QUOTE(Spoke @ Sep 22 2023, 04:51 PM)
Nice work on the 914 and sorry about your son's accident.
A couple of comments. The fuse block should work where it's at as long as you can easily reach it with the tank in and it has a cover to keep moisture out.
About the tank, not sure if you're going to use the little portal to make the connections to the tank. These can looped around to the driver side and back thus giving ample length to do the connections with the tank out and drop it it. I did this with my 914 and welded the portal closed.
Thanks for the feedback. The fuse block does have a water proof cover & seal. Also, being in PHX area, not much water/rain to contend with.
I have AN adapters on the tank outlet and am using the portal to access and connect them.
Most likely will be hitting you up for the LED lights/panels - plan on going all LED on the car since I'm not worried about originality.
