Since the last episode:
Another milestone - the Capri is now registered and road legal. First time in almost 15 years.
The drive across town went well, up until it didn't. The engine, transmission and brakes all work well. Suspension was very soft up front, needed to get some new struts.
Got the paperwork completed, and went to start it for the drive home, and the only ignition key broke off in the ignition. Since none of the lower dash parts were in place yet, I was able to remove the steering lock from the column and quickly hot wire it to get home. Annoying, but not horrible. I got the broken key extracted, and pulled the ignition tumbler to get the key code to have a couple new keys cut.
Still pretty good feeling to have it registered...
This past month brought a nasty ice storm (almost 2 ½" accumulated on the ground), new parts, new plans, and more.
First, working under this (and other) car(s) is going to be a lot easier after the delivery of a set of QuickJacks. Not sure why I waited so long on these, but that's sometimes how I roll. Saved $500 by getting an 'open-box' set direct from QuickJack. Going to be a nice help on this and future projects.
New OE-type strut inserts from the UK are now installed, and have restored the ride and handling to a nice, original feel. I did find that the internal steering rack bushing is bad, and will replace that as soon as the part arrives. Otherwise the suspension is pretty well under control.
A small shipment from Denmark brought a left quarter window trim and a used turn signal switch. Both parts are extremely nice, and the turn signal finally cancels reliably, every time, either direction.
Still waiting for a final quote on the paint, the shop had some computer issues last week that have set him behind.
But in preparation for that, I've re-worked my schedule and plans. I was planning to drop the oil pan for new gaskets and clean the engine from years of oil leaks, but it sounds like the paint shop may want the car within a couple of weeks. So I don't think I want to pull the engine apart just yet.
Related to that, I think the engine cleaning and resealing is going to go a bit farther than I had originally planned. The farther I dig into this car, the more it looks like (with no way to confirm) that the 76k on the odometer might be original and correct. I'm reasonably comfortable that it hasn't rolled over yet. Which means that I'm fairly sure the original and notorious fiber timing gear has probably not been replaced. So the oil pan drop will be expanded to include pulling the timing cover, and most likely the replacement of the gears. Will probably replace the water pump as well, as long as I have it off anyway.
So today, in preparation for the upcoming repaint, I removed the entire heater-A/C box from the car. This is a rather major project on the '74 factory A/C cars. But it had to be done as the entire system (including the cowl plenum) is stuffed full of leaves, pine needles and other related junk that must be cleaned from the cowl before it can be painted. Will begin cleaning out all the crud tomorrow.
