QUOTE(mgp4591 @ Dec 13 2016, 09:59 PM)
Some good progress there Ross! What type of air cleaner setup are you planning on using on those stacks or are the stacks staying?
I'm planning on running the ITG foam filters, but I may have to fabricate some custom mounts (foam is only 100mm tall and the stacks are 150mm).
QUOTE(Chris H. @ Dec 13 2016, 10:44 PM)
There are several really good ITB threads on Pelican.
I'm just about to go Megasquirt 3. Pretty excited about it.
If you have any questions on all the fittings and stuff for the clutch setup just let me know. You'll be very happy with the hydraulic clutch.
I'll have to check out those. I think the hardest thing will be figuring out how to run the cams, since they are truly variable, not just on/off.
I already followed your hydraulic clutch procedures when we put it in my roommate's car. Same engine and he blows me away because his shifts are so much faster and smoother than mine!
QUOTE(JRust @ Dec 13 2016, 11:40 PM)
I'll take a transmission rear diff block off plate! Let me know how much & where to pay you
You got it!
QUOTE(76-914 @ Dec 14 2016, 08:25 AM)
You'll wonder why you didn't do it in the first place. Nice design.
Thanks Kent! I'm looking forward to the improvement in driveability!
QUOTE(BigFour1973 @ Dec 14 2016, 09:09 PM)
I'd take a clutch slave bracket and center diff plate. Any chance you'd produce the cable mount bracket for the gear select rod
My friend Ray is working on a design for the shift cable mounts. I hope to have a prototype in a week or two!
QUOTE(914forme @ Dec 15 2016, 11:21 AM)
So how did it do with a hard load?
It did great. Only time it got hot was when I was stuck behind slow traffic on steep grades. Temps climbed to 220 on the slow extended climb out of Denver, but never got that hot again.
I will be rerouting my coolant lines (currently inside the longs) to under the car and I'm hoping the reduction in 90° bends will improve flow and reduce temperatures further.
QUOTE(greggearhead @ Dec 15 2016, 11:25 AM)
That things gonna sound wicked-cool.
Thanks Greg! Did you end up getting your EZ30 sold? (For anyone reading, I built a harness up for an EZ30 that I sold for Greg's Bus conversion).
