I had a nice day cleaning and putting some parts back on the car. It was a good change of pace from metal work. The steering rack was one last parts I pulled off the car so it's appropriate that it should go back on first. From the grease around the inspection plate it's apparent it had been leaking so I opened that up and filled it with gear oil. Sealed that up and cleaned it well. The boots responded well to a good treatment of Armor All. Now putting that rack back on without a helper was a challenge. I used a couple of bungie cords to hold it in place while I attached the steering column links. I stripped the key switch-turn signal assembly off the column before re-installing. That makes the column a little wibbly-wobbly at the steering wheel. I'll need to find a bushing to tighten that up. Then I started disassembling the front suspension. The tie-rod ends are shot and will have to be replaced. I got those off and then took off the rotor-hubs. The bearings on those looked good but the rotors are heavily worn. That's okay, I've got new rotors and bearings from Just Porsche Parts. Then I pulled the caps on the strut tubes and guess what... blue KYB shocks but they're both shot. I was able to free up the adjuster screws on the torsion bars and got those off. Those bushings will need to be replaced. The last thing I did was get the ball joints out of the control arms. I had to consult a book to see what was going on there with the threaded ball joint. They where really corroded but after a lot of PB blaster and a big pipe wrench - I was able to get that large nut off the ball joint. So I'm looking at all new bushings, tie rod ends, ball joints and shocks. Ouch!
