At the last autocross we raced the 914, I had two issues that needed addressing...
One, I suspect the engine is getting hot without the engine console tins. Readers will remember I removed those because of bad rust holes.
Two, the alternator belt was coming off just about ever lap.
Now those two issues may be related. If the engine compartment is getting hot, the belt could be getting soft and loose. I repeatedly checked tension and there's just no way to get a bar in between the tins and really pry on the alternator. I have purchased a Gates belt with kevlar that supposedly gets tighter with heat. The current belt is a new Conti.
I read several threads where it was pointed out that the oil temp gauge is not a good way to monitor engine temps. So I ordered a VDO head temp kit from Pelican. But before I took delivery on that, I went ahead and got an electric cooling fan. 11" was the smallest at the local O' Reily's and it actually fits fairly well. I mounted it under the grill because the drip pan is off on this car. Two holes with 3/8" pop rivets into the back edge of the grill frame. And then two tie wraps on the front side. I installed with the fan blowing up thinking that heat is going to rise anyway, best just move it on out of the engine compartment. I used a switch panel I made back in the winter for bench testing, mounting that under the driver side vent hole. Hookup was very easy as I've got terminal strips for hot and ground under the dash with open lugs.
Last weekend I got the head temp gauge kit. I thought maybe the gauge would fit nicely in the vent hole but it's about 1/4" too small. So I fabricated a bezel out of sheet metal. The instructions call for a 2 1/16" hole but a 2" hole saw cut a perfect size hole. I cleaned and primed that. This evening I installed the gauge and wiring. I put the ring terminal sensor on #3 spark plug as that's the easiest to get to and directly above the exhaust collector. The hardest part was fishing the connectors through the tunnel, along side my custom harness and into the engine compartment. The sensor or gauge does not require 12V so I'm not sure you should cut, crimp or splice that harness. The wire itself may be passing the thermal temp to the gauge.
I tested the engine and the gauge works great. Climbing right up as the engine warms. It settled in at 350F in the garage on a fairly cool evening. I kicked in the fan but didn't notice any change in temp so I'm not sure that is effective. I plan on racing this weekend so we'll see how it goes outdoors, warm day and higher revs.
