I think that's a little too bright for running lights. For brake lights, they could be as bright as the sun! Little cars + weak brake lights = disaster.
Keep at it. Those are awesome.
palmer_md
Dec 21 2013, 10:52 PM
QUOTE(CptTripps @ Dec 21 2013, 04:35 PM)
I agree this project is awesome. Keep at it. The key in my view is the difference between the driving light and the brake light. I've seen a few cars with led lights that the driving light is so bright that the brakes are not as noticeable. Need to have a toned down driving light and a bright brake light.
stugray
Dec 22 2013, 10:33 AM
They make adjustable "buckpuck" drivers so you could just turn them down to where you want them.
Spoke
Dec 22 2013, 07:05 PM
The Buckpuck was one of my design wins at my last job. The MP2483 is the buck converter in many of the Buckpuck modules. LEDdynamics manufactures these in Vermont. Great little company in a beautiful part of New England.
I've been thinking about using a buck converter for this application; either a module like the Buckpuck or roll my own.
stugray
Dec 23 2013, 12:23 PM
Spoke - Cool that you worked on that. Are you an EE and do you still do desgin/layout work?
I have also always wanted to make a brake light module with a MEMs G-force sensor in it.
If you press the brakes lightly (low G-force) the light comes on like normal. If you stomp on the brakes (high G-force), the Brakes lights Blink furiously...
Dec 23 2013, 12:32 PM
So, how much for a complete kit?
McMark
Dec 23 2013, 06:29 PM
QUOTE(stugray @ Dec 23 2013, 10:23 AM)
Hey, I thought the same thing! Only, I would do it with two of the stock brake lights switches set to operate at different distances from the pedal. Not quite as fancy as a G-force sensor, but would be much easier to set up.
mikesmith
Dec 23 2013, 06:41 PM
I've worked a bit with the MEMS sensors; they're a bit annoying, but I think probably more repeatable in terms of measuring deceleration than any sort of correlation with pedal travel...
BMW call their system "brake force display"; the BFD2 behaviour is pretty neat, even ties into the ABS:
Blinking brake lights -> "I am braking too hard" 8)
Spoke
Dec 23 2013, 11:23 PM
QUOTE(stugray @ Dec 23 2013, 01:23 PM)
Yep, EE with Masters from Lehigh U. I design, lay out, and assemble circuit boards. Most we have completely assembled but others we do by hand.
I laid out and assembled the 5mm LED PCB here. If you want to build something we should talk. I've already done a PCB for another member.
The MEMs sounds cool but I've been concerned lately with complexity with brake circuits with digital logic.
Spoke
Dec 23 2013, 11:27 PM
QUOTE(SirAndy @ Dec 23 2013, 01:32 PM)
I want to do about 3 sets for folks of this 5mm brake light to get some out there to see that they work ok. Component cost is always an issue with low volume and with paying myself below minimum wage to assemble these will mean these first sets of 2 boards will be $95 for a pair including shipping CONUS.
Spoke
Dec 23 2013, 11:31 PM
QUOTE(CptTripps @ Dec 21 2013, 07:35 PM)
I've cut the current down about 50% for the running lights. I'm running a burn-in test tonight as I plan to power the running light level overnight at 13.5V.
I over-estimated the voltage drop of these diodes based on the datasheet parameters. Instead of 2.5V per LED I'm seeing about 2.0V per LED.
mikesmith
Dec 23 2013, 11:37 PM
This is the line of thinking that's led to the current ECM + peripherals architecture in most modern vehicles; most of the complex logic and sensing is concentrated in a small number of high-cost components centrally located in the vehicle, and then things like lights are just as smart as necessary and no smarter.
I've been tinkering with the idea of a 'body' computer to host this sort of thing, plus a pair of LIN busses to hang stuff like lights and switches off. It's probably more complexity than most folks would put up with, but when you look at the pile of stuff that some people add (the entire Dakota Digital catalog, just for starters) it starts to look attractive.
A fairly 'dumb' LIN node with a handful of in/out ports could be done with a BoM in the sub-$10 range using one of the integrated system basis + micro SoCs...
Speedmster
Jan 13 2014, 02:32 PM
Spoke, How did your test go back on the 24 Dec?
Spoke
Jan 14 2014, 11:29 AM
The overnight test of the taillights went well. No issues.
I now have both brake lights on my 914 converted to the low power LED design with 63 5mm LEDs running about 5mA each for tail lights and about 45mA each for brakes.
Taillights are a bit brighter than the bulb and are much more focused behind the car. I need to take a few more videos of the tail and brake lights for comparison.
