william harris
Apr 17 2005, 11:42 AM
Suzie and I are gonna go roll the car back into the garage now.
william harris
Apr 17 2005, 11:43 AM
Last one for now.
william harris
Apr 17 2005, 09:19 PM
Now I'm working on this relay. The big push & pull into the engine compartment comes next.
william harris
Apr 18 2005, 04:14 PM
It's probably news to the rest of the world, but today is a state holiday in Massachusetts - Patriot's Day!!
So, Nick and I got busy pulling the main wiring harness into the engine compartment. I learned the hard way that the branches must go in a precise pattern so that everything can be pulled thru - the logic relay panel wires must go in last. Here's Nick very proud of helping me today. I was in the engine compartment, I would feed a wire thru to Nick, he would attach the wire with a wire tie to the wire branch and feed it in. Took about 1 hour to do.
william harris
Apr 18 2005, 04:16 PM
I bundled all the wires together and then used electric tape to tape everything together tight and secure to pull thru the tunnel and out the engine fire wall.
william harris
Apr 18 2005, 04:19 PM
I took a break from rewiring the logic relay panel under the passenger seat to post these pictures. That will be finished today. Learned you must be careful pushing in the small clips to remove, cause you gotta push them back out (very damn small they are) to reattach! Bowlsby, your work on the harness is spectacular. You repaired several bad areas around the logic relay panel (and removed the seat belt interrupt starter circuit!!). Man, it is finally almost entirely back into the car.
william harris
Apr 18 2005, 04:21 PM
My oldest son wanted to get into the picture as he left to go back to college today. Now he wants to know when the 914 will be back together.
william harris
Apr 18 2005, 04:23 PM
So I pulled everything thru and put the bundle in the trunk for today. Next into the engine compartment.
william harris
Apr 18 2005, 04:24 PM
Here is where I stopped for the day. More to come.
Kargeek
Apr 18 2005, 04:34 PM
Patriot's Day..I called my client back in Boston and they had the day off. If I have known Iwould have taking off the day too.
Gteat job! Takes me back to 20 years ago when I did mine. Keep up the pictorials!
Cut some black vinyl tubing and place over the hold down tabs for the wireing harness- as the factory did.
DH
william harris
Apr 18 2005, 06:24 PM
Thanks Karqeek, I have a bag somewhere in my garage with all the hold down tabs I removed. Some can be reused. A lot will have to be replaced because they were painted with previous repaints without removing anything.
kenpolives
May 22 2005, 04:23 PM
Isn't it time for more pics????????????????
william harris
May 22 2005, 07:18 PM
Well, we have continued to try to make small progress. Eric (Partsman here) Sanders hooked me up with all new factory seals. Here is where things stand.
william harris
May 22 2005, 07:20 PM
New hood seal is place (OK Eric don't tell anyone I installed it upside down), new bulkhead seal, new dash/Windshield seal, wired in Pilot lights, and lights are now in and waiting only for screws for chrome surrounds. Working on the trunk is almost complete.
william harris
May 22 2005, 07:22 PM
Inside, all new seals for the trunk. Also, you can't see the new dog bones used to mount the bumper. Inside the trunk are small hard parts to mount the sub-dash, it should be ready to go in this week.
william harris
May 22 2005, 07:24 PM
Let me tell you pushing those factory seals in place takes a lot of muscle power - the rubber has a metal band inside and you really got to push, push, push. A couple of the pieces are about an inch longer than needed and will have to be trimmed.
william harris
May 22 2005, 07:25 PM
I am starting on the engine lid tonight and setting up a work bench to build up the door. All the hardware, seals, channels, etc. will be replaced or renewed.
william harris
May 22 2005, 07:27 PM
My plan is to build a small work bench that will support each door on a couple of inches of foam padding and then add the window and door hardware, glass, etc. and then hang the door after they are completely assembled. Will let you know how that works.
