QUOTE(76-914 @ Jul 26 2014, 08:00 AM)
Looks great, Ross. BTW, re: P0691; in that you are running single speed fans I wonder what would happen if you connected both grounds (hi-lo) together. Maybe the ECU doesn't see that ground. FWIW, I had P0037 code before I dropped the engine from the donor. No CEL's from the missing 3rd 02 sensor? Great job, Ross. Enjoyed your build.
This was a great idea! I combined all three Fan relay grounds so the fan will kick on when any of them satisfy their loading conditions. It works beautifully. The fan kick on fairly infrequently and then kicks back of after a minute or two! Great tip!
QUOTE(Chris H. @ Jul 26 2014, 08:00 AM)
Sweet! How's the power?
You can probably search what those mean on a subie site and see how they handled them. rs25.com has a lot of conversions. I'd check the "high" circuits for sure, sounds like too much juice going through them but it might mean something totally different. Also that o2 sensor connection should be checked...loose or frayed wire maybe. You want that one good so the engine runs right. Did you clear them off and re-run them by chance?
BTW your tach is upside down
(I know, I know).
The power is intoxicating! I rarely put the hammer down in first because its over too quickly. In second when you mash it the power just keeps coming, with the most seeming to come in the 4-6.5k range!
I haven't done any more work with the codes, but once I ground out the fuel level sender and finish the fan wiring I'll clear them and see what comes back.
The engine has been running flawlessly, I put 50-60 miles on it this weekend with short trips and tweaks in between and plan to continue putting on as many as possible prior to RRC!
On a downer note, the remoted gauges don't work. I'm going to pull them out of the dash tonight and make sure I had them hooked up properly, but I wasn't getting any movement out of them at all. for now I'm driving with the subie gauge pack in the passenger footwell and mostly just gauging speed by flow of traffic!
