>> great. Thanks for the info. Does anyone know of a source for the grey hubcaps?
> PORSCHE ? I guess these parts are still available.
Ah, I was looking up the wrong part number. I see now. Yes, readily available:
http://www.sierramadrecollection.com/store...etail&p=432I doubt that silver matches my wheels exactly though...
> Another question from my side. I saw at the second glance that you cleaned the side markers...why? That's a typical nice part of the US-equipment. Isn't it now a problem if you want to participate in a concours?
I just think those warts are super ugly, and would never have been added to the cars unless the US mandated it.
And I'm not too worried about "concours". My plan for the car is just to make a really nice, original driver. Some parts are probably over restored for just a driver, but it's hard for me not to clean things up as it goes back together. But it's really far from 100% concours correct.
Here is my current list of "what's not correct":
- Mahle wheels. These are correct for a 914-6, but this car came with steel wheels.
- 185 tires (should be 165 with the Mahle wheels).
- Original cylinders bored to 81mm, new 81mm pistons. Not 80mm, but heads did not have to be machined. So in theory, someone could go back to 100% original with new P&Cs if they really cared. 81x66 = 2041 cc, so it's still a "2.0".
- "E" cam (original have "T" cams, but if someone really cared, this could also be reversed 100%.
- Added later Carrera chain tensioners. Not original, but stupid not to add them (IMO).
- Added front sway bar (Tarrett).
- Bilstein shock and struts.
- Porterfield brake pads (not OE).
- Used an aftermarket washer pump, not OE.
- H4 headlights, not sealed beam.
- Not OE seatbelts
- Small triangle headlight plate is plated silver, and should be zinc plated.
- Gas cap is yellow cadmium plated, but should be zinc plated (I think). But it looks better this way IMO.
- Gas cap shroud thing is held in with socket cap screws, should be hex screws (it's all I had).
- Momo prototipo steering wheel with adapter.
- Power Hershmann antennea (original was manual).
- Used black undercoating on bottom of car (original was grey).
- Euro front and rear tail lights on a US car.
- Several parts powder coated, but original was paint.
- Several bolts/washers are zinc plated, and should be yellow cadmium (98% are correct).
And I'm probably missing a lot of other things. See anything else? Feel free to tear it apart!
On a side, note, I don't think I'll ever try to do a "correct"/"original" restoration again. I just don't enjoy being restricted to find the right bolts/coating/etc. I'd just rather put something in that looks nice and works well and not worry about it. It was more fun to be creative when building my orange 3.6 car.
-Steve