Been working on the high power design with 20 Cree XBD LEDs. These things are very bright. I've already cut the brake current from 300mA each to 250mA each and I think I need to go lower.
The high power design runs cooler than the low power LED board since I'm using a switching converter to do constant current. Pretty neat how the circuit draws less current at higher voltages since it's putting out constant power.
I want to get this one mounted in my 914 and see how it looks.
CptTripps
Jan 14 2014, 12:10 PM
Those look brilliant. Can't wait till a full set is available for purchase.
ClayPerrine
Jan 14 2014, 12:15 PM
QUOTE(CptTripps @ Jan 14 2014, 12:10 PM)
<insert rimshot here>
AE354803
Jan 14 2014, 12:53 PM
QUOTE(Spoke @ Dec 23 2013, 09:23 PM)
No way! I'm an ME w/ masters from Lehigh. Looks like a nice winter project.
Andy
JmuRiz
Jan 14 2014, 02:59 PM
Off topic: Lehigh, good wrestling team!
Spoke
Jan 15 2014, 04:37 PM
These Cree's are super bright. I'm off by a factor of greater than 5 in current.
This is the shadow of the brake setting. It's way way too bright. It's dangerously bright. At 15 feet, one cannot look at this light and its already in the 914 taillight.
OK, I think I have some good levels now. I need to check the relative brightness with the other 5mm LED unit as well as the standard 1157 bulb.
For the taillights shown below, I'm running the LEDs at 2.5mA. For the brakes, I'm running the LEDs at 35mA. I started at 300mA.
The Cree brake unit is now running at 1.4W. This is compared with the standard 1157 bulb at 21W.
Harpo
Jan 15 2014, 06:28 PM
Looks good. I'm inclined to believe that they can't be bright enough. Our tail lamps are lower than most cars and if those following us are indeed one car length per 10 MPH then the brightness should not be a problem. IMO
Thanks for the great work! I can't wait to get a set.
DAvid
CptTripps
Jan 15 2014, 07:43 PM
David: That may be true, but there comes a point where you can flash peoples eyes and cause spots where they CAN'T see. That's REAL bad when they're driving behind you. ;-)
Spoke
Jan 15 2014, 11:11 PM
QUOTE(Harpo @ Jan 15 2014, 07:28 PM)
I thought the same thing when I started this design. High power LEDs nowadays can put out ridiculous amounts of light.
To compare output levels, I have one board with 63 of the standard 5mm LEDs running about 50mA in each LED. This board with 20 Cree's running 35mA puts out more light than the 63 5mm LEDs.
The test I did today with 200mA produced so much light that was painful to look at. I stood 20 feet away from the board installed in a 914 housing and I couldn't look at it. The shadow produced on the wall looked like a powerful red spotlight.
I will adjust these to be as bright or brighter than any vehicle brake lights I see. The main idea as you point out is to make our 914's be seen under braking.
Harpo
Jan 18 2014, 07:40 AM
Obviously you have first hand experience with how bright these are and therefore trust your judgment. Looking forward to having this upgrade in my car.
Thanks again
David
McMark
Jan 18 2014, 08:07 PM
Could you do a few milliseconds of bright flash and then step down to a safe level?
r_towle
Jan 18 2014, 08:14 PM
QUOTE(Spoke @ Jan 16 2014, 12:11 AM)
Are you doing something for the 911? Having pulled up behind a few I am concerned the taillights are far to dim
Spoke
Jan 19 2014, 12:19 PM
QUOTE(McMark @ Jan 18 2014, 09:07 PM)
Neat idea. Yes, this would be easy to do. How long of brighter flash would be good? 1/10 sec? 2/10 sec?
Spoke
Jan 19 2014, 08:02 PM
QUOTE(r_towle @ Jan 18 2014, 09:14 PM)
I plan to do one for the 911. They have really small brake lights.
Here's the latest 914 brake light. I stretched the board vertically to fill the brake light cavity and moved the LEDs to the edges of the board to get a larger light footprint. LEDs shine in the direction you point them. The lenses don't have a very wide dispersion so these will look larger especially at night.
I added the leading edge bright flash when the brakes are applied like Mark suggested.
The circuitry on the back really shrunk since I didn't need all the current the first circuit was designed for. I still use a big ass DPAK FET where I think I could have used a converter with a built-in FET.
Plus I changed from a boost converter to a buck converter. Buck converters are more suitable to handle transients on the brake/taillight wires than a boost converter.
