Today I got to work on my 4.0 conversion. The Cayman transmission has a hydraulic clutch, so I needed to make a way to hook it to the existing clutch pedal.
I fabricated a metal plate to hook to the pedal box, and stick out to the side to mount the clutch master. Simple plate with holes. I had already pulled the pedal box and brake master out of the chassis, so I bolted them together with the plate, and bolted the clutch master to the plate.
I marked where the clutch master would meet the clutch pedal. Then I disassembled the pedals, pulling the clutch pedal and arm. I won't need the spring with the hydraulic master, so it wont be reinstalled.
I drilled into the arm, and put a 6mm pin with a threaded end into it. That has a brass bushing that is 6mm on the inside, and 8mm on the outside so it fits in the factory end of the 964 clutch master cylinder.
Here are some picts of the assembled pedal box with the 964 clutch master.
Click to view attachmentClick to view attachmentClick to view attachmentThe plate I made is just a template to determine spacing between the brake and clutch masters. I had not trimmed it down when those pictures were taken.
Click to view attachmentThis is the area on the chassis I have to modify. The plate is hanging off the stud on the left. It was trimmed to the correct length, and tapered to fit the clutch master cylinder location. I put a bare pedal box in the chassis so I could use it for the studs.
The black lines show where it needs modified. I have figured out that I need to cut the right vertical line, and the bottom line, then pull it out so that it is flat. I can then add metal on the side and the bottom to fill in the open holes.
Because of the neighborhood, my garage curfew is 9:00 PM. So I had to stop for the night.
More to come tomorrow (Unless we go to visit my MIL).
