Aaron Cox
Jan 12 2006, 09:44 PM
outstanding progress lou!!!!!
cant wait to see it!
what color iz you gonna spray?
Lou W
Jan 12 2006, 09:47 PM
Mexican Blue aka: Riviera Blue, Im gonig to smooth out the top, and paint both valances and rockers the same color too
Aaron Cox
Jan 12 2006, 09:51 PM
QUOTE (Lou W @ Jan 12 2006, 08:47 PM) |
Mexican Blue aka: Riviera Blue, Im gonig to smooth out the top, and paint both valances and rockers the same color too |
one of 2 soon to be painted 914's in mexico blue
awesome!
Lou W
Jan 12 2006, 09:53 PM
QUOTE |
Aaron Cox Posted on Jan 12 2006, 08:51 PM -------------------------------------------------------------------------------- QUOTE (Lou W @ Jan 12 2006, 08:47 PM) Mexican Blue aka: Riviera Blue, Im gonig to smooth out the top, and paint both valances and rockers the same color too
awesome! |
Who's the other one?
r_towle
Jan 12 2006, 11:50 PM
Now that is a first.
That car has been there so long it has grown right into the concrete floor...
Your gonna have to get help to get that car removed from that slab....
It looks like a trailer skirt going around it...
LOL
Rich
Lou W
Jan 16 2006, 07:03 PM
Started the final block sanding today, I'm using 150 grit and a rubber sanding block. Sand it down so that's there is no orange peel;
Lou W
Jan 16 2006, 07:04 PM
Another;
Lou W
Driver side rear panel;
Lou W
Jan 16 2006, 07:05 PM
again;
Lou W
Nice and smooth;
Lou W
Jan 16 2006, 07:06 PM
Rear trunk;
Lou W
Jan 16 2006, 07:07 PM
Next, I will shoot a couple more thinned down coats of primer;
Lou W
Then, I'll finsh with 500 grit, before applying the sealer;
Lou W
Jan 16 2006, 07:08 PM
Then , finally a finished color, Yahoo, I'm getting close.
Lou W
Jan 16 2006, 07:10 PM
I started cleaning the latched and catches, I used this, I let the parts soak for about an hour, then I scrubbed them with a parts brush, and rinsed them off and applied light oil to prevent rusting. It really worked well;
Lou W
Jan 16 2006, 07:12 PM
I bought Engmans Stainless Steel Door Straps, and new rollers from Performance Products, the original ones were in pretty rough shape. The rollers arrived today, so I installed the parts;
Lou W
Jan 16 2006, 07:13 PM
They cleaned up pretty good;
Eric_Shea
Jan 16 2006, 07:15 PM
Lou, Lou, Lou, Lou, Lou, Lou, Lou, Lou, Lou, Lou, Lou, Lou...
jim_hoyland
Jan 16 2006, 07:17 PM
Sweeeeeeeeeeeeeeeeeeeet !
seanery
Jan 16 2006, 07:21 PM
this looks great!
Lou W
Jan 16 2006, 07:24 PM
After taking the door strap assembly apart, and seen how worn down the strap and cracked the rollers were, I would strongly recomend that you take yours out and repair them. My drivers side brackets roller pin had elongated the mounting hole in the bracket itself, so I will most likely have to replace that one.
craig downs
Jan 16 2006, 10:43 PM
Hey Lou
If you shoot what they call a guide coat over the primer before you sand it it makes sanding alot easyer. Its just a fine mist like overspray of a contrasting color like in your case black.
Then do your final block sanding. When you sand all the guide coat off you're done and it will be nice smooth and flat. Also the guide coat will show all the low spots and scratches if any.
Looking real nice
Craig
Lou W
Jan 16 2006, 11:08 PM
Craig,
Thanks for the input, that would have been the smart thing to do. I had considered doing that, but I was really focusing on the orange peel as my guide. when I do the deck lids and the doors, I will definately shoot a Guide Coat.
Lou W
Jan 23 2006, 12:05 AM
I started to work on the rocker panels that I bought from Dave (Korijo). First I stripped them with paint remover;
Lou W
Jan 23 2006, 12:06 AM
another;
Lou W
Jan 23 2006, 12:07 AM
I had to do a little bit of fiberglassing;
Lou W
Jan 23 2006, 12:09 AM
I filled in the holes for the jack posts, I'm planning on using a scissor jack;
Lou W
Jan 23 2006, 12:12 AM
I shot the final coat of primer last week, so now I'm block sanding again. I started off with 500 grit, I found it would hardly cut the primer, so I read the instructions
and, it said use 320 to 400 grit, so I'm using 360 grit instead and its making a big difference.
