QUOTE(mgarrison @ Dec 16 2022, 09:40 PM)
I've been working on my radiator mount/frame. But I had to replace my phone and the pics I took are in the new iPhone format and basically unusable. And, I got the whole thing welded together only to discover it was about 1/8" too tall/high. Had to cut off the bottom mounts, move them down, then re-do the upper braces (why there's 4 Rivnuts instead of 2 on each upper brace.
So, I gave up and deleted what I'd taken, but took some new ones this afternoon while testing to see with my rather sophisticated CAD system if I can mount the aluminum shrouding before installing the radiator mount...State of the art CAD system! Even my scissors suck...
Click to view attachment Survey says...Nope! Can't mount the lower sides before it's installed in the car.
Click to view attachment Once it's in the car I believe things will fit ok.
Click to view attachment Need an extra 1/2" or so on the back of the bottom shroud to close up this gap though!
Click to view attachment Arguing with myself
over how to shroud the portion above the curved bracing. Not sure if I should go angled like this, and then a cosmetic cover over the top, or...
Click to view attachmentLooks really good! I’m following build closely since I’m planning to do something very similar.
Couple of questions…. 1. When you ran the coolant hoses in the longs, did you run them right inside of the existing insulated ducts?
2. Is the part number of the radiator “MMRAD-CEL-00”?
3. What radiator fans are you using?
Thanks, Aaron