william harris
May 22 2005, 07:29 PM
Also put in these new seals on the body for the doors. These (like almost every other seal) were missing from my car when I got it three years ago.
william harris
May 22 2005, 07:32 PM
Put these in just to see how they fit. They will come out later as the whole assembly goes in.
william harris
May 22 2005, 07:34 PM
I had saved the old "hoses" and just bent these to the same shape. Putting this stuff in under the cowl is definitely a two person job and will have to wait for a weekend when Eric can come over to help me.
william harris
May 22 2005, 07:35 PM
So does your wife get pissed when you bring car stuff in the house and put it on the dinner table?
william harris
May 22 2005, 07:36 PM
Next week my goal is to have the dash back in the car and start on the interior.
CptTripps
May 22 2005, 08:36 PM
I spent the last 2 days replacing all the seals too. The one I hated was the windscreen. I thought the trunk was fairly easy...THAT one is a BITCH!
Looking great man!
william harris
May 22 2005, 08:42 PM
Yeah, haven't gotten to the windshield yet. Got to find all the chrome guide pieces and fire up the silicon can!
CptTripps
May 22 2005, 08:46 PM
| QUOTE (william harris @ May 22 2005, 09:42 PM) |
Yeah, haven't gotten to the windshield yet. Got to find all the chrome guide pieces and fire up the silicon can! |
I used Butle tape between the car and the chrome strips. Then I used White Lithium (sp?) grease on the seal, and it slid RIGHT in! Makes it ***A LOT*** easier than just silicone.
william harris
May 22 2005, 09:27 PM
Thanks for the advice. Now I know what I will be doing next weekend.
Any issues with clean up with the grease?
Doug Leggins
May 22 2005, 10:02 PM
Looks like its going together very well! And your moving at a quick pace -good job!!
| QUOTE |
| Let me tell you pushing those factory seals in place takes a lot of muscle power - the rubber has a metal band inside and you really got to push, push, push. |
Those seals really suprised me too on how difficult they can be to install. The one that goes on the bulkhead between the rear trunk and engine bay is the one that made my thumbs hurt for 2 days. Lots of push required to get that one on!
Keep up the great work, the car is looking fantastic!
redshift
May 22 2005, 10:06 PM
Sure is a nice looking job there.. I like the color!
Wow.. I need to wash my car.
M
MoveQik
May 22 2005, 10:21 PM
That car is sick! It is gonna be awesome when you are done. Hell...it is awesome now!
MecGen
May 23 2005, 05:15 AM
This is a cool thred
I just had a flood of memories when I finally got mine back together, rubber, trim...cool eh ?
GOOD TIMESlater
Joe
william harris
May 23 2005, 06:02 AM
Thanks for all the kind words. This site keeps me inspired and moving in the right direction. My goal is to be ready to drive to WCC3.
partsman
May 23 2005, 06:36 AM
| QUOTE |
| Those seals really suprised me too on how difficult they can be to install. The one that goes on the bulkhead between the rear trunk and engine bay is the one that made my thumbs hurt for 2 days. Lots of push required to get that one on! |
Ah, now I know why William had me do that seal...I couldn't get the divets out of my thumbs for quite a while...
I've seen this car in person, and it is almost undescribeable....it's like watching the factory thirty years later...what a rush!!
Eric
CptTripps
May 23 2005, 07:08 AM
I've been using a rubber mallet to 'cooerse' those seals into place. Light tapping did the trick.
No issues at all with the grease. It sprays on with a tube, and I use a rag to get a grip on the seal.
Another trick with the Windscreen seal was to use some of that Wurth adhesive, and after you get it on, latch the FRONT of the targa in place. That REALLY get's it on there good. Leave it on there overnight, and it'll be sealed up great.
william harris
May 28 2005, 06:02 PM
So today I decided to try to finish off the front end, at least with the parts as they stand today. The driving light/horn grills must be replaced, as well as the clips and screws. Also, this winter I intend to pull the bumpers off and rechrome them. But for now, they are good to go. I am very happy with the way the Pilot lights look and can't wait to fire them up.
redshift
May 28 2005, 06:04 PM
Thanks Mr. Bill, your thread has inspired me to wash my car.
