of the cables near the battery and fuse block to control vibration.
Tom
PS: does anyone know what post #166 means?
