Well, it's official; Yellow Freight lost my hood and deck lid! The vendor emailed me today to let me know they were filing a claim with Yellow Freight, and I could have them build more parts, or they could return my $$$...
I did get my trailing arm bushings installed this afternoon. I tried to follow the basic instructions of using a pipe clamp since I don't have a press. It did not go very well. I spent about 1.5 hours fighting to get the first arm done.
Click to view attachmentBut, I was able to ferret out a method that was simple and effective, but only used an orange plastic dead blow hammer for installation. It literally took me about 10 minutes to install the bushings and shaft in the second trailing arm! Here's my method for those without a press handy:
1. Install one bushing in the trailing arm (I started with the outboard bushing) No soap used/needed, and the bushing pressed in rather easy (my trailing arms are NOT powder coated)
2. Lube the inside of the bushing you installed, and lube one end of the shaft about 1/3 of the length.
3. Starting from the side without the bushing installed, insert the shaft through the arm and into the bushing. Press it in as far as you can with your hands - a twisting motion helped.
4. Tap the shaft further into the bushing with the dead blow. Go past the end of the bushing you installed and keep going until the other end of the shaft is flush with the end of the arm without a bushing.
5. Lube the inside of the second bushing and install it into the trailing arm - you should be able to tap it into the trailing arm without too much difficulty.
6. On the end where the shaft is sticking out too far, drive it back into the second bushing until it's flush with both bushings - I used a large socket on the ground to allow the end of the shaft an opening to go into past the bushing.
Sorry I don't have pics - by the time I figured it all out I had the second arm complete!
I touched up the black paint on the arms where I had scuffed it up a bit wrestling to install all the bushings. One teenie-tiny step closer.
