Tom
Aug 22 2011, 06:54 AM
EDIT: 3/06/13
I won't be providing these kits any longer. I apologize to the members who have been waiting. Please feel free to use any info in the thread to help you come up with a fuse solution that meets your individual needs. Parts list on last page.
Tom
NEW INFO FOR EARLY CARS. THEY CAME WITH ONLY THREE RED WIRES!! Two 4.0mm and a much larger wire running forward to the dash area. Please check before ordering.
Last round this summer. Maybe next winter I will do this again if there is a demand.
See pics of the new 4-way and 6-way kits, and the completed install of mine. Kits are designed to go on the outer edge of the battery box, however some have mounted elsewhere. If you have need for longer wires so you can mount yours differently, let me know and we can make that work for you.
Also, please see the two pages of info below. You should be able to print copies.
From the supplier: 4/6 individually fused circuits with connections that enter and exit from the bottom allow this fuse block to be mounted in narrow locations. Clear plastic dust cover is included. Max load capacity for all circuits combined is 50 amps, 65 amps for the 6-way. Connections are made using 1/4" female push-on connectors.
I will open round four as I already have 3 folks who want one. There will be two models, a 4-way and a 6-way, and three stages; 1-basic, 2-connections on and soldered, 3 - with new battery connector.
4-way
stage 1- basic kit $25.00
stage 2- connectors on and soldered and harness heat shrinked $30.00
stage 3- With new battery connector $32.00
6-way
stage 1- basic kit $30.00
stage 2- connectors on and soldered and harness heat shrinked $35.00
stage 3- With new battery connector add $37.00
I will leave this open until 5 June, them order parts. It looks from the last round that you can expect about a month to receive the kit. IE: if I order parts by 6 June, the kits will ship no later than 30 June.
tradisrad
Aug 22 2011, 07:42 AM
I think putting the fuses in place for the always hot wires is a great idea. On the early cars there is a hot wire that jumps from the ignition switch to the turn indicator and it seems that this wire is prone to shorting out (from the 4 steering columns I have and all 4 are burnt), so the fuses may be a good idea to prevent a car from burning.
I would probably be in for a kit.
Cap'n Krusty
Aug 22 2011, 07:44 AM
Why? I have never heard of an instance where those wires have shorted out. Not once in the 38 years I've been working on 914s. Besides it being a non-issue, you'd need fuses capable of handling the entire max load of the subcircuits and their current users at max capacity. Big fuses.
The Cap'n
Tom
Aug 22 2011, 09:50 AM
Cap'n,
A member in Canada just had a fire last week. Fire originated at the 14 pin connector at the relay board. Probably damaged the wiring harness before he could get the batt disconnected. Wiring harness is pretty expensive and a fused red wire would have prevented that.
Fuses shouldn't have to be too big. Max capacity of stock alternator is 55 amps. I think each red wire fused at 25 amps would be sufficient. Do you think that would not be enough? Just trying to get the info needed to make a decision.
Thanks,
Tom
76-914
Aug 22 2011, 10:17 AM
Besides the "cheap insurance" issue, I think the greatest benefit will be separating the wires from the main + cable. When tracing a short, it is much easier if you can check each red wire for current draw, one at a time. I'd take one just to replace this. Yours is much neater.
andys
Aug 22 2011, 11:26 AM
I'm not going to contest the 914 electrical system, but most modern systems have a power distribution module somewhere near the battery that contains fuses, circuit breakers, and assorted relays. I think it's wise to have something similar, and fusing those hot's is a safeguard. For my V8 car, I did away with the red wires, and ran a main hot to a power distribution module (of my own design, but in retrospect I would have rather used an OEM type module) with circuit breakers and relays where needed.
Andys
shoguneagle
Aug 22 2011, 01:20 PM
I have just completed complete wiring of my Sixer including the engine to car items. To protect my electrical since I had the potential for shorts, I fused all the battery wires plus the battery wires I added with 20amp fuses (fuse holders can handle 30amps) for protection. The car is alive with complete electical functioning. Did not have even small sparks on the negative terminal when connecting the battery. Only problems I had was with the turn signals/emergency flasher lights, light connections, and a couple of grounds.
