I do scrape with a screwdriver, my special scraping screw driver
, but I was saying you should forcibly poke at the recess there to see if it will go through. You really aren't hurting it if it does go through, but if it is solid, like my 'heckhole' is, having jabbed it some, I feel better about it now, even through it is pitted.
I was thinking more along the lines of a metal brush, a welding or grill brush. I'm not a fan of wire wheels on angle grinders. You will make good metal thin that way, and tear right through marginal areas. The acid will turn the rest, convert it, encapsulate it, whatever it does, turns the pits black. The products have zinc in them, too.
Etching primer is just primer that has similar chemical actions, but not as good as doing the whole etching thing, like shampoo and conditioner in one, but can't hurt to get that kind if you're going rattle can, "etching" or 'metal' primer.
There are many levels of dealing with it, depends if the screwdriver goes through. I would poke at the front of the jack post plate that is below there, too. That can hide some nastiness sometimes. I would take a good look at the suspension console ear on that side, too.
Here's mine to give you some idea what can go first. I'll link the image, it is pretty grotesque.
http://www.914world.com/bbs2/uploads_offsi...291433480.1.jpg
