Thanks guys! Appreciate the encouragement
I figure its another shot at enhancing aesthetic/style points...think I've heard that around here somewhere
I'm always excited to see updates on this thread. Nice work @mgarrison !
I purchased that same radiator for my build and was also planning on using the water-neck adaptor with AN fittings and hose. What size AN hose are you using?
A couple of thoughts on your interference situation... The water-neck adapter sure does look cool, but maybe it adds too much length here. Could you use a short section of rubber hose as the transition between the radiator and your AN hose?
What about finding someone to TIG weld a short section of aluminum elbow to the radiator outlet?
Just unprofessional observations from my situation, so YMMV...
I'm sure you could have aluminum AN bungs welded into the radiator inlets. But, I wasn't sure where to get that done/who I'd trust to do it right on a brand new Mishimoto radiator. If I had it to do over, I'd see if Mishimoto would do it for me.
Looking at how low that inlet sits in relation to the bottom of the radiator, and how low you need to mount the radiator to clear the hood support structure (nearly impossible to see/figure out until I cut my hood vent), I don't think a hose would work unless it was molded as an elbow, and even then it would be snug, or you might need to shorten the end attaching to the inlet.
If the inlets were horizontal it would be much simpler...When I spoke to the Mishimoto guys about flow direction in their Celica radiator, they did mention you could run it upside down. Drain plug would be on top, and overflow connection on bottom, but it is possible. That would put the "lower" inlet near the hood and angled towards the hood though.
I was not super happy with how my radiator mount came out. It worked and wasn't really seen, but sure could be better. I'm getting my chance to improve it I guess!
I ran -16 braided hose through my longs. The -20 did not really fit, and seemed to collapse much easier than the -16. Not sure on the hose specs as it came with the engine/trans I bought from another member of 914World. If your using -20 I have 4 -20 bulkhead fittings you can have if you want/need them - just cover shipping and there yours...