I decided to leave the fuses in on the hot battery wires and so far I have not had any problems. It does make trouble shooting for shorts, etc. easier since the circuit can be more readily traced.
Steve Hurt
r_towle
Aug 22 2011, 03:32 PM
seems like there are two people in this thread that had burned wiring without a good fuse solution in place.
One of the guys has 4 wiring setups that melted.
Seems like a very valid idea.
Rich
AndyB
Aug 22 2011, 04:00 PM
I am interested.
Razorbobsr
Aug 22 2011, 04:31 PM
QUOTE(Tom @ Aug 22 2011, 08:54 AM)
Looking at doing this for my car. Is any one else interested in a kit? I think I can put it together for under $20.00 + $5.00 shipping.
From the supplier: 4 individually fused circuits with connections that enter and exit from the bottom allow this fuse block to be mounted in narrow locations. Clear plastic dust cover is included. Max load capacity for all circuits combined is 50 amps. Connections are made using 1/4" female push-on connectors.
I would run new 12 GA wires from the batt positive to the fuse block ( overkill) and hook up the red wires from the harness with new spade connections to the other side of the fuse block. I think an insulated piece of material about 1 1/2 inches wide could be attached to standoffs alongside the battery to mount this fuse block on.
What do you guys think?
Tom
I can dig it, slicker than most! Bob
wingnut86
Aug 22 2011, 07:37 PM
I'll be in as well...
Tom
Aug 23 2011, 11:26 AM
I'll order some parts and when they get in, I'll put mine together and add pics and some instructions as to what I did. In researching, I've found that 14 ga. wire is good for 40 amps, so really no need to go 12 ga. Of course you are welcome to modify yours as you think necessary. Wire is expensive!!
Later,
Tom
JmuRiz
Aug 23 2011, 11:41 AM
I'd be in...I've got too many red wires running to my battery...this would make it look not so cobbled together.
swl
Aug 23 2011, 05:39 PM
Good initiative Tom. The border is too much of a hassle for me to get involved but I'll happily steal your idea
AndyB
Aug 23 2011, 06:26 PM
QUOTE(swl @ Aug 23 2011, 07:39 PM)
Steve I am an hour from you.
Cap'n Krusty
Aug 23 2011, 06:43 PM
QUOTE(Tom @ Aug 22 2011, 08:50 AM)
Cap'n,
Fuses shouldn't have to be too big. Max capacity of stock alternator is 55 amps. I think each red wire fused at 25 anps would be sufficient. Do you think that would not be enough? Just trying to get the info needed to make a decision.
Thanks,
Tom
It would be interesting to know how and why a fire originated in the 14 pin connector. and why the fuses for some of the circuits that go through there failed to protect the wiring.
The Cap'n
swl
Aug 23 2011, 06:44 PM
QUOTE(Scarlet75 @ Aug 23 2011, 04:26 PM)
We'll talk!
swl
Aug 23 2011, 07:04 PM
QUOTE(Cap'n Krusty @ Aug 23 2011, 04:43 PM)
The Cap'n
The how and why will be interesting.
http://www.914world.com/bbs2/index.php?sho...=141045&hl=The fuses on the relay board won't do anything to protect from a short upstream of the fuse. If there is a short anywhere from the fuse tab back to the battery you are going to get full current flow from the battery to ground. The fuse will only protect if the short is on the other side of the fuse so the grounded current is actually passing through the fuse.
Cap'n Krusty
Aug 23 2011, 07:58 PM
I'm thinking about this a little more. Basically, the only things fused on the panel are the fuel pump circuit and the rear window defroster. If there's a short at the points, say the wire is hooked to the hot side of the coil by accident, it'll fry the wire right back to the ignition switch. Tach wire might do something similar. The backup lights aren't fused until the fusebox, but that would blow before the wires cooked. I don't see where a fuse in the power supply is gonna prevent any of that. I could be wrong here, but it still seems to me you're adding complexity for no really good reason. Good maintenance and care in hooking things up seems to me to be the way to go. If you allow a connector to become hot because the connection is raggedy, you're gonna start a fire.
The Cap'n
swl
Aug 23 2011, 08:20 PM
That fuse also protects the heater fan and the AAR.
