Eric_Shea
Jun 17 2005, 04:05 PM
Thanks for the plug-a-roo
When do we go for a ride? I've always wondered what a teener felt like the day you drive it off the lot. 30 some years later and you'll accomplish that. Should be fun.
william harris
Jun 17 2005, 04:26 PM
Eric Shea- I'll pick you up on the way to WCC 03 (2006).
Pictures of install hopefully this weekend.
Gint
Jun 17 2005, 06:26 PM
| QUOTE (william harris @ Jun 17 2005, 02:46 PM) |
Thanks guys, I had a vision in mind. This will probably make some guys flinch - I wanted a better than factory fresh restoration and then I want to flog and drive the wheels off the car. Yeah, that's right, rain, crud, bugs, what have you - I would like to put 200,000 miles on this car before I pass it on to the next generation. |
That's my plan as well. GO!
Doug Leggins
Jun 17 2005, 07:45 PM
| QUOTE |
QUOTE (william harris @ Jun 17 2005, 02:46 PM) Thanks guys, I had a vision in mind. This will probably make some guys flinch - I wanted a better than factory fresh restoration and then I want to flog and drive the wheels off the car. Yeah, that's right, rain, crud, bugs, what have you - I would like to put 200,000 miles on this car before I pass it on to the next generation.
That's my plan as well. GO! |
That is was is was is ... my plan too. It is getting harder to stick with "is"
Go Men Go!
kenpolives
Jun 18 2005, 04:06 AM
Great work so far Mr H, sometime I need to drive over there and get Eric and your help installing the windshield/targa seal. Last time mine ripped and you know how expensive they are. Did eric get you your seal?
I also got my car back from CFR welding a while ago. He does do great work.
Don
william harris
Jun 18 2005, 08:13 AM
Hell yeah, Eric is partsman. I give Eric all the credit, he just knows how to put the damn thing in, that and the lithium grease.
Glad to hear Chris fixed another one - and Racer Chris does outstanding work!!! Eric and I volunteer to put your next seal in - notice I'm volunteering Eric, I'm just the helper.
rhodyguy
Jun 18 2005, 09:25 AM
refreshX4, 30 minutes, and nothing but red x filled boxes
. i'm sure it looks swell william. if you haven't got to it, 3M double sided scotch tape works very well for securing the vapor barriers to the doors.
k
william harris
Jun 18 2005, 03:39 PM
OK, here are those door gap pictures I promised.
william harris
Jun 18 2005, 03:42 PM
Next. Guess what I found when I went to put the door panels on? On the drivers side the arm rest/storage box is held in place up top by two bolts/phillips head that go into two "captive nuts" housed in the door. I noticed when I took the arm rest off a couple of years ago there was no bolt in the front hole. You know why? The captive nut is not in the door. Gotta get one.
william harris
Jun 18 2005, 03:44 PM
Last one for now. Gotta go make some new door vapor barriers. Using the one olds for a pattern, but they are pretty torn up. Will post some pictures of the door panels in a little while.
william harris
Jun 18 2005, 06:32 PM
Here are the door panels back in place. The original door panels.
william harris
Jun 18 2005, 06:33 PM
Glue the backing for the back panel back in place and slapped the back panel in the hold it in place for the adhesive to set up.
william harris
Jun 18 2005, 06:34 PM
Passenger door. This panel was really nice.
william harris
Jun 18 2005, 06:35 PM
Hard to believe this is all the original stuff. Not too shabby.
william harris
Jun 18 2005, 06:36 PM
Last project for the day was to run the cable and pull for the engine lid release. In and working.
william harris
Other side view. Gotta put the seats back in.
william harris
Jun 18 2005, 06:37 PM
What the hell, the same photo. Must be time to crash.
william harris
Jun 21 2005, 06:46 PM
Today I started the project to install the dash. Got a late start so didn't get too much done today. Hope to have the dash completely installed over the next few days. Starting to look much more like a car again
william harris
Jun 21 2005, 06:47 PM
I need the tool to install the front of the light switches, using the needle nose pliers in a real PITA. Got one from the local Porsche shop but it is too big - must be for 911 switches
william harris
Jun 21 2005, 06:49 PM
Been meaning to post a picture of Eric Shea's master piece. Everyone needs one of these.
william harris
Jun 21 2005, 06:50 PM
Replaced the dash face material on top and the basket weave on the face. Gonna look mighty good when it is all back together.
william harris
Jun 21 2005, 06:51 PM
Well here is how it sits today. More to come.
william harris
Jul 3 2005, 03:05 PM
So after the last post I figured out that the upholstery shop gave the dash face a couple of holes I didn't need - like on both sides of the cigarette lighter!!! So I ripped that off to redo it myself. So in keeping with my plan to always keep moving the job along, today I did a couple of chores. Reinstalling the outer rocker covers came next.
william harris
Jul 3 2005, 03:08 PM
I thought this would be a simple bolt on procedure.
No such luck, the damn rocker covers must really be pushed on and then you have the problem of trying to align the holes for the three bolts along the bottom and the two bolts - one on each end that go thru the rubber donut and into the clip on the car. This job had me wishing for a lift.
william harris
Jul 3 2005, 03:10 PM
You probably can't notice, but I also added the windshield washer nozzles on the cowl. And, I borrowed Eric Sander's (Partsman) rivet gun to add a few pieces back on to the car. Plate on passenger side headlight box.
william harris
Jul 3 2005, 03:11 PM
Here's the plate back in place. Also riveted the VIN tag back to the A pillar.
william harris
Jul 3 2005, 03:12 PM
Must be a picture of the VIN plate here somewhere. Well you can kinda see it here.
william harris
Jul 3 2005, 03:13 PM
Trying to get ready to put all the glass back in real soon. Couple of views of the car.
william harris
Jul 3 2005, 03:16 PM
So the next big push will be to finish the interior of the car. Chris Foley helped out by sending me a barrel nut needed to mount the driver side arm rest and a clip for the dash/instrument cluster. Chris - how about some pictures of the engine build? Trying to get it ready to join back up with the engine real soon.
william harris
Jul 3 2005, 03:18 PM
When it gets too hot, I cool off in the pool for a couple of hours and then do a little more.
william harris
Jul 3 2005, 03:19 PM
Here's the little brother of # 1970.
william harris
Jul 3 2005, 03:20 PM
Happy Fourth of July everybody.
Rleog
Jul 3 2005, 05:49 PM
Gotta love that deep blue......one sharp 914, Wm.
william harris
Jul 3 2005, 08:14 PM
Thanks Bob. Chris told me he was working on your car this week.
hargray2
Jul 4 2005, 11:36 AM
Quote:
From your other thread....
"This will not be a concours queen"
Now look whatcha done gone and did!
Eric_Shea
Jul 4 2005, 01:38 PM
Do you wash that thing every time you take it out?
You're gonna rub the paint off of it!
WCC06... driving through SLC right?
william harris
Jul 4 2005, 04:01 PM
There is so much dust and pine tree pollen on the car I can't resist washing it off when I roll it out of the garage. Working on the interior today.
