I wanted to make the engine cover removable for better access. I looked at a couple different options and decided on using horizontal pins mounted to the firewall with receivers mounted to the cover.
I made the receivers adjustable in height and alignment. First removed all hinge and torsion bar stuff, then welded plates with 6mm studs at each hinge location. Then I made the receiver parts with elongated slots for adjustment. Inside each part are delrin bushings I made with a female taper to help with pin engagement.
The cover slides onto the pins with ease and uses the stock rear latch to secure the cover.
Here’s a couple detail pics of the parts….