All the fuse box that Tom is proposing will protect are the two power leads from the battery to the relay board (pins 12 and 14) and the run to the forward power distribution box. In normal operation these extra fuse should never blow. But of course that is also true for any fuse in any car.
I do agree that care and maintenance should eliminate the need but ...
These connections are getting really old and the insulators are getting old. The risks are rising with time.
The cars are also being maintained by non-professionals who do make mistakes. Sometimes we have to protect the cars against ourselves.
So for a couple of bucks we can protect our expensive wiring harnesses. Not necessary but good insurance. As someone noted earlier, modern cars are being designed with the fuse box right next to the battery. The designers have learned about best practices over the years.
If nothing else the process is bringing to light the dangers of unfused power and people are learning to be careful.
Tom
Aug 23 2011, 09:54 PM
Steve,
Don't think I could have said it any better!
For everyone's info, the 4 red wires being talked about are:
2 4.0 mm wires, one runs to the KEY switch at #30 and the other runs to the fuse block and ties fuses 10, 11, and 12 together on the unfused side to the battery.
The other 2 wires are 2.5 mm and both run to the relay panel in the engine comp. Positions 12 and 14 of the 14 pin connector.
Sent an e-mail to order enough parts for 5 kits today. We will see how long that takes. I want to get mine done with pics and test it before I send any out. Really don't see any problems tho'.
Tom
Aug 23 2011, 10:12 PM
QUOTE(Cap'n Krusty @ Aug 23 2011, 05:43 PM)
It is possible to put the 14-pin connector on while it's off by one position (ask me how i know
That'll get you plenty of smoke in no time if the battery is still connected.
montoya 73 2.0
Aug 23 2011, 10:33 PM
Put me on the list for just one.
Tom
Sep 13 2011, 09:55 AM
I'll be sending out Pm's to those who expressed interest in this kit. Got some parts in and will need more, but need info from those interested first.
Tom
type47fan
Sep 13 2011, 08:36 PM
QUOTE(Tom @ Sep 13 2011, 08:55 AM)
Tom
PM sent.
moparrob
Sep 13 2011, 10:35 PM
Count me in. PM sent.
Tom
Sep 17 2011, 12:41 PM
Finally got it finished and tested.
All good. See first post for installation pics. You may not be able to see from the pics but I used two 20 amp fuses and two 25 amp fuses. Tried the starter, lights, turn signals which are the higher amperage loads, no problems.
If you are interested in this kit, be aware that it requires some rewiring and connection of lugs and proper connections are critical. I always use uninsulated lugs where possible and solder them at the lug end of the wire slightly just to be sure of a good connection. If one is careful, even insulated lugs can be soldered at the lug end without damaging the insulation. PM me if you are interested.
EDIT: the wires in the top picture are for illustration only, they are not the correct size.
Tom
Harpo
Sep 17 2011, 03:38 PM
Good afternoon Tom,
I would also be interested in one of your kits.
Thanks
David
michael7810
Sep 17 2011, 05:20 PM
I would like one kit also if it's not too late. Thanks
JmuRiz
Sep 22 2011, 02:35 PM
I'm interested too...may as well upgrade the system while the engine is out.
VaccaRabite
Sep 22 2011, 08:02 PM
Also interested in a kit.
I'll be going through my wiring this winter.
Zach
Gint
Sep 23 2011, 05:23 AM
I'm interested also. If for no other reason than I hate that clump of brittle old wires going to the battery terminal.
Tom
Sep 23 2011, 07:22 AM
All of the kits have been spoken for. I would have to order some more parts to get more kits together. I'll get back to all interested later.
If any of the club venders would like to add this to their product line, let me know and I will send you all of the info. Ordering in small numbers is costly and time consuming.
Thanks,
Tom
wingnut86
Sep 23 2011, 09:01 AM
jimkelly
Sep 23 2011, 10:16 AM
Sep 23 2011, 11:33 AM
QUOTE(Tom @ Aug 22 2011, 05:54 AM)
I like it! Where do i sign up?
Tom
Sep 23 2011, 02:03 PM
I had no idea there would be such a demand. My first kits used the two white standoffs made out of solid PVC and machined on my lathe. The following kits will have these made from PVC pipe. If that is a problem for anyone, let me know.