Harpo
Jan 19 2014, 08:45 PM
Looking good
Cairo94507
Jan 19 2014, 09:27 PM
I really like the idea of a brighter flash for a couple milliseconds and then stepping it down to just bright.
jcd914
Jan 20 2014, 01:11 PM
QUOTE(Spoke @ Jan 15 2014, 09:11 PM)
There are legal limits on the light output from both brake and running lights, something in the range of 100-300 candela for brake lights in the US.
Jim
Speedmster
Jan 20 2014, 03:32 PM
QUOTE(jcd914 @ Jan 20 2014, 02:11 PM)
Jim
I'm not seeing a maximum limit. I see a minimum limit. I'm looking a NHTSA Table IV-a—Effective Projected Luminous Lens Area Requirements. Then again I'm not even near expert on reading regulations. Anybody know how to read this stuff?
Maybe that's why the "NOT FOR ROAD USE" printed on the board.
Spoke
Jan 20 2014, 04:42 PM
Been contemplating a way to secure the board to the housing with minimal effort.
Mikesmith suggested a clip that would be held in place by the taillight lens and would just clip onto the divider on the housing and the board and thus hold the board in place.
So I used some sheet brass to mock up such a connection.
Here are the pieces. Looks like it will work just fine. I will look into getting these made in plastic or metal.
Great work man. That's a seriously great project...expertly executed.
monkeyboy
Jan 23 2014, 09:20 AM
Beautiful!
Spoke
Jan 24 2014, 12:04 AM
Here's a comparison of the Cree LED board and the 1157 bulb. The first two flashes are the taillights and the last 3 are brake lights. Quite an improvement over the 1157 bulb.
For braking, the 1157 bulb is burning 21W while the Cree LED board is burning only 1.4W. One can also see the immediate light of the LED vs the 1157 when the brakes are pressed.
I had put in a circuit to flash the brake lights 4 times the intensity for about 1/4 second but it's not working in the car. Worked nicely in the lab with short wires to the power supply. The longer wiring of the vehicle must be slowing the rising edge of the voltage to the lights.
This set of LED brake lights is now for sale. This is the only set available with these 5mm LEDs.
I wanted to try these out before I had the Cree LED board going. I've been running these in my car for the last several weeks.
These work well and put out a lot of light. See posts 186 through 196 for the light results.
This is the only set. Just looking to cover my cost at $55 + shipping. Includes 2 boards with pigtails and light bulb bases as shown, and 6 clips.
Real simple installation: pull bulb, insert bulb base, insert clips into boards, clip onto existing enclosure frame.
Respond to this thread if interested in purchase.
Jeffs9146
Jan 24 2014, 01:05 AM
I am in for a set!
Speedmster
Jan 24 2014, 06:28 AM
QUOTE(Spoke @ Jan 24 2014, 01:31 AM)
Spoke, is there a chance you could shoot a video or take a photo in broad daylight about 20-30 feet behind the car? Interested in how the LEDs preform in the daytime also. Similar to the photo in post #196 that was at night from the rear of your car.
Cairo94507
Jan 24 2014, 08:22 AM
Wow- this project is moving forward very nicely. That is looking nice. I too would like to see some video from behind during the daytime. Thanks for the hard work and dedication.
Spoke, those look good man! Both Cree and 5mm show pretty good.
I would like to purchase the 5mm LED Lights. PM sent.
Spoke
Jan 25 2014, 01:47 AM
QUOTE(FlatIV @ Jan 24 2014, 05:48 PM)
Are the Cree LED's red?
Yes. The p/n is XBDRED-00-0000-000000701.
Spoke
Jan 25 2014, 01:59 AM
Just toying around with a different LED pattern. Instead of a grid of 5 x 4 LEDs, what about a box pattern. More like connected lines outlining the brake light.
mikesmith
Jan 25 2014, 02:42 AM
I mixed the box and fill when I was playing with the smart LEDs; at distance it's hard to make the box out - would have worked better with clear tails and double-wide.
cary
Jan 25 2014, 09:35 AM
I'm in for a pair of 5mm when they're available.
Rotary'14
Jan 25 2014, 11:15 AM
QUOTE(Spoke @ Jan 24 2014, 11:59 PM)
How about running lights as the "box" perimeter and the whole thing for brakes? I think that would look cool.
Spoke
Jan 26 2014, 06:12 PM
Finally got the costs figured out for the 5mm board.
$90 + shipping.
This will include: 2 PCBs with 64 LEDs each. Pigtail with 1157 base to plug directly into existing bulb socket. 6 clips to mount the boards to existing light housing.
New PCB is larger than the prototype as the LED grid grows by 1 to 64 LEDs in an 8x8 pattern instead of the 7x9 with the LEDs spread out a bit more to provide a larger lighting footprint.
$90 + shipping.
