While we have this downtime, I am finally getting something done on my car. The oil system is pulled apart to add a thermostat, but I am stuck because I am waiting on, of all things, a drill bit. I need a 20.5mm bit to fix some fittings with messed up threads. Yes, I realize that is a 13/16 bit, but everything is closed on Easter Sunday.
So yesterday I started to tear into another issue. My LED front lights act weird. If you turn on the turn signal or flashers, the white LEDs flash. If you turn on the park lights, the yellow LEDs come on. If you turn on the park lights when the white LEDs are flashing, the yellow lights come on, and the white lights stop working. Considering how custom my wiring harness is, I figured it was something in the wiring causing it.
I tore the knee pad off, dropped the fuse box, pulled the gauge cluster, and pulled both the light switch and the hazard switch out so I could get to the wires.
No matter what I did, I could not find a reason for the problem. I finally broke down and pulled the LED board out of the right signal pod. I made a test rig to hook it to an old Radio Shack 110V AC to 12V DC converter.
I get the exact same results when on the test rig. White lights on, hook Yellow lights to the 12v power and the white lights go out. Remove the power to the Yellow lights, and the white lights come back on. But there is a delay before the white lights come back on, about 2 to 3 seconds, kinda like a capacitor charging.
The other thing I noticed is the jumper pads on the back of the board. There are three pads, labeled "US", "Euro" and "Blanking".
Mine has the "Blanking" one soldered.
I looked at Betty's 914, and the Six, both of which have the same LED boards. Bot of those have the jumper on "US" because they are US spec lights. Mine are Euro spec lenses, so I would assume they need to be on the "Euro" setting.
Can anyone with Euro Spokeworks LED boards check and see if the pad should be on "Euro"?
Click to view attachment Click to view attachmentThanks!
I like to stay on top of things and make sure all my LEDs work for folks. So this one is only 3 years old...
I'm hoping it's all worked out for you.
For your front turnsignals, I was offering 'Euro' which would act like the original Euro lights where the white lights stayed on with turnsignals. The 'Blanking' you have was an upgrade like modern cars where the white running lights turn off with turnsignals on that side for better contrast.
I don't do the 'Euro' front turnsignals any longer. All boards have white LEDs blank out with turnsignals.