The following have said they want a kit.
wingnut86
Type 47 Fan
moparrob
76-914
michael 7810
Panel Billy
rwilner
Harpo
Jmuriz
Vacca Rabite
Gint
Sir Andy
Scarlet75
bigkensteele
Rleog
I will be ordering enough parts and wire for these kits over the next few days. Please bear with me and I'll get them ready as soon as I can.
Tradisrad and Montoys 73 2.0 , yours are ready to ship when the funds are received.
Payment is check or money order. I'll PM all involved with the address some time next week.
Thanks,
Tom
AndyB
Sep 23 2011, 04:12 PM
Pretty sure I said I was interested when this first posted never got that pm
See post #9 also SWL expressed interest. So where do we fall in this?
Rleog
Sep 23 2011, 06:23 PM
If you haven't ordered the extra parts yet, please add me to the list. If I'm too late, tough luck for me.
bigkensteele
Sep 23 2011, 06:53 PM
Tom, I just saw this thread. I would also be interested for the same reason as Gint. I hate looking at the hillbilly wiring on my positive post. Please put me down for one if you haven't already ordered the parts.
Thanks,
Ken
moparrob
Sep 24 2011, 10:31 PM
Is your panel basically the same as these pre-wired ones?
BMC fuse panel
Ian Stott
Sep 25 2011, 11:41 AM
QUOTE(Cap'n Krusty @ Aug 23 2011, 09:43 PM)
Cap'n,
Thanks,
Tom
The Cap'n
I was disconnecting the 14 pin connector so I could clean up the board and the area around it, as soon as I touched the connector it got hot and I tried to pull it off the board but it was too hot to touch and then a puff of smoke and then flames, ran to evacuate the house and then went back to the garage and got the neg battery cable unhooked, so much smoke and it stinks!
Ian Stott
Moncton
Canada
Tom
Sep 25 2011, 01:28 PM
Ian,
If your key was in the OFF position, the only power to the relay board is the two red wires from the battery, which are unfused.
Tom
Ian Stott
Sep 25 2011, 01:31 PM
QUOTE(Tom @ Sep 25 2011, 04:28 PM)
Ian,
Tom
Key was off, never again will I play with electrical without unhooking the batt. I am looking now at the different battery isolators, seems like the one Porsche sells is the one to get.
Ian
FourBlades
Sep 26 2011, 08:04 AM
I am interested in getting a kit.
I also want to run my headlights and driving lights off relays.
I'd like to run a new power line from the battery to the front of the car to 3 relays
to power the lights (low, high, driving). It makes sense to me to fuse this line
Would that require 5 fuses in a block?
Thanks,
John
stugray
Sep 26 2011, 01:02 PM
I like the concept & that looks really clean, however why not use just one of these:
http://www.vteworld.com/content/electromec...anl/anlfuse.phpThey even have them with integral voltmeters:
http://www.sears.com/shc/s/p_10153_12605_S...u=SPM5039089501oohhh:
http://www.parts-express.com/pe/showdetl.c...tnumber=263-624I would run one wire directly to the starter, then put a 50 Amp fuse for the rest of the car.
Stu
Tom
Sep 26 2011, 01:15 PM
OK, the parts are on order and the following folks have PM's
wingnut86
Type 47 Fan X
moparrob X
76-914 X
michael 7810 X
Panel Billy X
rwilner
Harpo X
Jmuriz
Vacca Rabite
Gint X
Sir Andy X
Scarlet75 X
bigkensteele X
Rleog X
Thanks,
Tom
moparrob
Sep 26 2011, 01:42 PM
Thanks Tom, PM received. I was hoping you would respond to message #41 above so I could get a better idea as to the design of your fuse block and how it may differ from that pictured. Thanks.
Tom
Sep 26 2011, 06:06 PM
Moparrob,
The fuse block looks the same, but the wires are smaller. I am supplying two 14 ga. and two 12 ga. wires. Did you not get the pics?
E-mail me at t.powell@wavecable.com and I can send some more pics of what the kit includes and how it looks installed. Installed pics are on the first post of the thread.
Tom
moparrob
Sep 26 2011, 09:14 PM
No problem. Got it. I'll send a check out as soon as I get some stamps (I am a Paypal addict) tomorrow.
Thanks.
