All 4 wheels are now finished. Waiting on me to install the 5-lug swap and change the tires over.
More cleaning
Pulled the oil pump. Looks good and no contact between the cam rivets and pump.
Camshaft, wish I could tell what is is. I was told it was swapped out with the carb install, but based on other things below it is possible that's not the case.
Now for the biggest part. I tore down one of the heads and started cleaning. Put a ton of elbow grease into it. There were some marks where something bad had happened in one of the combustion chambers, but I thought that since it had been running in this state, I would just clean, reassemble, and go from there. The pic makes them look worse than they are, they're just filled with carbon still. (Bottom head in the pic below)
Then I put it all back together and started in on the second head. I spent a good 3 minutes just pulling the valves out and a light scraping and found that the passenger side head was in far worse shape. One combustion chamber looks like a 14 year old boys face, huge gouges, something was bangin around in there something fierce!
Strange part is that for both heads, the damage is on the cyl closest to the trans. Wonder what caused this...
At any rate, I wasn't going to put a ton of time into cleaning this one up, looks toasted. So I messaged the local 914 guy that I've picked up a bunch of parts from and turned out that he had exactly what I need. Drove down to his place and picked these up.
New heads are super clean. He was unsure of the exact history, but he had gone through it and it looks like everything was done to them. There is one exhaust stud hole that I will need to fix some threads on, but otherwise they're cherry. I'll probably pull the valves and inspect it all to be on the safe side but these are great.
Further inspection of what I have shows that I have the stock crank (66mm stroke) and that paired with the 96mm pistons means the engine is actually a 1.9 and not a 2.0. This is also what makes me fear that the factory cam is still in there... Follow my line of thought...
At some point in the cars history there was some sort of catastrophic event that caused the head damage. The event also caused significant piston and cylinder damage. The owner probably brought it to a shop and they swapped the 96mm pistons and cylinders in. The 1.7 heads still have 100mm registers for the cylinders, so they got the 96mm cylinder necked-down kits that were used back then that meant not having to machine the 1.7 heads for larger cylinders. They must have been on a budget. That's why they may not have swapped the cam. Either that or they dumped all their money in the cam, carbs, P's and C's and didn't have enough for new heads, or headwork... Who knows. If they were really on a budget I feel like they would have just done a stock set of P's and C's. For the cam, I cam probably measure the lift, may not be able to get an accurate duration measurement with the cam still in there.
So next on the project list:
-pull valves on new heads and inspect and fix exhaust stud
-reassemble new heads
-clean up block some more
-pull a rod and inspect bearing surfaces
-clean some more
Also, I'm going to try and duplicate the engine lift plate shown in the factory manuals.
I am aware that Tangerine sells something similar for just north of $100, but I like the idea of fabbing one myself. I'll probably take measurements off the block for the important parts, just wish someone I knew had one of the actual VW tools.