Lou W
Jan 23 2006, 12:13 AM
Here's a better picture;
Lou W
Close up;
Lou W
Jan 23 2006, 12:14 AM
Right rear quarter;
Lou W
Jan 23 2006, 12:15 AM
Passenger front;
Lou W
Jan 23 2006, 12:16 AM
After I get the rest of the car blocked, hopefully this week, I'll shoot the sealer next.
Eric Taylor
Jan 23 2006, 04:50 PM
Looks really great. What color are you oing to shoot it?
Eric
TJB/914
Jan 23 2006, 04:55 PM
Really great work Lou.
Sure would like to see a picture of the finished underside coating & clear coat. Keep those pictures coming.
Tom
Lou W
Apr 3 2006, 11:43 PM
I got some more Powder Coated parts in today;
Lou W
Apr 3 2006, 11:44 PM
Another picture, Different angle;
Lou W
Apr 3 2006, 11:46 PM
Getting the nuts and bolts ready to get plated, I just hope I can remember where they go;
Lou W
Apr 3 2006, 11:47 PM
Another view, some of them look a little rusty, I dipped everything in Vineger and then I'll get them beed blasted before platting;
Lou W
Apr 3 2006, 11:49 PM
Here's a picture of a couple parts that I bought from Bruce (he's a member here), they did a very good job plating these;
JoeSharp
Apr 4 2006, 12:00 AM
Lou: I think I saw a picture of you blocking the inside of a fender well some where. I know you are a little extreme, I thought only Jim Hoyland was that anal.
:PERMAGRIN: Joe
redshift
Apr 4 2006, 12:13 AM
Wow! Nice stuff Lou! How long now til blast off?
Very nice!
M
Lou W
Apr 4 2006, 12:30 AM
QUOTE (Joe Sharp @ Apr 3 2006, 11:00 PM) |
Lou: I think I saw a picture of you blocking the inside of a fender well some where. I know you are a little extreme, I thought only Jim Hoyland was that anal. :PERMAGRIN: Joe |
I got the front, rear and gas tank finished, now I'm blocking the engine compartment, what a pain in the ass.
I may need to hook up with you, i think I'm missing a couple bolts or so, last time that I was at your house I saw the bucket of bolts that you have, I'm sure you'll have what I need.
Lou W
Apr 4 2006, 12:31 AM
QUOTE (redshift @ Apr 3 2006, 11:13 PM) |
Very nice!
M |
Thanks, Ah, it's not looking too good for early next year, my schedule is a slipping
I just keep finding more things to do, DWD
redshift
Apr 4 2006, 02:21 AM
At least you are doing it (DWD) right.
Fantastic.
M
Elliot_Cannon
Apr 4 2006, 03:04 AM
Where are you shooting the car? How are you controlling overspray? the car looks great so far. Can't wait for the final pics.
Cheers, Elliot
Lou W
Apr 4 2006, 10:05 AM
QUOTE (Elliot Cannon @ Apr 4 2006, 02:04 AM) |
Where are you shooting the car? How are you controlling overspray? the car looks great so far. Can't wait for the final pics. Cheers, Elliot |
I'm shooting it in my garage. It will be shot in sections, I'll shoot the front trunk, gas tank area, engine bay and rear trunk one day, then I'll shoot the body the next, and then shoot the decks and doors after that. I'm going with a solid color, so I shouldn't have to worry about matching the paint like a metallic.
I've shot before in the garage and it worked fine, I just put plastic tarps up on the walls, wash the floor down, close the garage door and open the side door and use an exhaust fan.
I'm using the new HVLP guns, so overspray is minimal.
Grimstead
Apr 4 2006, 10:07 AM
You’re doing a great job Lou.
Mind if I sneak my car over there to have the engine bay done?
Lou W
Apr 4 2006, 10:20 AM
The gun on the right is what I used for the primer, the one on the left is the detail gun which I'll use in the engine bay area, the area is a little tight. I'm getting another one to use for the final paint.
jsteele22
Apr 5 2006, 04:17 PM
Lou,
Great work so far! I was curious (I know this might sound naive..) did you do all the underbody work from under the car, without a rotisserie ? Sounds like one helluva job.