M
william harris
May 28 2005, 06:05 PM
Chrome on the bumper is very good, but some idiot prior owner drilled three large holes thru the bumper (duh?, rather than remove the bumper - hey that takes four bolts and five minutes
) to open the front lid when the cable broke. Well, when I rechrome the bumper I will have them weld the holes up before the new chrome goes on. Another view.
william harris
May 28 2005, 06:07 PM
Friday, Partsman (Eric Sanders) got me the six screws that go in the chrome surround around each headlight. The old screws were completely rusted into the buckets. I drilled them out and then had to tap out the holes to get the new screws in. Close up. Spent alot of time with the steel wool to clean up the chrome stuff.
william harris
May 28 2005, 06:12 PM
Also started on the doors, window channels, winder mechanism, etc. Clean and redo everything before it goes back in.
william harris
May 28 2005, 06:13 PM
Another view up front. Miles, show us that clean car.
william harris
May 28 2005, 06:15 PM
Stuff waiting for my attention. Every part was painted by the previous crappy paint job, so a lot of time will be spent removing the overspray and paint where it don't belong.
Thanks to everyone for their encouragement.
lybones
May 28 2005, 06:24 PM
You rock! Too bad Discovery Channel isn't doing 914 shows.
william harris
Jun 2 2005, 07:20 PM
OK, so two weeks spent on one door. Holy crap, the damn inside wipe (the PITA piece that slides into the aluminum guide) beat my ass today, got it about half in with liquid soap and decided to call it a day. Hope to finish it tomorrow. Any how, decided to go ahead and assemble the rest of the door just to see how everything goes. Here's where I left it today.
william harris
Jun 2 2005, 07:22 PM
Remember now every piece was oversprayed yellow when the prior crappy paint job was done. So everything was cleaned (heavy duty degreaser works wonders), polished with steel wool and wire brushes, detailed, disassembled and reassembled and cleaned, lubed, etc. All new seals, the window lift mechanism was wire wheeled and painted, etc. I am damn happy with the way this is gonna turn out.
william harris
Jun 2 2005, 07:24 PM
You know it is a special form of insanity when you spend hours cleaning and painting stuff inside the door that nobody will ever see. Still, I know it is there and better than new.
william harris
Jun 2 2005, 07:28 PM
The funny thing is I'm gonna take the whole door apart again before the "final" assembly. The vent glass is just sitting in place, no glue or sealer - guess I will put something in there. Same for the felt channels for the glass. Anyway, I gotta put that PITA piece in tomorrow. Then I will start on the passenger side door.
Crazy stuff no longer available - like the cap at the top of the back window channel for the driver's door - passenger side is available from Porsche - but no driver's sides??? Are they different?
Also the brace under the vent window is different from 73 to 74 piece (I had both), the 73 piece has a big tab that goes into the seal under the vent window and offers a lot more support.
william harris
Jun 2 2005, 07:30 PM
I know some guys won't get excited by the door details, but I like the detailed stuff to finish off the car. By the way, what was used to attach the vapor seal (plastic liner) to the metal door before the door panels go back on?
william harris
Jun 2 2005, 07:32 PM
Anyhow, for the concours wiennies, the glass is the same glass that came out of the car, hell for all I know it has a date code somewhere.
Tomorrow hope to post pictures of the damn PITA thing all done and ready to go in.
william harris
Jun 4 2005, 05:24 PM
Today was the first day this year it was over 80 degrees in Massachusetts. So, I felt the need to put the wheels back on the car and give her the first bath since the new paint. Man, this was fun.
william harris
Jun 4 2005, 05:25 PM
My neighbors must think I'm nuts.
Guess they never saw anybody wash a car with no doors, etc.
